Rockwell Delta Drill Press- 15-231 w/ table assist!
tarbellb
Oregon
Found this on a Ebay auction, "local pickup only" which I feel like definitely improved my odds.
Got it for just under $200 sight unseen except blurry photos.
Model # 15-231 Made in Canada!? 3/4hp 15" w/ 6" quill travel AND .... table lift assist!
Everything is in excellent condition, barely used and the lift assist was complete and fully functional!
Got it home and everything was in excellent condition, I dont really care about the few peck marks since I will be using this and not just looking at it.
Came from a old HS getting rid of a bunch of equipment.
Rewired the momentary finger operated switch?? for a foot switch, a awesome upgrade I must admit.
Enough gloating...
tailshaft56
Miami Ok
I missed a nearly new $1200 jet drill press at an auction. Dumb be didn't know the auction house took plastic. unit sold for about $300
Davefr
OR
Looks like a "cream puff".
Is that table lift original or homemade? I've never seen anything like it.
T
tarbellb
Oregon
I've never seen one either!
Definitely looks mass produced, the action and quality are great.
bubinga
Nice!
Sent from my MotoG3 using Tapatalk
Again, Nice, Almost looks like you restored it, as in gave it a "face lift"
Interesting to note the pulleys have six groves. Are those 3/8" groves, and a 3/8" belt?
Mohawk Dave
SoCal
You killed it!
Start kicking around the idea of a 3ph motor with VFD. I get 3ph motors around here for 30-40 bucks. That will allow instant speed change. Most guys set pulleys at low torque, and then over speed the 3ph motor for small fast drilling since you don't need a lot of torque. You can almost pretty much get away with never touching the belt change again
454ragtop
Carver, MA
RE the pulleys, that's the more desirable 6 X 6 15" drill press, 6 speeds and 6" quill travel. I suspect the table raiser is a non Delta aftermarket add on, not unlike some of the speed reducers that have been found, possibly made by the same company. Might want to post it over on OWWM.org, they may well have more info over there.
scooternut
Pittsburgh, PA
Nice grab! Love the table assist but I do no now the origin as mine does not have one. Enjoy, it is beautiful.
I was initially puzzled by the 15-231 as it looked exactly like my 15-665. I'm no expert on the model numbers but I read that the 6 is for speeds, second 6 for quill travel, and I forget the 5. Yours seems to have these things but with a different model number.
I filled my table sins with JB weld and then sanded them out. They color slightly different but you forget all about it.
T
tarbellb
Oregon
Thanks again guys, I am very happy to have it grace the shop.
When doing research on it I also had a hard time figuring out exactly where it falls in the Delta/Rockwell line up.
If anybody has more info on this model or how it breaks down to others that would be appreciated. Regardless, its going to be a pleasure to use in the shop.
