Electric motor question...........
reman
Altha, Fl.
I am building a very large whole shop fan in my playhouse. I do want to control the speed, so I am wondering if I can install a rheostat on an older single speed 4 hp air compressor motor. I am thinking probably not but who appreciate any thoughts from those who are much more knowledgable than me. I know I can control the speed with pulleys, but I need to be able to vary the speed easily. Thanks
slow
near Orlando
Best option is to get a 3 phase motor and a variable frequency controller. Exactly what your asking to do and you get energy savings as a side benefit when lowering the speed.
GMCGarage
You need a VFD to control it without frying your motor, unless you can convert to a DC motor.
rlitman
Long Island
Probably not. I have never seen a 4hp compressor with a brushed motor where this would work.
If you have a 3-phase motor, you could do what you want with a VFD.
edit: looks like I took too long to type this, as I was beaten to the post.
James-W
Southeastern Wisconsin
I agree that what you describe would work just fine. But wouldn't it be less expensive to just buy a fan already setup to run at different speeds?
slow
near Orlando
all depends on the size of the fan. The last one I installed was a 7.5 hp 45,000 cfm fan, so it was great to be able to run it as a 15,000 cfm fan at a much lower speed, and crank up the speed when we needed more airflow (but it was much louder at full speed)
R
reman
Altha, Fl.
d
You are probably right if I were buying all the parts. But the fact is that I have all these pieces on hand except for the variable speed issue. I could hook it up as a single speed with what I have. Plus I have Lotsa time and little $$. lol As well as trying to use up some of the **** I have accumulated over a lifetime.
dogdog
Thanks for the responses so far. Good info. I saw this on fleabay and wondered how it might work in my application.
https://www.ebay.com/itm/For-Router...aEAAOSwyW5a7fKS:sc:USPSFirstClass!32421!US!-1
It would not work well on a true AC motor (induction type)... does work on motors with a carbon brush type though...but weaker unless at full speed... I used that on the grinder and routers, but they are Brushed AC motors... Not sure about energy consumption.... and also Not sure about 4HP motor 15AMPx120V = about 1800 Watt... 4HP is about 2982.8 Watt and that is not even including that initial current draw of the motor. ... most whole house fan motor I seen are 1/2 HP...
Davefr
OR
Reostats won't work with split phase induction motors. Why don't you get a HVAC air handler motor that uses winding taps to control speed. Use a rotary switch to select the speed.
redmondjp
Redmond, WA
That's exactly what I was going to suggest. Go to your nearest HVAC contractor and see if he has any old outdoor cooling unit fans which you could obtain either free or cheap. Make sure you get the motor capacitor as well - on some of those units the capacitor is mounted remote from the motor itself.
R
reman
Altha, Fl.
I think that is probably to most practical way to achieve my desired result. I had not really considered it because of the low hp motors. My fan is a regular bladed fan, with 3blades and about 3 feet diameter. Would the small HVAC motor pull this? I am sure there is a required torque difference, from what a squirrel cage or smaller blade requires. Thoughts?
