Vintage knurled sockets with 1/2 inch hex drive.
alton1911
I was doing my usual digging through tons of sockets and wrenches today and found a set of unmarked sockets they are dark colored, I do not believe they were ever chromed... and I had rounded up about ten of them in imperial sizes.
They were marked only with size indications. The 1/2 had a 12 point side and a hex drive. Both sides fit snugly on a 1/2 bolt head. I have heard of hex drives in 7/16 but never seen them in 1/2.
I guess this is my new guy question of the day. If anyone has an idea about these, I would appreciate the info.
I like the sockets with knurled bottom edges, and I usually buy what I like but in this case. I just don't have enough storage for a bunch of sockets I will never visit again.
Thanks in advance for any info.
alton1911
could be one or many of several different brands. 1/2" hex drive sockets were actually fairly common. the early ones were carbon steel and weren't plated.
really need to see a photo image in order to make a best guess.
in the meantime, take a look HERE:
http://alloy-artifacts.org/newbritain-nonebetter.html#carbon
and HERE:
http://alloy-artifacts.org/duro-indestro-p3.html#early-sets
and see if something looks familiar.
stars on either side of the size stamping, or trapezoid shapes on either side of the size stamping = Duro / Indestro.
if you've got an "ELL" wrench (looks like a hex key) that goes with them, or a holder, see if it's got a patent number, patent date, or maker's name stamped on it.
again, could be any one of several different brands.
A
alton1911
Wow. A lot of tools I am seeing are going to be easier to identify. I have found some BOG sockets also. Thank you so much. I will try to add pics.
A
alton1911
I have sorted through about 1,000 lbs. of sockets in the last couple of days. I have found a total of 13 of the 1/2 hex sockets. After looking at almost as many pounds of large hex wrenches I was unable to find a original handle. The best I can tell, I have parts of as many as 4 different sets. The knurling along the bottom is fantastic, on some and and on others its just scored lines. I am hooked.
Here are some pictures of some hex drive sockets and a holder IDed as Duro/Indestro by the patent number on the holder. The ratchet no longer works properly, unfortunately.
another example of early Indestro:
Indestro 3.8 hex drive socket set 01 possibly 2104.jpg Indestro 3.8 hex drive socket set 02 possibly 2104.jpg
d42jeep's example above has a different type of knurling than my set.
Sears "Dunlap" line used a knurling pattern similar to d42jeep's example above.
edit 01/13/18:
this is a model 2104, but it is not marked with either part number or patent number.
the "Pat Pend" refers to patent 2065340 / Applied: Oct. 05, 1935 /Granted: Dec. 22, 1936
(see also patent 2065341)
jim keris
snap on made hex drive ratchets I have a couple from my fathers tool box
damon18
Memphis, TN
Any chance of identifying these? No markings at all that I can make out, not even sizes. knurled hex drive shallow 1/2 drive (if I measure correctly, they are 1/2 to the points on the hex drive and about 7/16 from flat to flat.
