Why buy non impact sockets?
Chromdome35
Can you guys educate me on why someone would buy non-impact sockets? You can use impact sockets on the end of a ratchet, can't you?
If a guy were to buy 1/4, 3/8 and 1/2 impact socket sets in STD and Metric, Deep and Shallow, wouldn't that be all he needed? Why invest in non-impact sockets?
jocww
because impacts, at least mine are thicker than my chrome non impacts.
dwasifar
My understanding is that impact sockets are designed for brief, repetitive force, not sustained pressure, and can break when used as hand tools.
Finky198
North East
OMG. What would all the tool polisher's due if they didn't have any chrome? :headscrat
All of The above is correct. as well, things like impact swivels won't flex nearly as much as their chrome counterparts.... in most cases.
ADSR
I won't use 1/4 chrome sockets anymore. The impact sockets are only a tiny bit thicker. Get a nice grey or sunex set and you're laughing.
T45
Its been know since the 1930s that the "best" material for hand-tools is CrV and decent impacts are not made from it, but from another alloy. If you never use hand tools for any serious work, of course, don't buy hand tools. But impact-grade cro-mo will always be inferior to higher end CrV sockets, both in perceived feel as well as engineering characteristics.
A rule that may be made to be broken, but for many if not most/all people, the conventional wisdom is fundamentally correct.
Just my $0.02 :beer:
L.Cheapo
Some people do not need impact tools. My FIL has been an industrial maintenance man for over 30 years...doesnt own a single impact tool. He never had a need for one.
ADSR
I'm sure there is some wisdom to it. But when I'm working on something, I use whatever is closest. :lol:
ssdave
Eastern Oregon
They weigh less, are thinner, look and feel nicer to your hands, and don't rust. Other than that, impact are okay, and are best if you actually use them for impact use.
CR888
The main reason is simple. Most folks could get by with a couple of dozen sockets in 2 or 3 drive sizes but that is not many sockets. In order to fill up large tool chest draws and keep them looking bright and shiny, one must buy short, medium & deep sockets in ALL sizes both SAE and Metric in 1/4"-3/4. Then repeat the process in impact, swivel (chrome/impact), torx, etorx, hex and anything else you can find. Now instead of owning under 100 sockets you can extend this to 600-1000 sockets. Logic and need has little to do with it.
Cato
Alhambra, California
Best explaination! :thumbup:
Sockets are pretty - did you ever collect marbles when you were a boy? It's something like that.
WittHay
Surrey, BC Canada
Impact sockets sometimes break if used with a long breaker bar. When you are torquing HD components you need 12-point sockets and the chrome sockets seem to work better with torque wrenches. Also impact sockets wear out and good chrome sockets last a long time
Tonyuk
Scotland
Chrome sockets are cheaper than impacts, over here anyway.
I can get a good set of 3/8's chrome for £10 delivered, an equivalent set of impact would run £25 and up.
This is based on the impacts being proper cro-molly.
cliftonbros89
Missouri
Plus, you have to factor in size. For instance my Grey Pneumatic deepwell sockets are quite a bit longer than my chrome SK or Craftsman deepwell sockets. More clearance is more clearance.
deberly12
Lebanon County, PA
Where do people come up with this stuff:dunno:?
Engineering material properties.
Cr-mo (impact)
4140 steel
Yield strength: 95,000 psi
Elongation 17.7%
CR-V (chrome)
8650 steel
Yield strength: 99,750 psi
Elongation 14%
Strength is higher in chrome sockets but they are less elastic (more brittle) Chrome sockets will handle a higher constant force but will crack under high impact duty. Impacts are more elastic so will absorb and flex instead of cracking. But because the steel is softer (lower yeild strength) they will deform over time especially under constant force.
Sent from my XT1635-01 using Tapatalk
wolf_from_wv
WV
I turned down a set of 1/4" drive sockets in a lathe because the regular chrome sockets were too thick for the application...
visionguru
Chicago
..... they will deform over time especially under constant force.
How much constant force can you exert with hand tools? For using with a ratchet, the slight material difference doesn't seem to matter at all.
I think the main differences are probably what's obvious: size/thickness/looks/fits.
Surprised that nobody has mentioned this: I found that impact sockets only have 1 place (the hole) for the ball on the ratchet to drop in, while chrome sockets have notches on all 4 sides. On some ratchets, that could be an issue, because you may have to align the hole with the ball when putting on, not convenient.
orangeblood
Texas
Right on!
rmsg0040
Toronto
My genius impact sockets have holes on 2 sides, BTW I don't have any chrome sockets at home, impacts in 1/4, 3/8, and 1/2, never had any issues with them - clearance or breaking, hand or impact use, on the other hand my toolbag at work has chrome sockets
Finky198
North East
CR888 your post is right on. But I actually use most of mine.
I don't know put a 3' breaker bar on it and will see...I'd bet one could easily exert 500lbs with a little effort. Just because you can't see or feel the difference doesn't meant their isn't one...:lol_hitti
The other way reverse the roles and stick a chrome socket on a pro level impact for a while and see what happen usually they crack sometimes they explode...
Impacts with 1 hole are like that because they are primarily used with hog ring anvils on the end of an impact where they belong. Just because the ball doesn't line up means you can't use a socket properly on a ratchet? It will never line up on the impact either :eyecrazy:
All the ball provides when engaged is slightly more rentention force, the friction and tolerance fit is what make it work regardless.
deberly12
Lebanon County, PA
Usually true but it can make difference especially in cases where a large breaker bar is used. I work on some equipment with very large very tight fasteners. I have personally applied over 1000 ft-lbs to a bolt by hand. I have also dealt with some studs that had a torque spec of 1250 ft-lbs. We used a wrench welded into an 8 foot pipe to hold it.
marinusdees
Edgewood, Washington
I've used non-impact sockets on an impact wrench more than one. If it breaks, it breaks.
Mechanical Noise
Southeast of O'Hare
And that's why impact sockets are thicker. So they don't deform. Although I suppose the softer steel will wear a little faster on rusty fasteners.
Finky198
North East
Don't deform hahahahaha
I have some snap on impacts where the dive ends are so beat and twisted
That they won't fit on a gun and this is not from misused just normal heavy use.
driftpin
I've only scrutinized the first page of the thread, but this is one of the most-acceptable reasons I've read for the "600-1,000 sockets" collections, and the existence of 'tool polishers.'
mattygee
MA USA
If you're in the market for sockets and are one of the 'don't make me choose' types take a look at grey pneumatic's 'duo-sockets'. Good value and high quality. I've had to turn down a few on the 'belt lathe' which may make the completist/tool geeks tear up, but tools are fer usin' and occasionally modifying as need and common sense allow.
Squankum
Southeast
Dull, black impact sockets are a lot less likely to be flown away in the beak of a raven. I think that settles it. Well, if you have crow and raven problems.
stercorarius
Eastern Washington
All impact sockets will eventually deform with use on an impact tool. Proto even designs their retaining pins to show you when a socket has deformed too far. It's very visible on one inch drive sockets. Even on my 18mm 1/2" drive it's fairly apparent after only a few months. Will they deform work use when used only on hand tools? Probably will take a lot longer, but if it's just used on hand tools then why but impact grade?
Honestly though, if it's just for a homeowner/diyer you'll be fine with just buying impact sockets. I use my impact sockets on ratchets all the time.
Sent from my S60 using Tapatalk
