Oscillating multitool recommendation
branimal
Oscillating Multitool opinion?
Fein
Makita
Bosch
Or is it all about that blades that come with it?
Bosch comes with 5 blades for $200;
fein only comes with 1 blade for $200;
Makita comes with 1 blade for $160.
Home Depot prices....
jd_1138
NE Ohio
The blades are pretty cheap, so I wouldn't base the decision on how many it comes with. But I'd probably stick to name brand blades. The el cheapo ones are not as good (but can suffice for some applications). I used some cheapies to cut PVC, and they were alright.
I think Fein is the best. I have an el cheapo $35 corded Ryobi one, and it works great. Are you in a cordless tool system? Because most offer multi-tools, but corded is also fine.
Dagny
Northern Wi.
It's the only bosch tool I own I got a bag small box of blades and I think a bunch of sandpaper with it works great. 69.00 It was display at menards.
jp828108
I have a harbor freight one, and a menards performax brand one. Both were priced substantially cheaper than the ones you list. The harbor freight one is seldom used, and I use the menards brand one because it has an adjustable speed. The menards one came with a lot of different blades. Most were pretty junky. I have purchased additional ones when I could find them for the "right" price, and have a decent stock. No experience with more expensive brands, but am quite happy with good blades and the menards performax. If you have to have a name brand then I'm sure any listed would be good, if it's for light use maybe a cheaper one with lots of extra blades might serve you better
RStewart
a little north of boston
Ended up with a cordless Milwaukee after asking on here(even though no one here recommended Mil.) Got it because my son has a ton of Milwaukee and it has been very handy and works like a champ.
catron44
CT
I would go with whichever fits your hand better. Ive got the bosch and i like it. Ive also used the fein at work and like that too. I havent used the makita.
Ive had good expeience with imperial blades.
Cruzan80
Denver, CO
The bosch is a workhorse. All the bells and whistles, and when I looked a couple years ago, was reviewed at or above the Fein. No complaints.
I do also have a one-speed HF for the dirty jobs, so if I kill it, I don't care (grout removal, etc). But every time I use it I am glad I have the bosch to use regularly.
shawhite
I like the Bosch with the new starlock blade system. But the blades are pricey .
cgrutt
I have the fein and it's great. I think they make a few different models that take different style blades. The universal blades from home depot/lowes don't work with my unit. It's awesome though. No complaints.
mrjaw14
Nashville, TN
I have the Bosch. They are compatible with a lot of blades. Mine has a quick change blade system and is variable speed. The quick change blade feature is awesome. I use it more for changing the blade orientation to get the angle I want and use the variable speed to maintain control in tight spots or finesse a critical cut. Get a brand that doesn't lock you into a particular blade brand, a quick blade change system, and variable speed.
scooby074
Nova Scotia
Fein.
Also have the best life with the fein blades. Ive tried Bosch, Imperial and dremel blades, Fein are more money but last way longer.
TK-421
Pflugerville, TX
If your purpose is general home use, then do what my Grandpa does and buy the harbor freight version, and then buy another when it dies.
If the purpose is pro use, then I think any of the three you listed will do fine. I'd pick the one you like the looks of the best.
mshell56118
Elkhart, IN
I have a Rockwell Soniccrafter and hve use the **** out of it the past 6 months, i have installed over 1000sqft of new flooring and that required doing alot of flush cutting the rockwell worked wonderfully, then put some vinyl plank flooring down and used the saw to cut my notches and such out so it did not beat up the floor with the jug saw, help ny son cut out his pine wood derby car and sand it with the rockwell, \
6PTsocket
Fein
Makita
Bosch
I have the Rockwell. No complaints. It has a universal head that accepts almost any brand blade.
stage20
pcola FL
look at the amps....thats where you are going to get your power while cutting into something.
ive used them all.
harbor freights are cheap.... no power at all. i use it for fine work. starts easier, doesnt run off. more control. doesnt like hard cuts. as i mentioned, no power compared to other brands
the dremel is decent.
i like the dewalt myself.
friend has a milwaukee it works great too.
i had a ridgid cordless. it had good power. too many batteries floating around. i sold it.
any of them should serve you well. pick the features you like.
dewalt is the easiest to change blades. no tools required but it must be dewalt brand(or made for dewalt style saw)
jd_1138
NE Ohio
Does Bosch have a proprietary blade system?
Yeah, but it looks like the universal fit blades will work in a Bosch according to this chart. Also you can buy an adapter for a couple of bucks. The Bosch, Dremel, Milwaukee attachment looks pretty robust. Though I've never had problems with blades slipping off my Ryobi that uses a less robust attachment (needs allen wrench to change blades).
TNBurban
Two biggest things are
1. Power - some brands make weaker powered versions at a lower price point.
2. Blade - ultimately it comes down to using the right blade for the job.
Cannot stress enough the importance of using the right blade if you are looking to use it for more than 30 seconds as a time. And use good quality blades.
I know people that bought cheap ones with crappy blades and didn't use the right blade for the job. They HATE oscillating tools. But someone who buys a good well known branded one and uses good blades and the right blade loves it. Go figure....
bdelmar2
I have the Rockwell Sonicrafter as well.
I just bought it fairly recently and haven't used it much though I expect to use it a lot on the old (1955) house I just bought.
I read quite a lot on them and watched a couple of videos before I went to the store.
The Rockwell has a couple of features that I liked before I actually laid hands on it.
One is the blade change system, its fairly simple yet works well. Some of the reviews misunderstood how it works though. You don't have to remove the center piece for most blades, just loosen it - for some reason the reviewers had what I consider an unrational fear of losing the holding piece, I gather they must have been taking it all the way out every time.
Still only a blade change function so not make or break as long as it works well.
