Crete Heat
crook038
South Eastern MA
If anyone is thinking of using Crete Heat Panels, I would recommend them. I'm building a 42X48 post beam garage with radiant floor heat and just finished laying down the panels. For a person working alone you can not beat the simplicity of the system. I know there are far less expensive options out there but I didn't want to waste time and money so this was my best option. I will update this post once I lay down the pex.
Sean
C
crook038
South Eastern MA
I guess I never completed the initial post. I was able to bend up the rebar hairpins and install them in the posts yesterday. I also installed 1/3 of the pex tubing. The panels make this process incredibly easy for 1 person to complete the pex installation. I built my on pex in-coiler for less than $10 in parts and it has worked great. Here are some more pictures.
Sean
C
crook038
South Eastern MA
A couple of pictures of the manifold installation.
Sean
Chris705
The Finger Lakes of NY
Sean - creteheat product looks interesting. I have never seen the hair pins you installed except for steel framed buildings, what is the thought on what they do and why install them for a post frame building?
C
crook038
South Eastern MA
The hairpins are used to tie the posts into the slab. This helps prevent uplift as well as movement and separation between the posts and the slab. I finished the pex manifold installation today and pressurized the lines. I also began to lay down the wire reinforcement mesh.
Sean
joes169
WI
I first saw this foam system about 15 years ago at a ready mix supplier, but I can honestly say I've never seen it installed. Nice work so far!
bottom feeder
Utah
I watched a rerun of a recent This Old House episode and they used these. Didn't say what they cost though. May I ask you a ballpark figure on what they cost? Are they priced in a package of "X" sheets per package? As I recall they were 2ft x 4ft?
C
crook038
South Eastern MA
They come in a package of 8. Each 4x2 Panel was $11.95. I used 252 panels for my 42X48 building. Not cheap but easy to use. I finished the pex install as well as the welded wire mat and hope to have the floor poured soon.
86turbodsl
$3000!!!! Wow! No wonder i didn't look at this when i did mine. At least you got some insulation out of it. Looks good though.
rburke65
Canfield, Ohio
$3K!!!! I can buy lots of tie wraps for $3,000. Lots of money left over for insulation and/or concrete. But....different strokes for different folks.
bottom feeder
Utah
Thank you for the info!
