My New Shop/Garage Build: (Sub Shop)
subvet
Rising Sun, MD
After 20+ years, I retired from my first career in the Navy and moved here to MD. AS I started my second career, I designed then built my new house that was finished in 2003. Unfortunately I quickly outgrew my garage in about 6 years. I finally am able to build my new Shop/Garage. I have been lurking around this forum for several years reading and learning from all of you. After I started my build I finally decided to start this thread to hopefully gain some additional recommendations as I move toward finishing the shop/garage. Thanks in Advance.
First pics are the second driveway being put in
subvet
Rising Sun, MD
Re: My New Shop/Garage Build
Footers, Dug, Poured, and Block work started.
subvet
Rising Sun, MD
Lookin' good. Any details on the build? Size, etc...
Forgot the details:
I had wanted to build a 30x40, but with easement restrictions, septic reserve restrictions, and grading of the lot, the largest I could build was 30x34 within a reasonable cost.
Building will be 30x34, block foundation, 2x6 24 OC, 10ft walls, vinyl siding, Metal Roof, 16x9 garage door, one window and a man door.
subvet
Rising Sun, MD
Stone in place for the floor, concrete forms for the apron, sidewalk & steps.
subvet
Rising Sun, MD
After some discussion with the county, I asked the mason to add an additional row of block, this will gain some additional ceiling height.
With almost 2 rows of block about the concrete I will clear 11ft for ceiling height.
Glad I was able to do this just before he added the J-bolts.
Riley
Great call. Can't do it later. Looks like things are moving along nicely.
zmotorsports
Northern Utah
Subscribed.
That will be a nice looking when done. House already looks great.
What do you plan on using the shop for? Automotive, woodworking, motorcycles? What kind of tools will you be filling it with?
850xpeps
Looks good. I would recommend 16” or for wall framing.
subvet
Rising Sun, MD
Subscribed.
Thanks.
Automotive & Bikes & whatever else?
I have planned to have 2 areas to have thicker concrete just incase a lift showes up in the future.
Currently I plan to move over my willys CJ3a, my Harley, Drill press, pedestal grinders, Belt/disc sander, welding table & welder.
Probably a majority of my tools, Not sure if I am going to get new tool boxes or move my old snap-on boxes over.
subvet
Rising Sun, MD
I was put alot of thought into that and discussed it with nerous friends and the county inspectors, went with 24" Framing is now done.
The Amish crew is fast.
subvet
Rising Sun, MD
Framing and Roof done.
Most of the sheathing up and window is in
zmotorsports
Northern Utah
Thanks.
Sweet.
You had me at Jeep and Harley Davidson.:beer:
subvet
Rising Sun, MD
Concrete poured on the garage floor, apron, sidewalk and steps off the side of the porch.
The floor includes 2 pads 10" for possible future lift.
I have not decided what to do for a floor finish.
I think I want to keep the look of the concrete, so thinking
I am leaning toward some sort clear sealer.
I like shiny so thinking Gloss finish or not sure to keep it the natural dull look.
tpndrcn
Nice looking shop so far, please keep posting the pictures! What do you have planned for insulation and interior sheeting?
Sent from my Pixel 2 using Tapatalk
subvet
Rising Sun, MD
Thanks.
I am will be using normal R19 with plywood and drywall.
subvet
Rising Sun, MD
Siding is all done.
Electricians have started to run power to the Garage
subvet
Rising Sun, MD
The gutters got installed and the shutters got put up.
Electricians put in the panel and finished running power to it.
Next will be running lights and receptacles.
subvet
Rising Sun, MD
No Pics today, layed out all the receptacles and lights, the hung a few boxes.
However I show you what I had been busy with the last couple years.
Deezler
Southeast MI
Dang, it took you a couple years to build that bar? slow and steady work, lol.
Nice new shop/garage!
Ro_Ja Boy
Makes me realize how slow my build is coming. :D Nice work!
big_bake
VA
Is that 6" wide block for the masonry walls?
subvet
Rising Sun, MD
The building went up fast. When the builder told me 5-10 days I was doubtful.
There were 4 or 5 guys on the crew + another 3-4 just for the concrete & block work.
Progress will slow down now that I will doing it mostly myself moving forward.
subvet
Rising Sun, MD
More Bar build pics.
Laying out the Hickory Boards for the bar top.
Also place LED under the top
subvet
Rising Sun, MD
Bar rail I salvaged from an old local bar, reshaped it then refinished it.
Building the Bar back.
subvet
Rising Sun, MD
Checking out the bar stool spacing.
Fabricated foot rail brackets from iron pipe, round stock and some plate.
Foot Rail itself is sch 80 pipe, wire brushed then clear coat.
LED lighting is worked out great shines on both sides of the bar.
Bar counter shelves being assembled.
subvet
Rising Sun, MD
Counter top and Sink for the bar back and under bar counter.
TV connected, then re-routed the power and cable so it is out of sight.
Built a small Liquor shelf.
subvet
Rising Sun, MD
All Done:
Fran's Trusty Shellback Bar
subvet
Rising Sun, MD
Back to Progress on the garage.
Wiring was slow moving then one of our ALR members loaned me his son to help out.
Journeyman electrician 10x faster than I can do getting these receptacles in.
subvet
Rising Sun, MD
When I was trying to lay the electrical circuits, I tried to think of anything I would possible want in the future. I hope I didn't forget anything.
I should have plenty of receptacles now.
23 120v 20A receptacles on 5 circuits
2 220v 40A for my welders.
And in case I win the lottery I also included accomodations for wish items
like plasma cutter can share the 220v with my welders
1 220v 30A for possible future bigger Compressor
1 220v 30A for possible future lift
1 220v 40A for possible future Heat pump
subvet
Rising Sun, MD
Garage Door got installed.
The Side Door was removed and reinstalled with the right color.
:thumbup:
subvet
Rising Sun, MD
The R-19 insulation is going slowly. Working in the Heat alone is not helping any.
I was originally thinking to try and figure out what to do about the floor. I like the concrete look, so I guess I need a clear finish that won't cost me dearly.
Now with working in the heat, I may have change priorities and be looking for an affordable Heat pump.
subvet
Rising Sun, MD
Got sticker shock at the prices of insulation, plywood and drywall.
I guess I have been behind the times, been awhile since I looked at them till I started this build.
I sold my Softail custom to help finance this project.
Sorry to see her go but I wasn't riding her and on brighter side hat makes room for something else when I all down throwing $$$ in this building.
