Mr_P
I found this little lamp a couple of weeks ago, and thought it was very cool. I didn't see a maker's mark on it anywhere, and today I finally found a similar lamp with a sticker barely hanging on at the bottom. Had similar qualities as mine, so I snapped a picture. Thank you research skills. It was the same manufacturer as mine. It's a drafting lamp. Without further yapping, here it is.....
My lamp...
Patents tied to this particular lamp with inventor renderings...
Nov. 16, 1954 l. 1. FlORl 2,694,535
ADJUSTABLE LOAD-CARRYING STRUCTURE Filed July e, 1950 7 Sheets-Sheet 1 111229 [.Fiorl Nov. 16, 1954 om 2,694,585
ADJUSTABLE LOAD-CARRYING STRUCTURE Filed July 6, 1950 7 Sheets- Sheet 2 Ira/era tor 37 I ruinglfiom' gigs.
Nov. 16, 1954 l. l. mom 2,694,585
ADJUSTABLE LOAD-CARRYING STRUCTURE I Filed July 6, 1950 7 Sheets-Sheet 3 in van tor ImgjglE i Nov. 16, 1954 l. FIORI ADJUSTABLE LOAD-CARRYING STRUCTURE 7 Sheets-Sheet 4 Filed July 6, 1950 Inventor Irl/LrjLHom' mlIIIII.
Nov. 16, 1954 1. FIORI 2,694,585
ADJUSTABLE LOAD-CARRYING STRUCTURE Filed July 6, 1950 7 Sheet s-Sheet 5 Inventor jruilqlfiori Nov. 16, 1954 l. FIORI 2,694,535
ADJUSTABLE LOAD-CARRYING STRUCTURE Filed July 6. 1950 7 Sheets-Sheet 7 Inventor fruirlql. F iori 2,694,585 Patented Nov. 16, 1954 ADJUSTABLE LOAD-CARRYING STRUCTURE Irving Idaco Flori, Chicago, 111., assignor to Art Specialty Co., tChicago, 111., a corporation of Illinois Application July 6, 1950, Serial No. 172,359
7 Claims. (Cl. 287-14) My invention relates to adjustable load-carrying support structures, and more in particular to such a support structure adapted to carry a fluorescent or like lamp to permit its ready adjustment to substantially any position.
In adjustable support structures of the character identitied, it is not only essential that adjustment be permitted to substantially any position, but also that such adjustment be maintained by a structure which permits a conductor to be run from a source of supply to the lamp without deleteriously affecting such conductors when the lamp is moved from position to position. In one form of structure, a single torsion spring is carried at the lowermost joint of the support structure, and the parts are so related to each other that the load as adjusted with respect to two hinged joints is counterbalanced by the single torsion spring. This structure has the advantage of leaving a substantially free opening for the conductors, but has the disadvantage that in some positions of the lamp counterbalancing is not completely effected by the single spring. In some structures, such as shown in Patent 2,233,300, an extra tube is provided solely for the purpose of passing the conductors around the two main joints which carry the counterbalancing torsion springs. In Fiori Patent 2,395,178 an improved structure was provided which permitted the conductors to pass through the two main joints, each of which was provided with a counterbalancing torsion spring, without injury to the conductors even after extensive use. While the said Fiori patent disclosed an adjustable support structure having definite advantages, it had certain drawbacks particularly when substantially the exact structure of the drawings was employed.
The principal object of the present invention is to improve the functioning of the herein identified Fiori structure while still retaining all of the desirable functional advantages thereof.
Another object is the provision of an improved structure of the Fiori type in which the friction provided at the separate joints remains unchanged even after extensive use.
Still another object is the provision of an adjustable support structure in which all of the functioning parts are completely enclosed, but in which they may be readily exposed for inspection or re-adjustment.
A further object is the provision of an adjustable support structure in which symmetry and desirable appearance may be maintained, and in which no fastening mechanism is visible when the structure is in use.
In the drawings in which a preferred embodiment of the invention is disclosed- Fig. l is a perspective view of the adjustable support structure, all of the structure above the lowermost housing member being rotated to the maximum extent in order to facilitate showing the relationship of the parts.
Fig. 2 is an enlarged fragmentary sectional view taken along the line 22 of Fig. 1 looking in the direction of the arrows, only a portion of the lamp housing being shown in section.
