air compressor fittings - how tight
proboscis
Rockaway, NJ
Hi all,
So I bought an air compressor and I have the various fittings (regulator, air dryer, etc.). I'm gonna use teflon tape, but I'm curious on how tight everything should be? Like hercules tight to the point of stripping threads, or just hand-tight + 1/4-1/2 turn? Thanks
helterskelter
hand tight then snug them up lightly. If they leak take them back apart and re-do the tape.
Mohawk Dave
SoCal
I've learned to snug first. If it leaks, then a little more snug.
Back in the day I used to go gorilla off the bat....that's bad.
wjamyers
Falls Church, VA, USA
since we're already discussing hose fittings I'd like to double check... on a 3/8" air hose the thin hex nut on the hose side of the connection is 9/16"... correct?
Also... all of my wrenches are too fat to fit on this damn nut (I crushed the end of my leaking hose getting the fittings off with a vise grip... )... what do you guys use to avoid this?
Also... do you reuse the fittings?
should I just put new fittings on my new hose? If not, how carefully do I need to clean the old teflon off the threads?
Sorry for all the noob questions and the hijack but I think these questions are relevant to this topic. :)
rlitman
Long Island
since we're already discussing hose fittings I'd like to double check... on a 3/8" air hose the thin hex nut on the hose side of the connection is 9/16"... correct?...
Often, but not always. I've found ones that are metric too, and I'm not sure if there is a standard to these.
I use my PliersWrench on these a lot, as the first half of the jaws are thinner than standard wrenches.
Mikeske
Washington State
Believe it or not, I have never used teflon tape on the fittings, I just tighten until they do not leak under pressure. If anything I use some never seize on them.
doogdoog
You could use tappet wrenches since they are thin and will be able to go between the joints or just grind down an old wrench.
Sticky Grips
NPT threads are tapered, which provides an interference fit. The threads are suppossed to slightly deform when tightening.
Add some tape or pipe sealer, and install just past snug. There's no reason to crank down on them.
