I was going to add this to the Pex-Al thread, but its not really related because I went with the Pex-b.
So anyway I wanted four loops in inverted spirals and neither Blueridge nor Loopcad can easily do this so I just drew it up on graph paper. I had my 6" mesh down so I counted how many I had each way and made each one one square on the graph paper. The garage is about 27 by 34 inside and I placed the manifold half way down the side wall so if I do a control joint no tubing will cross it. Two of the loops are 220' and two are 230'. Well within the 10% rule and close enough for me. The tubing is 12"oc and I ended up with 900' of tubing in a 900sf space. All good.
View media item 1301
Here is a pic before I started.
View media item 1297
I was going to buy four 250' rolls, but I'm too cheap for that so I got a 1000' roll and it ended up working out well. I made a wooden spool for it out of some old plywood I had and put it in the spool before I cut the bands on it.
View media item 1298
View media item 1299
View media item 1300
Then I(The wife helped) just rolled it along the pattern ahead of where I wanted to tie it down. It worked really well with the full roll, but when the roll got smaller toward the end I had to sort of pick it up and spin it because the outside diameter of the spool and the tubing no longer match. If that makes any sense?
View media item 1302
View media item 1303
View media item 1304
View media item 1305
View media item 1306
View media item 1307
The separate tube to the right of the manifold in the last pic is for a floor sensor for the thermostat.
Some of these pics were taken from the top of a ladder the the ceiling height 12'. The white panels on the walls are smooth door cutouts that I am using to insulate the cement block portion of the walls. They will also insulate the perimeter of the slab.
The 14 white pvc tubes sticking out of the floor are place holders that will be pulled out after the cement sets up. There will be floor anchors going in those spots and I didn't want to take a chance drilling into the pex with a 3 1/2" core bit.
John
John
