Pros/cons of French-style "clés à pipes" socket wrenches
4xdog
Santa Fe, NM
My friends in France reach for their clés à pipes socket wrenches as often as I reach for a combination wrench.
Perhaps because I've not used these all my life, they seem OK, and sometimes truly useful, but it seems surprising they're so common in parts of Europe.
They can be used similarly to a box-end wrench on one end and a nut driver or socket with extension on the other end. They're typically 12-point on the short leg and 6-point on the long leg. The wrenches are sized such that a wrench a few sizes up will fit over the end of a smaller wrench to give additional leverage.
Perhaps some of the folks smarter than I on here can give us some of the pros and cons of this wrench style?
Here are pix of a few in my toolbox, these from Bost Tools of France.
AceofSpad3s
Certainly look like something the french would come up with.
All the negatives with the bulk of a ratchet and socket with none of the benefits of fast movement or ability to fit in spaces without much side to side movement.
Looks like they would be useful if you have a narrow space and a bolt on a long stud, or if you need tools that can do multiple functions and be compact.
driftpin
I don't know any real advantage to them. I would as-soon reach for a socket/ratchet, because the job would get done quicker using the ratchet function.
They remind me of nut drivers, of limited use, but I suppose in some instance they are handy.
What they remind me of, are the vehicle lug wrenches which come stock on so-many cars/trucks. They don't provide optimum leverage, and are enemies to nut flats. The first thing I do with a new vehicle is find out which socket of a 4-way wrench fits the wheel fasteners, and throw a couple of wraps of electrical tape around that shaft, to make for an easy I.D. at night, should I need to change a flat, and into the trunk it goes.
Gmonkee
They kinda replace a socket set and a wrench set all by themselves. I own and use a set so no "could be" or "looks like" from me.
A bit of a learning curve in making them truly effective but they do work well at many automotive tasks. Mine are effective in my hands but a co-worker struggles with them.
I like mine. The only way to know them is to use a set going in without prejudices. Make them do what the others did. Half of Europe uses them as first line tools. How can they be all bad?
4xdog
Santa Fe, NM
Wyoming09
Wyoming, MI
We have a few of them laying on certain machines. They were supplied by the machine builder to change parts. Most of us just use our own tools so I don't see them getting used much.
dnschmidt
Phoenix, AZ
As weird as it may sound angled socket wrenches were a major factor in getting me to sell TOPTUL tools. I love the things and TOPTUL makes really nice ones. Getting me and my buddies sets of angled socket wrenches was a driving factor in my making first contact with TOPTUL. They didn't sell worth **** but anybody that bought them loves them as they are very comfortable on your hands compared to relatively sharp combination wrenches. You can exert far greater force for a given length with an angled socket wrench because you're not hurting your hand. Great for valve adjustments and on motorcycles where you have screws inside of lock nuts. Eric O. uses the one I sent him for changing out struts which have this exact situation. Trust me they will never be mainstream in America but that's our loss because once you use them you'll like them.
fos373
I picked up a Facom in 10mm to try. I've reached for it once, maybe twice. I'm more likely to reach or a T-handle or a normal socket. Just didn't do it for me
unslow1
Illinois
I guess to me they look more like what you would improvise with if you were stuck somewhere without tools. Maybe it's just the mindset set of not giving something different a try. Personally I doubt I would ever even try them.
SRSemenza
The TOPTUL site has a useful diagram showing how these wrenches work.
Aaah, that drawing explains why the six point is on the long end. It didn't make sense to have the six point on the end with less leverage. But that T handle set up makes sense.
Seth
Sanny81
New Jersey
I couldn’t imagine a situation I’d use these over a combination wrench or ratchet and socket. And ever since I got the M12 ratchet I almost never use a regular ratchet so these would collect dust for me...doesn’t mean I still kinda want a set though.
Mr_B
Reading
Not that useful, I picked up a toptul set as too cheap miss and thought give them a try and have them on standby for special scenarios.
Kind of okay in smaller sizes as a wrench and nut spinner all in one scenario but it easy live without and certainly not a must have.
couple t-bars, spinner handles and good selection of various length extensions in 1/4 and 3/8 replace these easily and way more adaptable to specific job needs .
t-bar with extension and socket wins almost every time for me over these.
If wasted big bucks on facom or proto branded ones I been pretty upset .
