Offset cylinder head wrench
bixxjs
United Kingdom
Hi Yall
I’m in the process of engine strip down and found this tool really useful for removing the head bolts.A socket wouldn’t work as the nuts are offset.Part number s8663a,SO 11/16.
Provincial
Near Salem, OR
Torque adapter. Intended for assembly so you can use a torque wrench on the nut. As you have discovered, they are useful for disassembly, too.
They have been made in many different opening sizes, heights, and offsets in order to accomodate different applications. The one common design element is that the square drive is always located drirectly above the working opening.
anndel
Hawaii, USA
I was lucky as the last 3 engines I worked on only required sockets to remove/reinstall/replace head bolts. Good to know though there's something out there for offset head bolts. Thanks
BDT/NWMN
Erskine, Mn
Back in the golden olden days; Those wrenches were used on certain engines to re-torque head bolts after running them up to operating temperature.. Times have changed..