Fig. 3 is a bottom plan view looking along the line 3-3 of Fig. 2 in the direction of the arrows.
Fig. 4 is a transverse sectional view taken on the lin 44 of Fig. 2.
Fig. 5 is a fragmentary plan sectional view taken on the line 5-5 of Fig. 2.
Fig. 6 is an enlarged fragmentary elevational view showing the hinge joint of the adjustable load support which is nearest the lamp housing.
Fig. 7 is a view similar to Fig. 6, but with the joint housing cap removed.
8 is a sectional view taken on the line 88 of Fig. 9 is a vertical sectional view taken on the line 99 of Fig. 6.
Fig. 10 is an elevational View looking at the inside of the housing cap.
Fig. 11 is a transverse sectional view taken on the line 11l1 of Fig. 6 looking in the direction of the arrows.
Figs. 12 and 13 are perspective views from opposite sides of the ring hinge member, forming a part of the joint shown in Fig. 6.
Fig. 14 is a perspective view of a bracket hinge member forming a part of the hinge joint shown in Fig. 6.
Fig. 15 is a perspective view of a friction and swivel member used in the joint of Fig. 6.
Fig. 16 is a perspective view showing a friction spring for controlling the friction in the hinge joint shown in Fig.
Fig. 17 is an enlarged sectional view taken along the line 1717 of Fig. 1 looking in the direction of the arrows, the figure thereby being a sectional View taken through the intermediate hinge joint of the adjustable support structure.
Fig. 18 is an enlarged elevational view of the hinge joint which is shown in Fig. 17.
Fig. 19 is a view similar to that in Fig. 18, but with the housing cap removed.
Fig. 20 is an irregular sectional view taken on the line 2020 of Fig. 18 looking in the direction of the arrows.
Fig. 21 is an irregular sectional view taken on the line 2121 of Fig. 18 looking in the direction of the arrows.
Fig. 22 is a perspective view showing the housing cap forming a part of the hinge joint of Fig. 18.
Fig. 23 is a perspective view of a friction bushing forming a part of the hinge joint of Fig. 18.
Fig. 24 is a perspective View of the bracket hinge member forming a part of the hinge joint of Fig. 18.
Fig. 25 is a perspective view of the ring hinge member forming a part of the hinge joint of Fig. 18.
Fig. 26 is an enlarged sectional view, partly in elevation and partly broken away, the figure being taken generally along the line 2626 of Fig. 1.
Fig. 27 is a sectional view taken along the line 2727 of Fig. 26.
Fig. 28 is a fragmentary bottom plan view taken along the line 28-28 of Fig. 26 looking in the direction of the arrows.
Fig. 29 is a transverse sectional view taken along the line 29-29 of Fig. 26.
Fig. 30 is a sectional view taken along the line 3030 of Fig. 27.
Fig. 31 is aperspective view of the bracket hinge member forming a part of the hinge joint shown in Fig. 26.
Fig. 32 is a perspective view of the ring hinge member forming a part of such joint.
Fig. 33 is a perspective view of a friction bushing employed in the hinge joint of Fig. 26.
Figs. 34 and 35 are torsion springs employed in the intermediate and lowermost hinge joints, respectively.
Referring now to the drawings, the adjustable support structure as shown therein comprises an upper tube 36 and a lower tube 37, the said tubes being connected by a hinge joint indicated generally by the reference character 38. The upper tube 36 is in turn connected to a lamp housing 39 by a hinge joint 41, and the said lamp housing 39 is supported to swivel with respect to said hinge joint 41. Similarly the bottom tube 37 is connected to a bottom housing 42 by a hinge joint 43, and there is a swivable connection between the housing 42 and the said hinge joint 43. The housing 42 maycarry suitable mechanism such as a power unit to supply luminescent tubes (not shown) supported in the lamp housing 39. The housing 42 may comprise part of a stand, or it may be provided with clamping mechanism 44 as indicated for attachment to a drawing table or the like.
The hinge joint 41 comprises a ring hinge member 46 (Figs. 12. 13) and a bracket hinge member 47 (Fig. 14). These two members are connected by means which will .be described, and the ring hinge member is swivelably connected to the lamp housing while the bracket hinge member is swivelably connected to the upper tube.36.
My lamp...
