New Wooden Boat Shop Floor
Skiff Builder
Southern NJ Coast
Hello Guys,
Raised a house up on pilings after damage from Storm Sandy(2012).This left me with a 32x34 space underneath to enclose and use as a shop. Standard for floor here is 4-5" concrete, thickened edge, poured directly on existing dense sand- $10K and up, plus fill, quoted.
I build boats and wanted to work on a wood deck for many reasons.
Old slab had been removed.
Brought in 30 yards dense graded aggregate for fill. Placed in 3" lifts and plate compacted to a total of 9".
Laid 2x6 and 2x3 .60CCA marine treated nailers to a 48"o.c.grid.Spiked to the pilings and perimeter mudsills.
Continued to fill and compact to the top of the nailer grid.
Skiff Builder
Southern NJ Coast
At this point we have a solid base with embedded nailers. You need a pick or hammer claw to dig into it. Could have laid conc pavers or horse stall mats on it if wanted. Our choice of "paver" was 3/4" Ext B/C plywood (non T&G).
Laid down 10 mil sheet plastic. Put down the ply using only a minimum of screws.
All the load placed on this deck will be carried by the fill.
Skiff Builder
Southern NJ Coast
For finish we went with oil based stain covered with water based polyurethane.
The B/C plywood had just the right amount of tooth. Not slippery even when sawdust covered.
cgrutt
Interesting! Looks great and thanks for sharing. Good luck with the boat building.
Skiff Builder
Southern NJ Coast
I poured cement aprons/ramps for the front and rear O.H.doors. We'll see if they last longer than the floor.
dave*99
Coastal NJ
I am curious as to what would happen if you get some minor flooding. Will that floor system float up? Is it anchored well in the center?
I suspect that "minor" flooding will have no affect ! The plywood is well above grade (9") and what is below ("dense graded aggregate") looks like it will drain quickly once the water resides.
Hey Skiff Builder ! I really like that Yamaha 90. IIRC, it is sort of a copy of the old OMC 3 cylinder on steroids. Lots of power in a small, lightweight package. The OMCs were thirsty and had some issues (no tell tale on some models) but were good engines.
Around here there is very little love for Yamahas.
Skiff Builder
Southern NJ Coast
Dave, that's an important consideration for this floor system. In the below pic you will see the tops of concrete anchors poured near centers of each nailer. We had a ground level wood deck/screen porch enclosure that was anchored this way. It survived Sandy's flooding with no movement or heaving.Hope it works here if ever needed.
dave*99
Coastal NJ
Makes sense. Looks good. I saw some poorly anchored decks float up during Sandy. Now I see your anchor system.
Skiff Builder
Southern NJ Coast
Just a question, why no insulation in the floor? 2" EPS foam or something ?
Moveover,
I wanted to put in 2"xps.
Reasons I did not at this time were:
Time and money.
3 years of every weekend and vacation day to raise, add addition, complete gut entire house and all mechanicals....you get the picture.Had to draw the line somewhere.
House is a second for weekend use now.
South Jersey winter is Dec-Feb and not to terrible.
The space is heated by natural gas, when I'm working in it. Very comfortable so far.That wood floor feels so much warmer than our old slab.
If i find myself there full time I may retrofit it in.
Skiff Builder
Southern NJ Coast
Wizard1,
That's an 05 i found new in 2009 for 4K while I was building the skiff. That and it's 269lbs weight sold me. Good running and not bad on oil for an old school motor.
I like the fact that I can easily pull start it if needed.
carhunter
southern Ohio
That's an ingenious solution! Nice work.
yeldogt
Interesting floor ... I guess time will tell.
We had what was basically a wood deck built on the sand - under the house on LBI. We parked on it .... and think of how many ground level decks are built. it was 50 years old when we sold the place.
It really a question of moisture -- that marine pressure treated will outlast the house -- even the plywood should be fine with repeated wet downs.
Mike99
Wow what a nice floor! I just finished my 2 car garage floor all in wood. Didnt have your energy so just used 4x4 posts everywhere and placed a bunch side by side where the wheels go. The car doesnt move anywhere else just in and out.
Skiff Builder
Southern NJ Coast
The 1068 sq ft of plywood cost me $900. It's exterior WPBP glue so feel I'll get longevity from it. Really not too much different than the ply the skiffs are made from. If I build enough boats I will end up with a totally epoxy resin coated surface 😳
nutmegct
SkiffBuilder: "For finish we went with oil based stain covered with water based polyurethane."
I've got a plywood floor in my new shed. What was the reason you decided to add the stain and polyurethane? Just wondering if I should leave my plywood bare, or if there's a reason for covering it.
Thanks.
Tom M.
WPBP = water proof boil proof ?
The only place I have ever seen that is on BS1088 marine plywood ! $$$$
Skiff Builder
Southern NJ Coast
Thanks.
Tom M.
Tom,
I wanted to finish it for stain resistance and ease of cleanup mainly. Car fluids,oil,glues,paint,water all wipe up easily. Hot car tires have not affected either.
I have 2 sheds, one floored in ply, the other with roughsawn hemlock. Neither was finished. Built 1988, still going strong, just shows dirt a little more.
nutmegct
Thanks Skiff. That is definitely a practical reason for adding finish to the floor. Not just "gee ain't it pretty!".
Tom M.
Skiff Builder
Southern NJ Coast
Wizard,
I was re posting lost pictures on this thread and saw your post on WBP marine plywood.
Look for BBOES plywood seen on many larger concrete forming jobs.
B face/B face/Oiled/ End Sealed. All plies are glued using phenolic resin so it's rated as water proof boil proof. Seen in S.Pine, Fir and Mdo around here. Have seen it used on larger cold molded boat hulls. Menards sells it, as well as commercial yards.
A lot of exterior ply uses the same glue ,but only on the outside veneers so does not make the rating.
https://www.menards.com/main/building-materials/panel-products/construction-panels/concrete-forming-panels/royomartin-3-4-x-4-x-8-greencore-plyform-concrete-forming-plywood/p-1444439107278.htm
