Advice on conduit bending
evercl92
Columbus, OH
I'm going to upgrade the electrical in my finished garage from the single outlet that is there now (which conveniently is tied into the circuit on the wall it shares with the interior of the house). I plan on putting in 5-8 outlets, likely split across two separate breakers.
The plan is to run the wiring from the panel in the basement, up the interior of the wall in the garage, exiting the wall about two feet from the ceiling (10ft). From that, run EMT horizontally, then do vertical 'drops' to where the outlets will be. I have a bump-out along one wall and a bump-down along the ceiling that I need to work around.
I'm familiar with running electrical, just not with the actual bending of conduit. I got a bender / pole setup, but looking for where to start on how to make the EMT do what I want it to.
Need more space
I just did this in my shop, never done it before. I watched a few YouTube videos and it turned out great. Took me longer then a pro, but sure went smooth.
E
evercl92
Columbus, OH
Awesome. I browsed around youtube university, apparently I didn't come across the ones that spoke to me.
matt_i
PreYouTube: If you buy a new EMT bender like an Ideal or Greenlee, they should come with a little pamphlet (book) that details bending all of the typical offsets, saddles, etc, using the marks on the bender. 90s are not too hard :) What separates the men from the boys is whether you can dig up the book in a few minutes' notice :D
Crazyjake8493
Upstate NY
Bending EMT isn't difficult, just takes a little practice and a lot of math. Luckily, it's cheap to practice with.
finn
The UP, God's country
I’v Had my bending tools for about forty years, and use them maybe every five years , just enough to be semi competent.
Always have trouble making neat, consistent box offsets, so, for the last project I bought the die cast offset fittings.
Not as nice as a well bent tube, but functional and easy.
E
evercl92
Columbus, OH
Yeh, I bought those - figuring the lack of frustration with the extra bends will justify the overall minimal cost.
Norcal
Yuck.
bigb56
Tucson, Arizona
When learning box offsets attach a box to the end first and air bend it, box facing up for first bend and down for second. This will help avoid dog legs. Also easy does it, as soon as you feel the conduit bend slightly flip it over and do your second bend. Hold it all against the wall to check before mounting.
To check for square on 90s use a window/doorjamb, mortar joints or concrete expansion joints.
I agree about the die cast offsets, they scream DIY or Handyman. A professional looking installation will be something you will be proud of.
OneOfEm
Buy a few more pieces of conduit than you'll need. They'll become test pieces (even if they don't start out that way).
alfredeneuman
Fullerton, CA
I'm pretty sure Norcal was talking about these:
and you're thinking of these:
dscheidt
Every time anyone -- including you -- looks at them, they'll think "whoever installed this pipe was a lazy dog". It's worse than seeing minerallac straps on 1/2 conduit. Learn to bend offsets. Not hard, makes the job look better, and they're easier to pull wire through.
rjn2649
Il, A little west of Chicago
I am a "self taught" pipe bender, the hardest thing was those offsets, all I can say is practice... practice... practice, well worth learning. I liked the little booklets that came with the benders. The other thing I want to add is, IMO if your pipe is exposed. it's more important that it LOOKS straight than to be straight. That means parallel to walls and windows sometimes it's a compromise, that can drive you a little nuts...at least it does me.
rburke65
Canfield, Ohio
Ya.....just practice the off sets. I was never good at them, but at least try. Don't know why I was never good at it.....happy to hear I'm not the only one.
ronzmtrwrx
Me and a buddy are wiring my new shop. I’m pretty happy with how it’s going. The offsets are the hardest for us being novice pipe benders, but we’re getting there.
PoorOwner
CA
offsets are actually not too hard even when starting out, the only problem is that I can't put an offset close to another bend, it just won't fit into the bender no matter you make the offset or bend first.
I guess that's where the offset bender tool comes in handy.
It gets more difficult when your run change planes, or you need the pipe to fit back to back exactly which is what pros would need to be good at.
alfredeneuman
Fullerton, CA
You can always buy a Greenlee "Little Kicker" for offsets, only problem is that they are **** your pants expensive.
They also bend the conduit a little more than is needed for a standard box, and there is no way to bend less than the bender's full cycle :mad: .
You'll end up either with the conduit rolled to one side or another, or the box doesn't fit flush with the wall.
Brian_WK
NE South Dakota
I can bend copper like non other but I still manage to screw up at least a half dozen bends in conduit. the back to back U bends are the worst. At least conduit is cheap!
Brian
bigb56
Tucson, Arizona
Instead of trying to put an offset at the end of a 90, just bend your 90 then kick the end out just before the 90 out enough to fit the box-no offset needed. In other words your 90 will come away from the wall just enough to fit the box, and you will strap it right near the end of where it is in contact with the wall.
exranger06
CT
I couldn't seem to get the hang on bending offsets either. Every one took me a few tries and I wasting too much time and material, so I eventually said "screw it" and bought a box of offset fittings. What a huge time saver! I really don't care what anyone thinks when they see them, and I think they look just fine. It's surface mounted conduit in a garage with unfinished walls. It's not exactly the prettiest room of the house anyway.
matt_i
You mean these man-killers...
I say that because of all the blood I've spilled catching the sharp metal edge of either the strap or the screw end...
E
evercl92
Columbus, OH
For anyone still following this - i finally got around to doing this. Of course i messed up a couple pieces but i expected that. Im content with the results.
