Iron-Iceberg
So I picked up this monster and I have a few questions for others that have one.
I had the older model of this with out the One Key and my main complaint was that with only 2 power settings it was either set on Kill or slow slow slow with no power, basically finger tight lug nuts.
So I bought the 2873-20 with the One Key system. Hoping to be able to fine tune the torque. Maybe not within a pound or two but maybe around a 10 lb window. I’m not trying to eliminate a torque wrench but just be able to run lugs and other nuts up to 10-15 lbs below torque and then finish them with a wrench.
So on to the problem. The Gun has a lug nut setting but it starts at 80-130 lbs
That’s a little too high for me. Would like something in the 50-60 lbs range.
It also has a custom torque setting but it is just a scale of 1-20. I looked but I can’t find a tech sheet that shows what that might be in ft lbs.
Anyone have one or maybe just their favorite settings as a start?
