My floor option HD40
Toomanytools?
Washington
Ok thought I would post a bit about the shop floor. I have two spaces one side is about 2000 sqft for RV storage and a place to do metal work, the other about 1000 sqft for a wood working shop.
I after much research went with Legacy Industrials product HD37 and HD40 densifiers on the RV side.
1) Started by prepping the shop floor 2,016 sqft of power troweled concrete.
First thing was swept up the big stuff, cleaned and vacuumed the saw cuts out blew out the dust with a leaf blower. Next I sprayed a diluted mix of Simple Green working in sections scrubbed floor with a broom, rinsed off with water and squeegeed out as much as I could.
2) Let it dry overnight then applied HD37 with cheapo garden sprayer and a microfiber pad from Lowes $6. Had 5 gallons and did 3 coats, pretty easy spray a section (saw cut to saw cut) about 4' out work in with pad, spray next and repeat. Took me 1 hour for each coat, by the time I was done with one started the next coat.
3) I think it's recommended to let the densifier sit for 7 days, I couldn't wait so at day 5 started the HD40. Same process spray on a workable section and work in with pad, went through a total of 3 microfiber pads on the HD37 and HD40. I had 6 gallons actually bought a 5 gallon and a 1 gallon, I did 3 coats and still had about 1 gallon of the 5'er left. I let it dry overnight then applied a 4th coat in the morning let it dry for about 3 hours. Took about the same 1 hour to apply but I let it dry for 1 hour after I finished to start the next coat.
4) After drying for 3 hours I had rented a burnisher (1500rpm) and had the Hogs hair pads from Scotty.
This is when the fun starts my concrete is pretty smooth but had some rough spots from the power trowel I think it was too dry. I started the buffing (burnish) and used a laser temp gauge to see how hot the surface was. Started about 68-70 got up to 80 easy enough but trying to hit 90* recommended temp for HD40 to set in was a pain. I had to hold the buffer in one spot for like a minute or longer to get 90-95*, so at that rate it was going to take days. After about 30 minutes I scoured the internet trying to find another burnisher, nobody had anything over 1700rpm the next thing was a propane unit that heats up the surface and spins at 2000.
So back at it I went, it took a long time ( I'm not a patient guy) it did not get to 90 everywhere, but it did start to get some gloss to it. I would really like to burnish it more but can't find a better machine in my area. Overall looks good has an almost wax like feel to it and water beads up great. I think for what I'm going to do it will repel the minor oil and gas spills. I think with a few supplies and rental I'm in about $850 which is great for 2000 square I didn't want to spend $3000 on the floor.
For the woodshop I'm thinking faux wood floor, acid or dye stain and poly top coat or a metal epoxy haven't decided.
Here are some pictures, I also filled the saw cuts first with foam backer rod then with SikaFlex Self Leveling Sealant Polyurethane. I found it was easiest and less mess to tape the saw cut using a caulk gun then level off the excess with a putty knife. Let it dry for 5-10min still wet pulled tape off and it found its own level.
Thanks to Scotty for all the help, he is a man of few words but helpful.
BIG-BRO
New Hampshire
THANKS for posting your detailed experience !
Earlier this week I ordered up the same set of materials for my 2000 sq ft new garage here in New Hampshire.
(Waiting to hear back from Legacy on shipping......)
I'll keep looking for faster burnisher, but they all seem to be 1500-1600 RPM
T
Toomanytools?
Washington
Hey hope my description helps a bit , it was easy not like doing an epoxy. I did the whole thing by myself, I should have had a helper spray as I worked in the product but I couldn't wait.
The burnisher I had spun fast without load but as you set it down it would slow up, hopefully you have better luck.
LegacyIndustrial
deerfield, IL
On a truck today Big Bro!
BIG-BRO
New Hampshire
Thanks for the follow-up Scotty ! ( And TooManyTools ! )
Burnisher rental options that I can find jump from 1600 RPM up to one choice at 5400 RPM ! Would that be too fast for the hogs hair burnishing pad ?
T
Toomanytools?
Washington
Wow never seen one at 5400 RPM (hang on). Some commercial ones list engine speed as 3600 + then pad speed as 1600rpm. Might see what Scotty says, go big or go home!!
BIG-BRO
New Hampshire
HD37 bold print in product description says to use full-strength on old or soft concrete, so I was assuming that meant diluted on new??
Did you use the 5 gallons full strength on your 2000 sq ft and get the three coats? Or was that diluted per instructions ?
HD37 instructions (download) on Legacy website says dilute it with three parts water.
HD37 container (received today ! Yay! But I guess one more day for applicator material) says "one component product"
Krzewinskibe
Northeastern Maryland
Question, the site says 400sqft/gal coverage for the HD40. Is that per coat or overall finish? Original poster stated they bought 6 for their 2000sqft building so I'm assuming the latter.
Thanks!
T
Toomanytools?
Washington
I did 3 coats on the HD37 and that did the 2000 sq used full strength, I was also confused by the instructions to dilute,so followed Scotty's advice.
T
Toomanytools?
Washington
Thanks!
I didn't think 5 gallons would be enough even after Scotty assured me it would :lol_hitti so I ordered another 1 gallon. I had plenty of product did 4 coats, only on the last 200 sq looked like I would run out so added maybe 2 cups water to about 2-3 cups of HD40 to spray the last 4th coat.
Depends on the porosity of the concrete but results should be similar.
To clarify used 5 gallons still have the unopened 1 gallon.
T
Toomanytools?
Washington
Looks great! Any other plans for the floor or is this how you plan to leave it?
Hey thanks, I'm going to put a floor polish on it (gloss) helps keep the sealer gloss on it longer, Legacy sells a "Cherry Wax" which is just a Water-based acrylic & wax co-polymer. But I think I can find something local and a bit cheaper.
This is just vehicles and metal work area, the other section is smaller I think I may try a dye or metallic epoxy on the floor.
BIG-BRO
New Hampshire
I'll tack this on here since my application is very similar. On my 2000 sq ft the 5 gallons of HD37 did just ONE coat (as we started and saw how much it was using to spread one even coat, we marked the sprayer bottle in 1/3 gallon increments since I have 15 "squares" defined by the saw cuts). The 5 gallons of HD40 did three coats today, about an hour in between, and three hours after last started with the burnisher. Picture shows result. (No matter how I edit, the iPhone seems to put the sideways pics) . Later I will be doing the Legacy Cherry Wax, and then the backer rod and SikaFlex in the saw cuts.
PurdueSD
Indiana
Is their a time window that the floor needs burnished in after HD40? Do i need to line up a rental or is it something i can do a couple days/ week after the application?
T
Toomanytools?
Washington
I think somewhere I read within 24 hours, not sure, ask Scotty @ Legacy. I think if you put it on Thursday and burnished it on Saturday morning you would be ok.
