Completely wrong. There is a reason it is code. The poly does not trap moisture when there is no vapour barrier on the outside of the wall. Your theory is crazy. Why would Vb produce mold? When you seal a house you also need to install a proper hrv system to replace the inside air with fresh air. A hrv is also code and must be installed on new houses.
Your first sentence baffles me. You say plastic vb should be avoided and then follow it by you must stop air movement....which is what the poly does. I don’t even know why I would reply to your post but it seems like you don’t know how good building practices are. You vent on the outside to keep the air flow and avoid moisture build up and you seal inside to keep the warm air from condensing and causing moisture inside a wall. I hope you are not a builder and are advising people the way you seem to think stuff should be built.
Sent from my iPad using Tapatalk Pro
I know what i speak .. do some research before you say someone is wrong.
It's not hard to find the facts. Mold has become a problem because people keep using impermeable barriers.
The whole reason for the development of house wrap was to solve the air intrusion problem and still be able to use inexpensive fiberglass batts.
venting and plastic are bad bad bad ... Have not done either in over 30 years. Foam is the best with proper positive fresh air intake .. but a good building can be done with batts ... not with plastic.
There are many recent studies ... it's not new. When polly first started to be widely used after the energy crunch in the early 70's -- it did not take long before the problems become noticeable. The tighter the building the bigger the problem. saw many in the 80's when I started.
follow the link in an earlier post ... explains part of it and discusses where to get more information