Larryjones
WV
You would have a natural affinity to push down own the wrench while torquing and thus have a greater chance of snapping off the fastener. A ratchet and socket doesn't have such a high center of gravity and the old saltus wrenches had the flex coupling.
Mr_B
Reading
Yeh the old saltus style swivel socket wrenches a far more useful tool than these.
These are certainly not a must have but indeed a nice box filler if you got a chrome addiction or just see them at steal price ...
bob15
Northeasten, CT
They would also work well when working with thread rods and nut depths greater/deeper than a socket depth and gives you better hand/finger clearance.
Ji m
The Northeast
I could see keeping a couple around as dedicated oil plug wrenches, or something similar.
But mostly I can see very little advantage over a box, or offset box wrench.
If I had to find a use,
I'd say for production work where you had multiple workers assembling things that that had the clearance to fully spin the wrench it would be cheaper/less stuff to lose vs having a ratchet & socket for each assembly worker.
Plus no one is going to steal the thing :lol:
The in line side could help lining up the nut/bolt and spinning it up before cranking it tight with the 90* side.
davewo
USA
I don't have a set, but I've been in quite a few situations when a socket wrench is too bulky, but a combo wrench lacks the depth to clear an obstacle.
Gmonkee
You obviously do not embrace minimalist ideas. They eliminate the need to carry full socket sets with all the trappings for regular uses. Special situations will require special tools. Ten wrenches and a screwdriver as T or extension handle. Double duty as possible.
They also can make box ends optional but not open ends in all cases.
My work kit has a small 3/8" socket set for speed issues but really for the most part I could avoid using it.
Its not hard to guess who never thinks of things as multiple use/scenario tools.
Fedwrench
Valley of the sun
I chalk it up to being a European Tool thing. They might handy in some situations but, never really caught on here in the USA.
Kind of like ball peen hammers are popular here but, cross peen hammers are more popular in europe or red is a popular color for tool boxes here while green seems popular in europe :dunno:
Mr_B
Reading
!!! :-S
No, that pretty much why I wouldn't bother with them much as in a minimalist approach and thinking in multi use scenarios I can make standard socketry cover socket wrenches, nut spinners etc . I can triple duty a socket rail set with few extensions, t-bar and small knuckle bar .
4xdog
Santa Fe, NM
In my country they are known as pipe wrenches...
That's pretty much the French word, too. In American English, we use "pipe wrench" for one of these. The names refer to different kinds of "pipe", though!
The US pipe wrench is called a Stillson wrench in the UK, for the name of the American inventor (which we don't use.)
Mr_B
Reading
In my country they are known as pipe wrenches, they are very useful to disassemble the front shock absorbers.
I do not have any pictures, but to get an idea, change the T-handle key to an open head pipe.
I tend use an impact, one time I did try that on aftermarket shocks and lift spacer assembly at the bench it wouldn't work as the aftermarket nut was 19mm and oe was 17mm so not enough clearance as wall thickness bit chunky so back to impact and chrome socket . They got uses but just not that many besides go through scenario and that special scenario where just right shaped tool work the easiest, not something I have out on the tool trolley daily .
Kasal
Galicia, España
If here it is also known as a stillson key
Kasal
Galicia, España
Oh if an impact would be the best and fastest.
I even used a cranked key for not having other tools.
mfewtrail
Those facom style posted on page one look like they would be perfect for shocks/struts since the openings in the end for a torx, hex, or whatever to pass through are sorta large.
Kasal
Galicia, España
Yes, those on the first page are fantastic, but I do not know if I could justify the expense of the game, when it was only used once or twice a year.
Mr. Tool
:lol_hitti......the shape and style of these tools remind me of that lame little nut lug wrench that comes with your vehicles spare tire accessories, jack, etc.
Here's the FACOM catalog page for their socket wrenches:
https://catalogue.facom.com/uk-en/c...s/produit/76-metric-angled-socket-wrench-sets
Here's the same page on the Proto Industrial Tools page. As they're all part of the greater Stanley Tools ecosystem, one would expect a lot of cross-posting. FWIW, my friends all use the FACOM version.
http://www.protoindustrial.com/en/i...10-Piece-Angled-Socket-Wrench-Set---6-Point-/
Gmonkee
Seems to be a few sets that could be easily resold just by folks in this thread.
I am keeping mine.
