Craftsman has a new screwdriver set
gdocktor3
Connecticut
Vessel screwdrivers are JIS. This says it fits US Phillips screws. Are you sure this is made by Vessel?
K
kball
SoCal
Package says made in Japan and Craftsman has had Vessel make screwdrivers for them before so it's not much of a stretch.
Tellingthem
Traverse City, Michigan
I'm pretty sure that with Vessel (at least) a JIS will work in a phillips. I got some of the previous Vessel ball grip screwdrivers that Craftsman rebadged and they are great. I do not know for a fact if those bits are JIS, but I have used them in phillips before and like them quite a bit.
Dimitri
Toronto
Yup.
Lots of bit sets supposedly come with Philips bits, but if you look closely, they are missing the web between flats because they are really JIS but still labelled P0, P1, P2 etc.
Dimitri
Moparman390
My guess is if they are making them under contract for Craftsman those would be made to standard Phillips spec. Probably as easy a modification as slapping a different name on them.
Stevenn1
USA
Back in the 1980s some Craftsman tools were made in Japan, like the adjustable & combination wrenches. I know because I own a few of them.
bonneyman
Desert SW
An impact driver incorporated into the screwdriver. Interesting.
Though, if you ever stripped out the tip, you chuck the whole thing. Most impact drivers use separate, replaceable bits. Being Craftsman people will just keep returning them and getting new ones. Until Sears figures out like 90+% are being returned. :shocking: So I wonder how these will pan out.
SuperCat
Sacramento, CA
This new screwdriver set is $30, on sale for $20, but the tips are not removable.
A Craftsman impact driver set is $25. The impact driver set has removable tips.
Easy choice. I don't understand why anyone would buy this. :dunno:
HomeTheaterMan
I agree. This seems like a gimmicky tool. If I needed a quality screw driver and was going to pay $10 a piece I'd pick up used Snap On or new Williams before even considering these. I don't see many people paying $20 for two Craftsman screw drivers.
paulsomlo
Northern Colorado
Very interesting. I just bought a Vessel #2 JIS and a PB Swiss #2 Philips, they both fit fasteners very well. The flat blade must be a special for Sears, haven't seen that on the Vessel website. Would be good for screws down in a bore, where a regular stubby bit impact might not fit, although I'd rather see a #2/#3 Philips set.
Mechanical Noise
Southeast of O'Hare
Yup.
Dimitri
Very true. The JIS drivers are good phillips drivers but not vice-versa. The only difference is the interior corners of the JIS dirvers are sharper than the more rounded interior corners of the phillips drivers.
Once I became aware of the difference, I started looking for JIS type drivers. Before that, I was using a hammer to get my Phillips drivers to work on my Japanese motorcycle.
I have a couple of impact drivers so I'll probably skip the Craftsman impact screwdrivers. But I believe the Vessel impact screwdriver has a good reputation in the motorcycle community.
Ericgst
I have a large collection of Megadora screwdrivers, including a Phillips Impacta.
These are very high end and compare well against Snapon Instinct drivers. I prefer the Vessel grips and feel they are typically less likely to cam out.
The Impacta drivers, such as these are shaped just like the non-Impacta driver and can be used interchangeably. You cannot get an Impacta flat head directly from Vessel, so I will use some point to get a set of these.
outdoorspace
I am surprised they are even bothering to stock these in stores. Both of my nearby stores had cases of the ball grip screwdrivers even after prices had bottomed on clearance at $2/pc last year.
dodge610
North Canton Ohio
Gimmicky maybe throw away possibly but i will give them a go if they save your bacon twice they are worth $10.00 in my book. Just ordered a set see if they work as per the video.
VRStrickland
^^^^^^^ Man, that is exactly where I was going. Prob not taking serious any video that uses a claw hammer in the mech shop.
gungatim
west mich
yeah, a buddy of mine collects the different craftsmans, lots of Japan and I think Canada as well...
gungatim
west mich
Kind of amazing, given their financial state, still adding new products.
given the lead time of introducing a new product, the project likely started well over a year ago and is just now making it to market. I bet the initial batch is done and there won't be any more after they sell out...just a hunch...
LB-1911
Northwestern Il.
^ I'm w/you on this one, Your hunch is a pretty good one.
4xdog
Santa Fe, NM
I have the Vessel version of that impact driver. It works, and I like it. In fact, Vessel JIS drivers have become my go-to across the board. Definitely recommended.
VRStrickland
You guys are telling me you have never used a claw hammer for anything on a vehicle?
Used an old rusty one I found one time to short a starter across. Was kinda ashamed about it later. My claw hammers do not even live in the same building as my automotive tools.
928'er
Wine Country, CA
Only when I don't mind picking metal slivers out of my eyes....
By the way, I'm not knocking Vessel drivers - I like Vessel. Just taking a poke at the clueless folks who made the Craftsman video.
scooternut
Pittsburgh, PA
So I grabbed the set, just because I wasn't certain if I had a JIS driver in my box. I reply about the JIS. I do work on motorcycles, and even my Austrian bikes have Mikuni carbs. Need to know if they are for sure JIS.
My best stuff in stock was a nice set of wiha bits, a similar Blue Point bit set, and the popular Williams set that looks like the old snap on.
My issue, I just can't tell from looking at the drivers in the bubble wrap. I don't mind the cash (cheap with points of course), but I do already have a snap on impact driver and do not need the "impact" feature. I just want a dedicated JIS.
Seems easy enough to tell out of the package, but I'd like to retain the ability to return. The sears part number is 9-86616, that doesn't seem to mate with any Vessel part number, though all Vessel "impact" screwdrivers say "cross point," which does seem to be JIS.
Any one have any non Sears hating advice to add? Thanks.
paulsomlo
Northern Colorado
There's been some contention here on the forum on whether or not true JIS screwdrivers are produced anymore. Most makers seem to manufacture to some DIN spec. I think there's more on the Vessel website and if you search "JIS" on the "Tools of Japan" thread, you'll see some discussion. Apex bits, which are well regarded here, has some bits on their website that they refer to as "Japanese Philips" http://apexbits.com/492J-CI-Apex-1-4-Japanese-Phillips-2-Hex-Power-Bits.aspx. You might try calling them, they could probably shed some light.
As an aside, I just purchased a #2 crosspoint Vessel and a #2 Philips PB Swiss. I tried each one on several fasteners on my 2001 Civic. The head of each fastener was marked with a very small cross symbol, and there was very little difference in the way the two drivers fit. In fact, the PB Swiss may have had the edge over the Vessel.
drtyler
Is this what the cross in the screw heads looked like?
