FurnitureGuy
- Joined
- Aug 9, 2017
- Messages
- 16
Should have posted in the VISE thread....???
And we cant get the scale with your tape measure, no where can we see the actual size in inches?
OK that is a really weird one. I'm trying to figure out if the front jaw is supposed to be fastened to the long rail. Does the rear large threads turn? The lever in the back makes me think this may have had some kind of quick release.
Hmm that's great... is your version in working order? Does it have that bullet/release lever on the back? I'm wondering about the large screw now, does yours spin?
JimNC, sounds like you are talking about the Backus Vise patent no US 78565 patented June 2nd, 1968. Again similar but not quite the same.
Yep what he said��
You're a furniture guy, do a furniture thang.
That's a Craftsman metal lathe with a wood chisel accessory. I think it's fifty inches long.
It's worth its weight in weight, but it's perfect for what it does now. No damage was done to the lathe.
I'd give fifty bucks to make your vise into a book rack...I'd give nothing for it as a vise.
As a furniture guy you should know it's 250 easy bucks as a book rack in the right store. That probably means $125 to you for about four hours labor, plus the time to place it, you're at ten bucks an hour.
Make something for yourself (like the table you considered) and honor those that aren't around anymore if they are worth honor.
I'm a designer / Web SEO / Business Process Automation guy who's always had a passion for furniture, salvage, re purposing etc... I'm only now finally starting to do something with furniture.JimNC, sounds like you are talking about the Backus Vise patent no US 78565 patented June 2nd, 1968. Again similar but not quite the same.