The F80 version of the Sonicrafter also has a unique feature, you have a choice of blade oscillation angles, all the other brands only have a fixed angle - currently anyway. The angle determines how fast it cuts, larger for fast cuts (5 degrees I think) and less angle for slower cuts with more control. (3.5 degrees?)
Speed of the tool also plays a part and pretty much all of them are variable speed with a wheel, except the dewalt. It has a variable speed trigger. At first I thought this would be a nice option, but I gather its difficult to control at odd angles/tool placements. Given that a multisaw spends most of its cutting time in odd situations this seems more like drawback than a plus.
I've only used my saw a couple times and I will have to agree that a trigger controlled speed would be a hassle.
I had to repair my shower valve for example. Its behind a tile wall and has screwdriver stops that were leaking. Whoever tiled the wall didn't leave enough room to remove the valves so I had to cut 2 v-shaped pieces of tile out.
To do that I had to hold the saw in 4 odd positions, one right after the other. No problem with the Sonicrafter, but would have been a hassle if I would have had to use a trigger.
Rockwell also makes pretty decent blades according to all the reviewers that mentioned blades, and their blades were often recommended for other brands of tools even.
I had already planned to cut the poorly installed grout out around my shower and tub - which was actually what I initially purchased the saw for, before the valve became a larger than expected job.
So I bought a better blade for that, carbide I think, and they don't recommend it for cutting tile, but it lopped those 2 small pieces out no problem. Took longer to get the saw plugged in and in position that it did to cut them.
I wasn't quite ready to buy the saw, but I was in either lowes or home depot and was in the tool section so thought I'd check them out.
The Rockwell felt good in my hands which is nice. The blade mechanism appeared solid and well made, as did the head and switch for the two blade pitch options - about which I had some concerns before getting an actual look at.
There were several Rockwell blades in their selection, more than all the others combined - even though I believe the Rockwell will take almost any blade should the need arise. Rockwell's blades are a little more expensive, but I don't mind that for a better blade. Generally I find projects have enough intrinsic stress I don't need to fight my tools as well.
It was also on sale for $20 less I believe, so even though I wasn't quite ready for it, I bought it anyway. Glad I did or the shower issue would have been an even bigger hassle.
$150 or the $130 I paid is more than many of the other multitools, but I figure it will last me for the rest of my life so I'd rather have a good one.
Edit: I have since been to the other box store and they had a large selection of Rockwell blades also.
chrisexv6
CT
Ive never used a Bosch corded OMT but I sucked it up and bought a Fein about 5 years ago (FMM250). Expensive? yes. Worth it? YES. I had the Dremel version when it first came out and it didnt work well. The blades wouldnt stay tight enough, so a lot of power from the oscillating movement was lost to the slop in the blade to machine connection.
The Fein feels much better in hand (the weight helps, oddly enough) along with being built better, the blade mechanism holds them really tight, etc.
I recently bought the FMM350 with StarLock but havent used it yet. Just plugging it in and turning it on, its a LOT smoother than the FMM250 (mostly in part to how the motor head "floats" in the unit now). The price isnt horrible either (199 at HD) so it feels more obtainable than it used to be.
The killer is buying genuine Fein blades, and I havent seen any of the aftermarket companies making StarLock style blades yet so you're at the mercy of Fein or Bosch. The Bosch blades are a little more affordable but still not cheap.
sberry
Brethren, Michigan
I bought a Performax at Menards for 40 and looks and feels identical to the Bosch, DeWalt, Rigid, it has the hi power motor and 5 blades along with a "useable" case, better than most. They do make one model cheaper as does HF but its not the same. Different motor, different chassis.
Monte
Germany
Fein or Bosch with Starlock
<iframe width="560" height="315" src="https://www.youtube.com/embed/cdX4SC6hYLc" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/Bd5XV3e1cvk" frameborder="0" allowfullscreen></iframe>
Dave455
Sussex, England
I bought the Fein a few years back. Come in a deal with a load of blades chucked in.
Verdict - superb tool. Wouldn't be without it now, it's probably my second most used power tool, and I use it for a lot of things I didn't think about when I bought it!
Some observations. Yes, blade quality is relatively important. Fein are great, no worries. I use British made saw blades that seem to be as good, but I've seen some substitutes that are poor!
Read about the different blades and ensure you get the right blade for the job. These tools seem to be more sensitive than others in this regard. If you use the wrong blade it can get trashed instantly!
Read the instructions and set the right frequency for the blade / job. If you don't do this the tool won't perform optimally.
jboehm
Spring, Texas
I have used the Fein, Bosch, and HF. By far the Fein is the best, but you are paying for it. I own the HF and can't kill it.
M6erfan
'Merica!
another Bosch multitool owner here. Bought it last year for home remodel, dont know how I would have got by without it.
jd_1138
NE Ohio
It's amazing how many people do not have multitools -- even pro tradesmen. It's such a precise cutting/sanding tool that it's silly to not have one in your arsenal, even if it's just a $40 Ryobi corded model.
M6erfan
'Merica!
My BIL is a painter by trade but all around handyman. He works for a lot of real estate flippers and is always doing various stuff like windows, flooring, bathroom plumbing, drywall, trim, light electrical, etc. He's never had one...
atthebeach
At The Beach
I had a 1 amp Dremel multitool for many years that recently died. Replaced it with a 3 amp Makita multitool that comes with an adapter allowing the use of the blades I have on hand. Mostly used for finish trim work. Both were good purchases.
jd_1138
NE Ohio
That'd be an excellent Christmas gift for the guy. :) I bet if he had one he'd use it.
4 Ever-Fish N
Deep East Texas
Looks like I'm the only one who has a Makita, cordless model. I really like it. I have bogged it down before, battery may have been a little weak. I don't have any experience with the other models. Edit: Just noticed one other guy has a Makita.
