sicklyscott
- Joined
- Dec 29, 2009
- Messages
- 131
Hey All -
I know what the "right" thing to do here is but I'd rather a band-aid fix and would love your opinions. I have a 22x11 garage in NJ with no insulation, 7 ft. walls and a roof peak of maybe 4 ft above that. The garage is wired with a 20 amp 120v line, no gas or water running to it. I'd like to spend some time in it over the winter to tinker with my project car.
The RIGHT thing to do (short of rebuilding) is to insulate, run better electric and put in an electric heater that can sustain 50 degrees when I'm in it. That's too much time / effort as that means a new main panel for the house, maybe upgraded service, and rewiring in the garage.
The band-aid fix would be a propane heater that I can use with a 20 lb tank. I've seen those alien glowing eye infrared things you can run off of the tank, not sure if that is useful in such close quarters. Another option is something I found on McMaster Carr's site that would be the appropriate size for my garage (40k btu) that uses 2 lbs/hr. It is expensive but will it work? And in your opinion would the added humidity be a problem in the winter?
As a side note one of the biggest problems with working on a car in the cold is that your tools are all frigid. I was thinking of wrapping my tool chest in the under tile heating mats, figured if I could keep the tool chest and tools warm it might not be so bad to work.
Looking for helpful suggestions!
