Rusty Bolt
I'm about ready to hook my new detached shop to the electrical service. I'm trying to figure out the best way to proceed.
I've got two questions:
The power company will be upgrading my service from 200A to 400A. The house currently has 200A service.
I've found a 200A breaker that should be and looks to be an exact match for the existing 200A breaker and there is space for the new breaker on the busbars for the new breaker. I just want to add the new breaker to the pedestal and connect the wires!
The problem is that there is a screw in the center of the new breaker (just like on the old breaker) but there is no hole for it to go into. You can see the corresponding screw hole in the existing breaker at the left of the picture. I need a hole above the bare copper ground and below the fluorescent sticker.
There is a tapped hole that looks to be the right size but it is too far to the left. If the box weren't hot with the power company's feed behind the panel, I'd just drill and tap an appropriate hole. If I'm sure that's a good approach, I can wait until the power company kills the power to pull new wire and swap transformers, then drill and tap.
The second issue is connecting the new neutral wire. There isn't space for a double lug where the current neutral connects, so I'm thinking of using a split bolt. I.e. strip the insulation on the old neutral, then use a split bolt to connect the new neutral to the old neutral. This is something else that I'd wait for the power company to drop power for. Is there a better solution?
Sorry about the size of this picture but it's not immediately obvious to me how to shrink it. So, if you reply to this, please take pity on those folks with slow data connections and strip the picture from your reply.
- How to anchor the new breaker
- How to connect the new neutral
