Garage 30x40 Superior Walls - precast concrete
tstealth32
South NJ
Starting my garage build!
Ill be using Superior walls. I've seen people talk about building a garage with this system, but haven't seen anyone actual do it.
I cut down some trees to make room for the garage.
30 X 40 garage.
10' wall height
8/12 Roof pitch
Front doors are 10x8
Rear door is 8x7
windows 3x4
1 man door. Might be adding another on the right side.
90amp subpanel
I'll be laying radiant heat in the slab and adding mechanicals later down the road.
I'm going to go with storage trusses on front half. and scissor trusses on the rear. Plans for a lift down the road.
I decided it would be best to put the 3rd garage door at the rear. This will allow me to expand the garage down the road without knocking out concrete.
The lift will most likely go in the rear right corner by the garage door opening.
Then I could have a desk and seating in the rear left by the windows.
I'm thinking no windows on the right side of the garage, it only faces a fence and also gives me more wall storage. The sun rises in the rear left of the property, sets in the front right.
Mockup pictures to come.
T
tstealth32
South NJ
Here are some renderings. The walls will be concrete, but this helped me get a feel for what it will look like on property.
T
tstealth32
South NJ
A few more.....digging starts soon.
Jackie Treehorn
Interesting, is it a kit where you order the walls and they ship in? I'm planning on doing icf for my house and most likely a stick build for the shop, but your precast walls piqued my interest
T
tstealth32
South NJ
The company designs the walls with you, then they ship them on a truck and use a large crane or track vehicle to put them in place. They do all the heavy lifting.
The walls will be above grade. So I need to provide them with a level pad of clean crushed rock. The subbase is 30" deep and 3' wide. They set the walls directly on top of this and they bolt it all together.
The walls come with the headers and frame out for the garage doors/windows/door. You just tell them the size of the openings.
T
tstealth32
South NJ
I was quoted 13,500 for 30x40. 10' walls. And an additional 1k for the track lift because I can't get a crane in the back yard.
T
tstealth32
South NJ
Here is the layout and specs for the pex heat. Sent the sealed drawings for the walls and trusses to the city. I start digging at the end of the month!
T
tstealth32
South NJ
I'll upload better pictures tomorrow if I can.
I picked up a couple of nice Anderson windows on Craigslist that someone had ordered the wrong size. Built the openings to accommodate them.
The rear garage door by the lift is an insulated steel roll up door, this way it won't interfere with the lift or get in the way. It's 8 x 7. Sandstone in color. Same with the windows and the front garage doors.
Riley
This is a neat idea that I'm interested in following along with. As you mentioned, I've not seen it done on a residential build. Cost wise seems pretty decent for a termite proof, rot proof, practically weather proof shell. Can I bother you with a few questions about how it goes together once the shell is up? Wall thickness? Insulation? Electrical - all surface mount? In conduit? Overhead - trusses I'd guess? Pretty good pitch; storage above? Door hardware mounting - Would you lag a header to the walls then attach to that? I'd guess you'll be getting to these as you go though it would be handy to have a summary in advance is it's not too much trouble. Thanks in advance!
davo727
Ok im confused, you said precast concrete but the renderings are of stickbuilt.
T
tstealth32
South NJ
Yeah, sorry, that was just for a general idea on size and layout. I used menards garage planner to see what it would look like in the backyard. It really helped give me a better idea of the foorplan, instead of 4 windows, i'm just going with 2 windows on one side.
T
tstealth32
South NJ
A lot of those questions are located here ..... www.superiorwalls.com/tech_resources
The cost is about the same as if you finished a typical stick build.
Wall thickness : concrete Shell is 1 3/4" with concrete studs 2 1/2" concrete studs @ 24" OC.
Insulation : For the XI wall - 2 1/2" xps foam. Fire rated so you don't have to drywall over if you don't want to. You can add extra foam if you want, but will then have to drywall over it.
Electrical and plumbing - Galvanized steel studs are molded into the concrete. So you run your electrical and plumbing as you normally would.
Roof- You attach a 2x10 pressure treated board to the top of the walls after. They provide the 1/2" x 2 1/2" Bolts to secure your top plate. Then the trusses and truss ties attach as you normally would.
Pitch is 8/12 asphalt - I have ordered 17' of attic trusses, the remaining will be scissor trusses. The attic trusses will have an opening of 8' high x 12' wide. I plan to store the air compressor, hvac equipment, and auto parts up there. And also throw a couch and tv up there to get away.
Door mounting - The quote with the walls includes all the wood framing. So your overhead garage door beam will be there, all your windows will be framed with wood and man door. You just attach everything as usual. Makes it very simple.
Concrete floors - The walls include steel ties that you bend down when you pour the concrete. This ties everything together. Then you can throw on the roof, then backfill the outside of the walls.
Siding - You have the option to add furring strips at the time of the casting so they are already attached when it gets delivered. It comes with a knock down texture that really nice, and ready to paint.
Making holes - There is guidance on if you wanted to add a door or window after your walls have been set. As far as running electrical from inside to outside, you go through the bond beam between the panels (basically caulking) You can add larger plumbing holes with a hammer drill in between the concrete studs.
Subbase - The walls include the concrete footer. You just need to lay down a subbase of 3/8 clean crushed stone. Since it's a garage and above grade walls, your stone has to go to the frost line, here in South NJ, I have to do 30" deep and 36" wide. compact every 8". You can use a different stone for under the slab, but the 2' inside the walls, has to be 3/8 clean crushed as well, then you can transition to whatever stone you want.
