Yorktown Tool Roll by Atlas 46
Fedwrench
Valley of the sun
I have one and I'm slightly disappointed with it for one reason, it lacks a separate carrying handle when rolled up. It has thinner nylon strap loops at both ends for hanging, additional straps to secure it to a seat back (but then you can't access the wrenches/tools on the back side) with d rings.you can leave one or two of the nylon loop straps out and carry the roll by it but, it then pulls at the corners of the flap.You could also carry it by the securing strap but, you have to leave it loose for your fingers to fit in. I like to be able to roll it tightly in case I have something long like a 1/2 inch drive breaker bar in the middle.
The roll itself it outstandingly well made!!! All components are extremely high quality from the zippers, to the nylon, to the buckles & hardware everything is great. The pouches are outstanding. They will easily hold 1/4 & 3/8 socket rails, pliers, screwdrivers, etc. If you get the version with the wrench slots on the back size, they aren't made for long pattern wrenches so, anything longer than a Tekton series won't fit. It is a bulletproof tool roll. I doubt if there is a better designed tool roll out there. You can easily the military gear connection to its quality but, they missed the mark a bit to me without a separate heavy duty carrying handle on the back side. :beer:
