nonhog
So my shop has metal on some walls and I want to seal the air gaps.
I have added flashing under the siding which helps, should keep the mice out
however still allows air (heat-cold) in and out.
I have seen foam shaped like the siding that you place in the voids.
The only problem is it was kinda spendy once you add up 30 feet here and forty feet there upper and lower.
I have thought about spray foam for the gaps to seal it up but in so many places it would just flow right out w/o the foam seal dropped in 1st.
Seems there has got to be a better way. Am I missing something ?
