Kurt Vise Sloppy movable jaw, but up and down?
Strouty
Southern Maine
I am a newbie to kurt vises, seems to me that there should not be a lot of movement, but I am not sure. When I bought it, there were two of them and I am not sure I really checked this one over, I gave the other to my father, so I don't have quick access to it to see if it is similar. I did not measure it, but seemed like I could lift the movable jaw up about 1/2", is there adjustments, is this normal, am I screwed? I will try and get pictures tomorrow.
larry_g
oregon
They are adjustable and rebuildable. Go to the Kurt site and you will find the procedure. Pay attention to how to adjust the setscrew, If I remember right it is tighten and then back off some. (On edit, reading the manuals a bit the backing off of the setscrew depends which model vise you have.)
https://www.kurtworkholding.com/vise-trouble-shooting-guides
lg
no neat sig line
matt_i
I think its normal. There's a 45 degree angle surface so the forward pressure of the screw causes a force perpendicular to that plane. Resolving the vector into two equals means equal downforce on the moving jaw as forward pressure on the screw.
That's why the Kurt is a big improvement over say a Palmgren or Bridgeport vise. In those the forward pressure of the screw causes the moving jaw to lift up...
Strouty
Southern Maine
I was wondering if it was, but I couldn't find any info on how much it should move, just seems like a lot. I will get exact model and info when I go to the shop again. My other vise is a palmgren and it doesn't do this at all.
Strouty
Southern Maine
I haven't been to the shop yet, but I will try and get a model and pictures, at least then I can see the manual and know what I have.
Strouty
Southern Maine
Here are the pictures, not as bad as I remembered, but still think she needs a rebuild. The serial number is not really visible, but it is an older D60.
larry_g
oregon
https://www.kurtworkholding.com/documents/online_D40.pdf
Look at the above link. It shows on page 9-10 the procedure. The link above that I posted will get you to the rebuild kits, if needed. I'd suggest that you disassemble, clean, lube and then reassemble to check if all is OK. Then order a kit if needed. There are also new jaws available from Kurt or aftermarket sources.
Your base problem is that the setscrew in the movable jaw is loose, item #12 in the parts list in the link.
lg
no neat sig line
Strouty
Southern Maine
Once I get it apart, I am sure I will find that it is dirty too. I will be ordering the rebuild kit for it, they are like $11.
