UPDATED: See post #7
Wow, just found this while cruising.
https://www.amazon.com/dp/B01MYC6O3P/?tag=atomicindus08-20
Corded Brushless Hitachi 4.5" grinder, pretty stacked specs as well. $190
_Ultra efficient AC Brushless motor that permits the use of extra long extension cords without power loss
_ Superior performance when using a generator due to an internal inverter circuit that regulates uneven power supply
_ Powerful 12-Amp motor produces a powerful 1,300 watts input power for tough grinding applications
_Ultra slim grip circumference (due to the Brushless motor) that reduces fatigue and improves control, especially during continuous use applications
_Variable speed switch allows the user to determine the best speed for the application
_ Electronic overload protection is an electronic feature that stops the motor when too much pressure is applied
_ Slide switch with trigger lock-on for comfortable and continuous operation
_ Kick-back reduction quickly shuts off power in the event of a bound wheel, extending the life of the gears and protecting the user from potential harm
_ 4.2 lbs, lightweight design facilitates maneuverability and ease in overhead use applications
_ Recommended uses: stone polishing, surface finishing, rust and paint removal, light grinding, concrete finishing, wire cup and wire wheel applications
Man that thing looks comfortable. Ive always had a thing for Hitachi, they were my first brand to buy a lot of back 10yrs ago. They seem to offer a lot of bang for the buck.
Its made in China, and is priced similar to a variable speed Metabo.... which I just bought and absolutely love. But still....
