OH_Varmntr
The survey is done and I'm all set to begin. But before we break ground I'm going to clean my front yard up a bit by having my current overhead 25kva service primary buried. Before my house was built there sat a trailer in my front yard and it was fed via this overhead service. When the house was built they buried a new feeder to the meter on the house.
This was years before I bought the house and now that we are building a pole barn I wanted the front yard nice and open for the kids to play in while dad is in the shop. It would also be nice for when the adults get to playing whiffleball and football.
So here's the current service setup. As you can see it really takes away from the view. The transformer pole and the pole near the road will be removed and an underground primary will be buried nearly 325' from the road pole to a pad mounted transformer. You can see the survey stakes in the background as well as the pink flags marking the proposed layout of the shop. Most of the front yard is utilized by the two septic leech beds that are required around here so I barely have enough room to squeeze a 48' wide building in there.
Untitled by B.Shuman, on Flickr
The power company marked the current house service entrance but I can't drill my post holes for the new meter base until the ticket for the call before you dig service is fulfilled on Monday. Good thing to do it as you can see here it's anything but a straight buried line.
Here's the 400 amp meter base structure I built. The posts are 4x6 ground contact rated with GC rated 2x8 crossties up top to mount my enclosures to and a GC rated 2x6 across the bottom to secure my conduit to. Expansion joints will be utilized in all the conduits except for the grounding conductor. It will be used to mount the meter base as well as 2 individual 200 amp feed through lug breaker panels. One to act as a service disconnect for the house and the other for the future shop. These are outdoor Nema 3R rated panels. My current house underground service will be tied to one of the panels so I don't have to re-feed the house. Our current meter is on the house so the POCO will jump and blank the existing meter and utilize only the 400 amp meter base I'll be installing.
We're getting hit with some rain from a thunderhead rolling by so I'm taking a break from building the panels at this time. Since the survey has been completed it should only be a few weeks until my builder gets started with things.
I started another thread with some proposed layouts and thanks to some suggestions from here this is what I'm shooting for.
More to come!
Untitled by B.Shuman, on FlickrThe power company marked the current house service entrance but I can't drill my post holes for the new meter base until the ticket for the call before you dig service is fulfilled on Monday. Good thing to do it as you can see here it's anything but a straight buried line.
Untitled by B.Shuman, on FlickrHere's the 400 amp meter base structure I built. The posts are 4x6 ground contact rated with GC rated 2x8 crossties up top to mount my enclosures to and a GC rated 2x6 across the bottom to secure my conduit to. Expansion joints will be utilized in all the conduits except for the grounding conductor. It will be used to mount the meter base as well as 2 individual 200 amp feed through lug breaker panels. One to act as a service disconnect for the house and the other for the future shop. These are outdoor Nema 3R rated panels. My current house underground service will be tied to one of the panels so I don't have to re-feed the house. Our current meter is on the house so the POCO will jump and blank the existing meter and utilize only the 400 amp meter base I'll be installing.
Untitled by B.Shuman, on FlickrWe're getting hit with some rain from a thunderhead rolling by so I'm taking a break from building the panels at this time. Since the survey has been completed it should only be a few weeks until my builder gets started with things.
More to come!
