mattlikesbikes
Last fall my wife and I bought our first house. A fairly new (2001) 3/2.5 brick house with a built in two car garage. The previous owners had a large boat and extended the driveway to provide parking for the boat and the truck to pull it. The extra slab is nice since we've got 3 cars and a motorcycle. So parking everything in the built in garage is a bit tight. The built in also lacks the space around the car to do anything but park and get out.
So I've been authorized by the wife to build a stand alone garage on the extended slab. It's not a huge space, but with careful planning it should be more than sufficient. The additional garage will house my classic car ('68 Volvo 220) a small shop, and a second floor storage/office/library/man space. The other two cars and the motorcycle will fit in the main garage.
To fit with the design of the house I decided an offset ridgeline would be best. It also gave me a nice airy second floor.
The windows in the back corner will be larger and the ladder/steps to the second floor will probably be moved to the other end of the garage to allow me to have a desk that over looks our backyard/creek.
The size is a bit small, 24x19. The 18 will be pushed out another foot so that the inside is 18, despite what the design says right now. There is no more space to spread out, so the foot print is locked in.
I thought I would build it as a first floor, 18x24x10 building, then add in the second floor portion(hoping I can just do two supports for the 24ft open edge). Then I figured I would build the three walls around the second floor. From there I set the ridgeline and set in the rafters, fill in the walls over the one story portion, and then dry it out. Sounds easy enough right...
so here is where I need help. Look at what I've got and provide any constructive criticism. Any suggestions would rock. Any insight regarding the floor of the second floor, the ridgeline, materials would rock.
