It's finally done...30x40x14 in UT
clanure
Clinton, UT
Hi everybody!
Been lurking on here for years, learning what I can, but now it's time to throw my hat in the ring.
Well, it took longer than I ever thought it would, but it is finally done. My dream shop (30x40x14) has been erected. I signed papers with the contractor in May 2017 and he finished up with his part at the end of August. There were a few delays along the way, but all in all the contractor was awesome.
Anyways, it will be a multi-purpose shop, once I get the floor finished and the Lighting/Electrical done. I've got quite a few questions on those fronts, so I plan to be quite a bit more active on here.
So, on with the pics.
Floor is power-troweled 6" slab for future lift. I've got HD37 and HD40 on the way (hopefully) from Legacy Industrial.
It's fully insulated, including the roll-up door, and I'll add HVAC (mini-split?) in the near future.
And, just because, one of the future occupants of the new shop:
So, my first question is; where do I ask questions? I have so many, on so many different topics now, that I don't want to seem like a pita with so many questions in all the different sub-sections. Is there a proper GJ etiquette?
Thanks in Advance,
Lynn
tdott
South FL / Toronto
Welcome!
Looks like a great start! What are your future plans other than the lift? What type of work will you be doing in there?
arkieguide
Ask away - but we will need purpose of shop ? what will you use it for ? Have welding machine, air compressor, auto lift, table saw, grinders etc. That is what makes a difference in wiring and lighting.Good luck.
rburke65
Canfield, Ohio
Welcome to The Garage Journal, from Ohio! If you have an electrical question you ask it in the ...Electrical section....Flooring...yes in the Flooring section. You just start a new thread, a heading and start the question. Good luck.
Todd.Brock
Cincinnati
Welcome! Ask away, but be sure to use the search function. You may learn the answer to your question and get lost in some fascinating topics along the way ! Good luck with the new shop space!
