toplessHO
so friend says its gone thru 2 replacement motors.
I havent had a chance to check anything out but
did get a pic of data plate.
HP is labeled "spl" which in my book is termed "special" or "BS".
too much of this misleading info out there,so you can sell a 3.3HP
compressor as a 7.5 HP one.
I suspect others have had this same problem .
So rather than declare my self insane by replacing it with the same motor
Im looking at larger replacements.
Surplus Center has a couple 56 frame 5 HP ones but would need to replace
the drive pulley as the replacement motor is only 5/8 shaft instead of 3/4.
For comparison Ive taken a data plate pic of the "smaller" Devilbis which is closer to a real compressor.
, even though some places at the end of a long service with heavy loads, actual voltage will be close to 225 or so.
