Unidentified (& maybe OOAK) Pressed Steel Era Extension
I recently acquired an early (1910-1922 era) pressed steel socket wrench set with 11/16-inch external and 1/2-inch internal square drive sockets and a mix of internal and external square drive tools. More to come on the set itself, which I am still in the process of spec'ing and sorting out, prompting a number of different research deep dives.
One of those deep dives concerns this extension.
View media item 77177
It's OOAK in construction and branding, with no other known examples in the vintage hand tools websphere, as far as I have been able to find or determine, so far.
It's 7 inches long. Steel. Finished, like the set, in some kind of black rust-proofing. The smaller end with the friction ball is 1/2-inch O.D., to drive the sockets from the inside. The larger end is 11/16-inch O.D., to fit inside the 11/16-inch female drive opening in the ratchet like a drive plug. I'm not sure, but it almost looks like the 11/16-inch drive stud was hot-crimped onto the end of the shank. It's not forged. Looking for thoughts on this.
View media item 77179
It's similar to the approach Walden took on their early pressed steel socket drive tool extensions, which came in different lengths. But the large end on the Walden extensions were female, and drove the sockets from the outside of the socket base. Here is a 10-inch for comparison.
It's also similar to the approach taken by Mossberg in the No. 1 Auto-Cle set in the sense of using a 1/2-inch square bar stock. But it was 1/2-inch on both ends. Here is that extension for comparison.
And it's very similar to the approach taken by Mossberg on the later No. 351 extension in the sense that one end was 1/2-inch (for internal socket drive) and the other end 11/16-inch (internal ratchet drive). But the Mossberg 351 was made from thick steel tubing swaged into a square on the big end and pinched around a solid 1/2-inch drive stud on the smaller end.
Here is an example...
Moving on to the really fun stuff, here is a close-up of the brand and model number marking.
View media item 77178
As I mentioned above, I can’t find another example of this monograph style logo anywhere in the hand tools websphere, and that includes Alloy Artifacts.
My first thought - and after careful further study and analysis, it's now my conclusive theory - is that the "boxed MW fraction" logo (for wont of a better economical and descriptive term) signifies the Mossberg Wrench Company.
Here's my rationale:
- Note that the pronounced serifs in the "M" (and the "W" - which is a mirror image of the "M") are very reminiscent of the serifs in the "M" in many examples of the Frank Mossberg Company so-called "M-Diamond" logo. That could be a coincidence, but a crazy one, if so.
- Note also that the Frank Mossberg Company demonstrated a propensity for the same marking scheme, with a pair of logos bracketing a model number, like this: "< M > model number < M >".
Here are some examples from AA:
- Note that the Mossberg No. 351 extension bears a very similar model number. Not uncommon for mfgrs to do that for tools in different lines or those made by subsidiaries.
- Note that the ratchet in the set is a ratchet made by Mossberg but marked "W. & M. Co.". (This is a whole 'nother subject and thread topic that I am not prepared to introduce yet, but AA has one if you want to see an image.)
- Lastly, through process of elimination - what else could a "boxed MW fraction" logo reasonably stand for?
It's not Walden. And it doesn't belong to any of the smaller enterprises making pressed steel socket wrench sets in that era (Syracuse, Charles Miller, and King).
EDIT: It's not Montgomery Ward. They had an MW logo, briefly, but much later.
If you're not read up on Mossberg stuff, Frank Mossberg was in business as early as 1894 as the Frank Mossberg Company, although he didn’t trademark the M-Diamond logo until June 27, 1905. He trademarked the name "Mossberg Wrench Company" a year later, on June 12, 1906, several of his early patents (bicycle wrenches) were assigned to it, and it continued to show up as a separate business entity in legal gazettes "until at least 1915 or so," per AA. But the exact nature of the relationship between the two companies is strange and not known. Most pertinent to this thread, no hand tools have been found that are marked with the name "Mossberg Wrench Company" or a logo indicating the Mossberg Wrench Company as opposed to the M-Diamond logo indicating Frank Mossberg Company, as far as I have been able to tell.
Until now, that is, perhaps.
It stands to reason, in my opinion, that Frank was using the Mossberg Wrench Company to fulfill orders, and maybe especially for the pieces in the 3rd party pressed steel socket wrench sets he was making for re-badging by others (e.g., Sears & Roebuck Aristocrat No. 1). Perhaps other pieces were marked with this "boxed MW fraction" logo and they just haven’t been recovered.
Also - and I should've said this earlier... If anyone has a tool with this marking, or knows of a tool in another collection with this marking, please post it. It's possible that it's out there somewhere even though no examples show up on AA, Etsy, Worthpoint, etc.
Anybody have any other ideas or theories?
All comments welcome.
twertsy
Reedville, VA
And it's very similar to the approach taken by Mossberg on the later No. 351 extension in the sense that one end was 1/2-inch (for internal socket drive) and the other end 11/16-inch (for external socket drive, or internal ratchet drive). But the Mossberg 351 was made from thick steel tubing swaged into a square on the big end and pinched around a solid 1/2-inch drive stud on the smaller end.
This will be fun!
