Old Union Machinist Chest Restoration
Davefr
OR
Last month I picked up this old Union Machinist chest at a garage sale. It was missing a ring pull, the entire front cover/lock and most of the hardware had rust. The good news is that the wood was nearly perfect. Joints were solid, no cracks, holes or any signs of abuse. The leather handle was even in great shape. For $5 I decided to buy it.
As Found:
The next challenge was to try and find a ring pull. They're unobtainium so I decided to make one of of a sheet of brass and a rod using a couple ball pein hammers and a hole on a piece of oak.
Not perfect but better then a blank hole. The challenge was matching the patina of old worn, tarnished plated brass.
I removed all the hardware and gave it a bath in Evaporust then cleaned it up as best I could and then shot them with Lacquer. There was very little brass plating left on the corners. The original leather handle was in very good condition and just needed some Neatsfoot oil.
Finding a lock was a challenge. The front is 1/2" and nearly all old cabinet locks were for 3/4" thick drawers. I found a lot of vintage locks but had to amputate 1/4" off the barrel so it would look right:
To be continued.
D
Davefr
OR
Now that all the hardware is accounted for the next phase was stripping what's left of the old finish, staining and applying the final finish. I chose Transtint Mission Brown die for the stain and Sam Maloo's formula of equal parts varnish, turpentine and BLO for the final finish.
The next step was to make a new raised panel front out of quarter sawn white oak and then mortise for the lock.
D
Davefr
OR
Finally the finished project:
I decided not to re-felt the drawers. The old felt is still in decent shape and it give this old box some character.
rsanter
visalia ca
So you spent $5 so you can spent many hours and some money restoring a very old toolbox.
Yup, sounds like a GJ member
Great job, that turned out awsome
bmwrd0
Beaver Fever Oregon
Nice, I have the same issues with the lock for a George Scheer I am restoring. Now I have a better idea what to do for that.
D
Davefr
OR
Impressive.
Can you post photos of back of pull you made? Is ring soldered?
I don't have any images of the back of the ring pull. Here's a close up of the original. I made mine the same way by cutting a couple slits and pushing it out to make the ring's hinge. The ring itself is just closed up tight but not soldered.
Davefr,
I believe these people have the union pulls:
http://machinistchest.com/site2/product_details.php?item_id=18
Tom
Thanks, I already tried that site but the rings are long gone and I'm not sure the site will re-open for business.
7th Kahuna
Los Angeles, CA
Wow, beautiful job, beautiful box. Thanks for posting the details.
I recently acquired a (?1970's or 80's?) Gerstner box with a dreadful dull finish. I nearly passed on it, but decided I could refinish it. I looked online for color inspiration and found several vintage boxes I liked. I just wasn't sure how to get there. The Transtint approach looks promising. For anyone curious, I found an interesting related article on the Lumberjocks website;
I will also need to change the felt in mine. The moths have had a field day. I read that some felt (?contains chemicals that?) will cause oxidation. I need to research that further.
Username already in use
I'll echo the previous sentiment with my kudos as well. That's a fantastic looking restoration! Excellent job. :thumbup:
I've got an old Gerstner box that needs some TLC like this. I'm not sure if I have the skill or the patience to do it justice.
D
Davefr
OR
Thanks everyone!!
This is the third time I've used Transtint dies. I like them so much better then traditional stains because they make the colors and grain patterns really look vibrant. The problem with dies is that you mix them with distilled water which will raise the grain. The solution is to first wipe the wood with plain distilled water which will raise the grain then give them a light sanding. Now you can use the dies and they won't raise the grain. (or you can mix them with alcohol which I haven't tried)
The gerstnerforum has a ton of info on re-felting. I think the key is to use a special felt and apply it with liquid hide glue.
http://www.gerstnerforum.com/forumdisplay.php?8-Tips-and-Tricks
Gerstner even sells re-felting kits.
http://gerstnerusa.com/replacement-hardware
larry_g
oregon
That is great. Did the Union boxes ever have a felt or cardboard work surface on the inside of the front door?
lg
no neat sig line
D
Davefr
OR
lg
no neat sig line
Yes, the images I've seen show felt covering the inside of the raised panel. I'm going to leave it bare wood for now.
Was the inside front really intended as a work surface?
drivesitfar
Dave: well done sir!!
I still recall the big oak multy drawer oak file cabinet you restored maybe 4 years ago that was also amazing. :bowdown::bowdown::bowdown:
you sir have some skills and can make a turd into a diamond as you have time or want to.
keep up the hunts for these lost souls that you seem to put a lot of new life in. :thumbup:
Toolmaker65
York, PA
Having been in the machinist/tool and die maker trade for 35+ years, I have never seeen anybody use the front panel of their box, either wooden or steel, as a 'work' surface. I may place an indicator on it so that it is safely out of the way until I need it again, but have never 'worked' on it. Imagine how long it would last if you put a bench block on it to try to drive a broken dowel out of a 5 pound die block with a 16 oz. ball pein hammer. Bet it would be cracked nicely after the third hit.
I have seen the covers referred to as "work surfaces" mostly on ebay by people who learn what a machinist chest is, realize that they might be able to make some money off of it, but have no idea what a machinist actually does.
The sole function of the front cover is to keep the drawers from flying open when you move your box around in the shop or from job to job. It also keeps your tools safe from those thieving SOB's that work on the shifts that you don't when you lock it.
Excellent job on bringing it back to life Dave!
larry_g
oregon
Considering that these boxes were/are used by jewelers, optometrists, and other trades that may travel yes they were used.
lg
no neat sig line
Yes.
Common sense dictates that you can't pound on it, but there are plenty of tasks performed by machinists' in the course of their work that don't involve pounding or any other type of blunt force.
I don't know about Union, in particular, but the front drop panel/hinged lid on a machinists' tool chest, often either cork- or felt-lined, is most definitively described as a work surface, or tray, secondarily to its lid function, in vintage catalogs and advertisements. H. Gerstner & Sons still advertises it as a "work surface" on current models, saying that it "affords ample room for small projects or organizing hardware."
Wartime machinists' chests, which I hesitate to even show in the magisterial presence of your oaken beauty :))), even had various recesses for retaining small tools and parts intentionally built into the panel.
I own one by an unidentified OEM with a 2-inch recess that runs the length of the panel, and another Kennedy Big Horn Line with three round well-placed dimples for this purpose.
View media item 78320
View media item 78319
View media item 75995
rlitman
Long Island
lg
no neat sig line
Also used for cosmetology, and theatrical makeup kits for example. In these cases, it might make sense as a work surface.
jimreed2160
Tallahassee FL
"Work surface" is a broad phrase that covers a wide expanse of waterfront. Of course it can be used when working. And it will remain in good shape if the user is mindful of its limitations.
7th Kahuna
Los Angeles, CA
I almost asked if you had used water or alcohol with the dye. I think I'll experiment with alcohol. First I need to get the remainder of the existing finish off.
How did it not occur to me there would be a forum . . . :lol: and replacement parts too . . .
Interestingly the felt they sell is acrylic. I'm assuming the felt in mine is original but it is clearly wool. I wonder if there is an advantage to one over the other.
davewo
USA
Wow, what a fantastic restoration, and that new drawer pull looks great! Looks like it ready for a few more generations.
leg17
Kentucky
When you think 'work surface', think:
"Where can I set my mike/indicator to keep it up out of the mess?" (thanks toolmaker)
or "Now what can I do with these screws so I don't lose them?"
