sbosecker
I purchased a Makita 3612BR Plunge Router sometime in the mid-80's. It has served me well for over 30 years.
A few days ago the collet appears to have failed.
I was routing using a 1/2-inch straight bit (probably about the same age as the router) in 11/32-inch plywood. A bit over 2 feet into the cut something bad happened.
I shut down the router and attempted to remove the bit but it was jammed inside the collet. I removed the collet nut and the collet, nut & bit all came out together. The bit is fast inside the collet and the collet is not coming apart from the collet nut.
I don't believe in the 30+ years I've had this machine that I've ever completely removed the Collet Nut - I don't know if the collet is supposed to come out with the collet nut or what its behavior is supposed to be.
Questions:
1. Anyone else ever have this happen?
2. If so, will replacing the collet and the collet nut repair the machine?
3. Any other useful information?
Thanks.
Scott
Questions:
Thanks.
Scott
