benjamming
I need some more sockets (don't we all?
). In general, are deep sockets not used very often & will they damage/slip the fastener more than a shallow? I do plan on purchasing impact sockets as all of mine are currently chrome.
In particular, I need a 19mm socket for the crank bolt on an '02 Accord V6 (timing belt job). I believe a deep socket would be best here, although I have a 19mm shallow socket but not impact rated (not used daily - I'm a DIY). Would type socket would be best in this use? I would think that the chrome socket would do fine, but not 100% sure.
As a followup, what would you recommend as additional sockets that would be the most used in automotive repair applications that I don't currently have? I'm saving about $600 doing the timing belt myself, so that gives me $300 to spend on garage items. Anyway, these are the sockets that I currently have.
1/4" Drive 6-point shallow:
4-14 mm including 5.5
5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8-9/16 (skipping the /32)
1/4" Drive 12-point shallow:
3/8" Drive 6-point shallow:
6-17mm
1/4-13/16
3/8" Drive 12-point shallow:
12-19mm
5/16-13/16
3/8" Drive 6-point deep:
12-18mm
3/8, 7/16, 1/2, 9/16, 5/8, 11/16
I am seriously considering Wright impact sockets. What are the opinions of the Wright spline drive sockets?
Thank you.
). In general, are deep sockets not used very often & will they damage/slip the fastener more than a shallow? I do plan on purchasing impact sockets as all of mine are currently chrome. In particular, I need a 19mm socket for the crank bolt on an '02 Accord V6 (timing belt job). I believe a deep socket would be best here, although I have a 19mm shallow socket but not impact rated (not used daily - I'm a DIY). Would type socket would be best in this use? I would think that the chrome socket would do fine, but not 100% sure.
6-17mm
1/4-13/16
12-19mm
5/16-13/16
12-18mm
Thank you.
