Bought myself a cool old lathe
Unruh
Silverdale, Washington
Recently I bought a Delta Rockwell bandsaw, the guy I bought it from texted me and let me know he was thinking of selling his lathe as well. I’ve always wanted on and I love learning new skills, so of course I jumped on it. I got it for $75. Looks like it will that a little elbow grease, but should shine up nice. I’m planning on making a different stand for it. Any tips for a first timer?
That looks like a deal for 75$. Stand looks ok, as long as it is not shaky...
drivesitfar
UNRUH: now that you own it i'm sure you'll see more stands and better ways to set it up to use. think SAFETY before turning on the motor to work on things cause wood flying around can cause you some grief if not secured or using the proper safety gear. full face mask and probably fairly heavy clothing until you get a good knack for what it can do.
i haven't used a lathe for maybe close to 50 years now, but my dad asked me 10 years ago to come pick up his Shopsmith anytime i wanted to cause it's mine so i'll be joining you and making chips some day too.
did you get any chisels or tools?
U
Unruh
Good idea with the full face mask. I alsways were glasses, but can't be too careful.
It did come with a good set of tools. The previous owners said they were middle of the road, but good enough to get me started. I'll watch some YouTube videos for some basics skills.
Here is the kind of stand I was thinking of. It is even pretty much the same lathe!!
drivesitfar
Unruh: i like that table and i actually owned one similar that i had to let go for lack of space a few months ago that also might have been perfect. here's a picture of it and it had a little Dunlap wood vise attached which might have been older than your lathe is. i think the dimensions of my little wood bench were 48 inches wide and 21 inches deep and about 32 or so inches tall.
also after you use the chisels to get the rough shape you can use sandpaper to really put a nice finish on your project, but make sure you use a dust mask under your full face shield cause that fine dust won't do you any good in your lungs.
cheers
ProGun3400
Will County, Illinois
UNRUH:think SAFETY before turning on the motor to work on things cause wood flying around can cause you some grief if not secured
I'll second that. I recall a high school (1970's) wood shop class assignment (a table lamp) starting with and turning down a 4x4. I witnessed a few fellow students leave class via a stretcher due to poor centering & improperly secured material spinning between centers. One guy was knocked out cold. Back then, we wore goggles, which did little in preventing a few baseball sized knots on foreheads. Another caveat, no unbuttoned/loose hanging sleeves, etc around or near spinning machinery. Young men sporting ponytails were extremely rare back then but hanging long hair is another no-no around a lathe spindle.
Empty Pockets
Rural New York
UNRUH-
All good advise, so far. Another thing to remember is to be sure to keep your turning chisels sharp. that way they're less likely to grab. And be sure to take small bites out of the wood that you are turning.
Have fun. Using a lathe is a lot of fun
U
Unruh
All great advise! I've used a lathe in my high school woodworking class, but yikes that was over 25 years ago. It will be a lot of fun learning now that I have more patience. I'm currently building my wife a pantry, once that is done I can start on the lathe bench. This gives me time to watch my share of YouTube videos, and get excited.
rsanter
visalia ca
The stand for those lathes need to have some added weight on the bottom to adsorb vibrations and eliminate the issue of being top heavy.
You can always add some sand bags or steel weight to the bottom before using, but think about that in the design
Sudsy
I've been turning for about 30 years so I've made a few mistakes and learned a few things I can pass along.......
#1, to #100 Think SAFETY.. SAFETY... SAFETY !!!!
It's amazing how fast bad things happen with a lathe spinning at high speed. No jewelry, especially rings, or loose clothes !
Eye protection ! It's not an "if", it's a "when" that chunk of wood is going to split and fly all around the room at high speed. Wear a face shield !
Before you sand that thing spinning on the lathe, move the tool rest out of the way. Hurts like hell when your finger gets pulled in there and crunched (trust me on this)
Have dust collection and wear breathing filters, not the hospital type but a real filter. A surprisingly large number of woods can cause respiratory distress. Some (like Brazilian rosewood - don't ask how I know) can cause serious respiratory distress. Your dust collector can be as simple as a 2.5 gal shopvac with the long wide fitting zip tied under the tool rest.
Keep your tools as sharp as possible at all times. The sharper the tool the cleaner the cut and the less tearout thus less sanding and less dust.
Learn to sharpen your tools before you ever turn the lathe on.
And remember, the larger the item being turned, the slower the speed.
And a few things you might not realize immediately, flat tools for making curves, rounded tools for making flats. Heavy cuts go uphill, delicate cuts go downhill.
The best way to practice is to make custom handles for your tools - never buy a tool with a handle, a true turner always makes his/her own and adds a personal touch. (the highest quality tools are often sold sans handle just for this reason)
drivesitfar
Unruh: i'm liking all this wood lathe conversation too. just curious if you are maybe going to put the motor up on the same level of the lathe and make the table a bit wider to hold it. I'm guessing you might want to make a cover for it to keep the dust out of the motor or do you or anybody agree that the motor should be on a shelf below?
good luck
toolguynj
Sparta, NJ
These vintage lathes are great as they are built to last and are much heavier than similar ones built these days. As other have said ...safety ...safety ...safety ... always check the balance of the rotating piece at a lower speed and safe distance before just diving into cutting.
U
Unruh
good luck
I plan on putting the motor on the back leg. I wanna use a hinge on it that will allow me to lift and switch the belt if I want.
Dennis Leigh Henry
South Central, IN USA
Just make sure that it can be "secured" or locked in place. When the going gets tough, you don't want the hinge to move and let off the power... I had a bandsaw with a motor on a hinge, and it would bounce and cause the cut to get awkward..
Packard V8
Spokane, WA
FWIW, a lathe is a great application for either a DC motor or a 3-phase with VFD.
I have a Delta with the 16-speed jackshaft. It is a PITA to change speeds. I got a working treadmill for free and used the DC motor and controls. I still need to refine the installation, as the treadmill uses a flywheel to manage speed, which keeps the lathe turning longer than desirable when shut off.
jack vines
U
Unruh
Got a lot done on the stand today. I’ve been making a pantry for my wife and was busy with that. Here is the stand almost done. Hopefully I can finish it up tomorrow and post more pics.
U
Unruh
So I cleaned up the motor. It is a nice 1/3 HP Delta Homecraft and mounted it on a hinge on the back leg. This should make adjusting the belt easy. I also showed a pic of the tool storage.
U
Unruh
Here it is all mounted and painted!!
LXCam
That turned out (yuk-yuk) right nice OP. You did an excellent job on that stand and I'm digging the tool holder.
U
Unruh
So I have had this lathe up and running for about 2 years and one thing I really would like is variable speed. Anyone have any experience using a treadmill motor?
mikegt4
sw ohio
Well done Unruh, make that very well done. It looks like you thought out the design pretty well. I have a Weiler Matador (German built) metal tool room lathe that came with an optional tool rest, wood turning style. I don't know if I want to mix wood chips with metal chips but I might try it someday.
