lots of work happening, I finished wiring all the outlets for the work bench, the long end has three boxes, plus one box in cabinet for vacuum, the short end has two boxes plus one in cabinet for compressor
B90B6281-1A7C-478D-82BC-B84F734505CE by
, on Flickr
AB369261-0461-4EB4-8AE2-634F909D65C9 by
, on Flickr
I hung and framed wallpeg vinyl pegbopard, then added my tekton metric/SAE wrenches, took a few tries to get the layout right
824B5A1F-D676-429A-9B3B-C22A7DE17A93 by
, on Flickr
7BFF4601-4358-4961-BCCD-E152F7FDC455 by
, on Flickr
next the bench tops, two layers of mdf, a sheet of hardboard, and maple edge banding, and several coats of wipe on poly, and two coats of the wall color paint on the bench
C3EC2C59-6D8C-44DE-AEC3-BD5BFB5FA62D by
, on Flickr
D5BED651-120B-4331-85DE-B549B49D3914 by
, on Flickr
next is the cradle for the Bosch glide saw, this things rocks
0297ABA9-1C55-4F28-85EA-A677FA2F9516 by
, on Flickr
I unearthed my Morgan 88 from storage, This is what it looks like after I lubed the main screw and gave it several wd40 rubdowns. I got the vise on ebay about a year ago, it had surface rust, but very minor usage. Jaws are like new. I don't plan on doing much else to it but using it and keep it well oiled.
8554BA19-493C-4248-9A19-FB53EE9CBF07 by
, on Flickr
This was nerve raking to say the least. Routing 8' foot channel for T-track in fully finished and mounted bench. I also routed a shallow channel for tape measure that my stop block will utilize
7BF63E21-4556-4127-975F-BCBA1B4F5BF3 by
, on Flickr
11598426-C075-4596-8E15-535BA5B0B908 by
, on Flickr
Here is my stop block solution gleamed from many ideas i have seen, and modified for my purpose. I don't like vertical miter fences because they take up bench space, and when long boards have a bow as most do, they get in way and make keeping board square to miter fence an issue. Also, when this stop block is removed i have a flat, fully usable 8 foot bench, and the track can also be used for hold downs for sanding etc.
The stop block uses a heavy duty 4.5 inch ball bearing hinge so it can flip out of the way when cleaning up edges or making quick rough cross cuts. The tape is a Starrett left reading 12' tape. I also added a Lexan cursor for the tape measure which I scribed and colored with a red sharpie. It is slotted to fine tune the stop block for perfect length cuts. It has a hard maple runner and one bolt for the t-track knob. Now i have it dialed in I can cut any length board up to 9 feet within a 64th of an inch with repeatability. For short cuts I have a 20"spacer block, and use that to cut pieces < 20" perfectly.
105BA8B3-6DE8-4B73-BE16-C9410C55A63C by
, on Flickr
25478C3D-2447-47B0-A9F8-7C0A09431D27 by
, on Flickr
837082BD-B897-49A1-B1C3-81512D2CF8C4 by
, on Flickr
CF893DAF-5328-4D3A-B5DE-CED321FFFF8A by
, on Flickr
I used the saw heavily for a day, and while the vacuum and modified dust boot does great job on short cross cuts. On wider boards, or miters, especially when cutting fast I was getting to much dust so i built a dust hood and the difference is night and day. It does cover a fair amount of my pegboard, but I can hang tools from hood too down the road if i see fit. With the hood and the vacuum I get almost zero dust on the bench
DE5BD98D-59B9-4C4F-984A-9BA9D4CD9C19 by
, on Flickr
Here you can see the vacuum in the cabinet which i control with a remote, and the duststopper separator under the saw. I have a hose running out to table saw, and a hose for the miter saw, and simply switch them at the separator when needed. The dustopper works very well keeping filter clean and making clean out easy.
636F83B2-C247-4755-AB3A-E7FEAB4E21C4 by
, on Flickr
A9FC87E9-BC49-41F2-96EF-1B9BE4845853 by
, on Flickr
I almost done with the initial shop build. all that is left is to paint and hang doors for work benches, and renovate, paint and hang old kitchen cabinets that will go above long end of work bench.