I don't really think that it is Mossberg Wrench. In my American Wrench Makers 1830 - 1930 book, the Mossberg Wrench examples seemed to not have any logo.
P
Thanks, Don. If you mean "Mossberg Wrench Company wrench" (as opposed to Frank Mossberg Company wrench), I realize that. Or at least, that's what I gathered from AA, which cites that very book and various old journals and gazettes etc for their sources. Hence, this...
Still, MW logo with a "351" model number, similar to a "851" model number for the same tool, found in a set with the same number and types of pieces as Mossberg Set No. 11, with a ratchet made by Mossberg, in an era when there weren't very many mfgrs making pressed steel socket wrench sets, it's a very compelling (EDIT: and too obvious to ignore) theory.
I would gladly be disabused of it with an equally compelling alternative!
And, if there is one, I have to say, it's going to have to be one humdinger of a koinkydink! :)
P
Don,
Are there are any Mossberg Wrench Company drive tools in the book? Are there any Frank Mossberg Company drive tools in the book? Are there any extensions - regardless of mfgr - that look like this one?
Not that I saw and I went all the way through the "M" manufacturers. Every Mossberg after the turn of the century had the M in a diamond like the examples you posted. I didn't see any other likely contenders either.
P
Guys,
Quick update: I found a photo of an identical extension online, marked in an identical format, but with a different though similar pair of logos. Not going to say where just yet, or name the brand of the set. Suffice it to say, for now, that it's not a Mossberg branded set. But, the pressed steel sockets in the set were made by Mossberg, and marked with the < M > logo. And the ratchet in the set, though branded with the set name, was also cleartly made by Mossberg. And I believe the extension, though branded with the contract brand, was also made by Mossberg.
I am now 99.9% positive this M/W-box extension I have was made by Mossberg Wrench Company. I also think, boldly, that it's a "missing link." A Lucy for tool archeology.
If you're familiar with AA's pressed steel socket set era collection, you know that a lot of the sets in their collection, regardless of brand, were found with a few or sometimes a complete range of Mossberg marked sockets. AA has postulated for years that these sockets were owner replacements, due to the fragility of pressed steel sockets, and the prolificness of Mossberg's production in the market.
I don't think that's the case. I think Mossberg was supplying sockets and drive tools, sometimes unmarked, sometimes marked with the contract brand, and sometimes marked Mossberg, to a number of rebadgers and resellers previously not attributed or credited to Mossberg by Copes or AA or anyone else.
EDIT: Much more on this soon.
P
As I alluded to above, I found what appeared to me to be the same extension as my mystery extension online, on Alloy Artifacts, to be precise, in the Syracuse Wrench Company section.
So I went on a little research acquisition binge, prompted by my mystery extension and its twin. Or more rightly said, its first cousin. So I could inspect and spec one out in more detail, in person.
To wit, here is Syracuse Wrench Set No. 10.
View media item 77659
You can see the extension in the well under the ratchet. And here it is next to my extension.
View media item 77660
As you can see, they are identical in every detail, including the way the 11/16” male drive end (for the female ratchet drive) is hot-crimped onto the end of the 1/2” stock square rod. The only difference, if it can even be called that given the similarities, is the marking. S/W (for ‘Syracuse Wrench’ Company) in a hexagon versus M/W (for what I still maintain is ‘Mossberg Wrench’ Company) in a rounded box.
View media item 77661
One might come to the conclusion that Syracuse made my extension. If so, why would it be marked ‘M/W’ in a Triumph Specialty Company socket set? Staying with the Syracuse connection, one might make the conclusion that M/W stands for Miller Wrench, alluding to the company that Syracuse seems to have mimicked, at the very least, for its first generation production tools. Not a bad thought. The problem with that theory is that none of inventor Charles Miller’s two manufacturing companies were named Miller Wrench. They were named Miller Combination Tool Company and Charles Miller Company. The bigger problem is that this Syracuse socket set is from their third generation, in the early 1920’s, just before they dissolved, when they were merely re-badging tools made by – you guessed it, Mossberg.
Look again at the ratchet in the Syracuse set. It’s identical to Mossberg ratchet No. 355.
As I mentioned above, many of the sockets in this Syracuse set were also marked with the Mossberg brand. The sockets in the Syracuse set AA owns also had a lot of Mossberg sockets in it. AA considers them to be replacements. With a ratchet made by Mossberg, an identical extension to an extension marked “M/W” and found along with a Mossberg ratchet in a Triumph Socket Set explicitly advertised as Mossberg made, I think AA has underestimated the pervasiveness of Mossberg’s contract production for others, which they limit to Sears & Roebuck.
I’ll be posting much more on this “M/W in a box” extension, the mystery “W. & M. Co.” ratchet, and the Triumph Socket Set No. R7 they were found in, as well as Syracuse and their sets here and much more over at the Tool Archives soon. I just wanted to post a quick update.
P
I found this primitive early heavy duty pressed steel type wrench this morning looking very Mossbergy and bearing the same mysterious [M/W] logo as the extension above, or in this case, [W/M]. I still have not come to definitive grips with this "company" (if it is indeed different though related to Mossberg), but finding a DOE wrench now expands the types of tools to the other types of tools that Mossberg was making and putting in its largest socket sets.
