William Caves
- Joined
- Jul 18, 2017
- Messages
- 10
Hello,
First time posting and any help would be appreciated. New to air compressors but recently purchased one from Craigslist. 60 gallon 5HP single phase 240v 22AMP. Model US560V. For home use. This is one relatively similar (or identical, except that one is two stage) to the Harbor Freight model that comes up when you google the model number and also a BelAire linked here
https://www.mastertoolrepair.com/stationary-air-compressor-parts-218v-p-20126.html .
When I purchased it (for very cheap) it didn't run and I tested the capacitor and it was out of spec. Replaced the capacitor and it runs but it turns itself off and smokes a bit after about 20 seconds on. Have it ran to a dryer plug that is Nema 10-30 rated at 30 amps and 125-250 volts on a 30amp breaker and this is the only outlet on the circuit. I know this is not up to code as a compressor legally needs a ground and I only have a neutral (almost hoping that is my problem). I intend on using the compressor rather rarely and only having it plugged in while using it and under supervision as my dryer needs to be plugged in often. After scouring the internet it seems as this is a "workable" method, but not the safest. I am not sure if I am doing something wrong or if the motor is bad. I have tried it disconnected from the pump pulley as well as connected. I have tested the leads and the two power leads test at 120 volts. It does not build pressure it seems during the 20 second run cycle but it does turn. I feel like I must have configured it wrong electrically or something. Also, I believe that the pressure switch was changed (looks extremely new) and it seems to not resemble OEM and is rated at 20 amps, which is obviously lower than the 22 amp draw from the motor. Some pictures attached of the wiring and motor documentation. Any help would be greatly appreciated. Thank you.
), guess I am done pursuing this motor. Win some - lose some! Thank you for the guidance and eliminating some doubts at certain steps along the way!