Deezler
Southeast MI
Very interesting to use superior walls totally above grade like that. As typically, they are a foundation-wall replacement.
4 years ago we had our superior walls installed for our rear/north home walls. Superior walls was very nervous about us backfilling until we had the slab poured, and most of the interior walls and roof built for some additional bracing. It seems the wall system on its own doesn't have a lot of resistance against bowing in or out. I guess your walls will be tied across by the roof trusses though. Good luck!
lqT6Sh8SqKspjY0YUJiGlexZherbjKoRi5xINu0s2yfpTDEgyGQey0QZyQ8GFW6zMwsTLC68n9BCz2_w5blnYQu6-JqJRWfVrg0378S270oxIg2cko59F0dWaYBxfjZeJydOdJ_NNsxI6rTxuOobqxvn-kra2klF8VsK4ssyXDS603T_RcqwdqwNJpJRC_LFhBZqkMvZQ5SGm706VXNJnqbUxkqM0-_XcfppK5PEACwT2rFf4Gbi7VPJbV_CgiomgbKsAtAtbrawYm3p2e8Wn0D0KgpSKhCYN3u_PZwWTIjnSxFjseapHPsgbQfcC26BV-pKFqIttyvUe_j27Z_su3CNEQMRyyX5s_vEjjcGhYORL3M79dc0TEu0aoe9Kpr-4CrWVPfIHXJxPIw1WqIVb4hGsjOdLy5Teo9PZOk0S47PevSQTATjYNIihleRhEte4_Rvr7NQIK5wp-ZyO1SAi9kxwTzBgyhy3l0l3ELcsOEH5W2wSaHSTw25nubzkijZ3bB1N1HeG1RWLsqSx9V6vS0pcYC3EmIGUYG6_NzpBM4NAlXZbV6rrkM2tvTC0Z8LprQGIH4XAIjwYT4Lzyox8ylXJ_1227ZdwLgWzWmxMo3lSR90gOa4LWvxZeFxY1gblk60XtmKZMHYI_rez4r4ym1g=w977-h733-no
NWw-hl1aXQpovyEOxRUwlwVHr_fPKvJeclpJgo8SnlGDLz0CYU4jrtsfz_VYCvwNXNLvhl6jzqOF2RpSwjXaHA073W29bNIwuNQ4JkkCnOQB2BWIigpeDsCv4oZCJ2aKTMW3qOlZkrmweadxCxkxINVjPiQ6NNSagzBlvX2_fwTS3Y5R6F0dMVs6b-sXDO-WciLbEIbdfCUBWT-kCbbAhK_H0f4WW87BnnX4y-0fbF8uZrFTj3ZYVngNTQW_nDqFeZG9EC1wxH3-SAAlbItDjGwLYkNn0e2cEH_ii8-aIl73nwy_mWvPht0V-U4BU-9UFTNxPdxJn-0qmTDoTcDbFKIJvUhs28F99dI5uEgS7s32pUz5DIZs6Fhixo57ZKUPXkQqKz_ax0DghvfF4x0ShqDNP9HCw2QdzG_Er6B-EnO_qs4QsJeYec9mv4os02ohDVfKJ8IA-MWnsojj-YcWt0fKsEE54FDTZDmKTeO2DYOW00Te4PiMNJBTJGTbO1-kt2gLT_tGtn7hifkQOLNWR7q3T38R6KPMhLSN69a_QN7iltcSjHdNCV83gcNyv_bcdspPjnVXsUGwkvPmjEDX6GS3foYxkkSijfLfo_4KjhRrZESFojGwPLZlEEZOjPqTD_QHW6VlBYXZACvb05xCehBm=w977-h733-no
Rockcam
Grand Rapids
I used Superior walls for our house and garage foundation so far we've been really pleased.
Just the tops are above grade.
Tstealth, the info you posted above all seems correct. They did our entire house and 24 x 45 garage in one day IIRC. Quite something to watch with a big crane to get them into place.
ConCretin
Central Maine
This should be interesting.... How much frost do you get down your way? I assume that the working theory is that the 30" of stone under the panels provides the frost protection? I'd want to make sure the frost doesn't get under the wall and lift the slab. Will the exterior concrete face be left exposed? Please keep us posted!
T
tstealth32
South NJ
They say the 30" will protect it from frost and heaving. You'll also backfill once the concrete floor is poured and trusses in place, that additional soil should be enough protection from frost.
Riley
Thanks for the link and info. Nice they have a good resource library available. Looking forward to seeing it come together.
wasfast
San Diego CA
I'm a fan of prefab in general but wasn't familiar with this company. Sadly, I live on the wrong coast and they don't service this area yet. There are some real advantages to what they make for below above options. I'm sure cost isn't the lowest but the quality and speed are worth it in some cases
Deezler
Southeast MI
Actually the costs of superior wall systems are quite comparable to conventional poured concrete walls, IF you consider: Superior walls are 6000psi concrete, and thus require no exterior damp-proofing, are already R12.5 insulated, and already have usable framing studs on the interior. They definitely cost more than the raw concrete, though.
T
tstealth32
South NJ
Digging started. Have to wait for the ground to freeze to bring the rock in.
jkeyser14
(rural) Maryland
I looked at these walls for our basement when building our house since it would have saved significant money. I ultimately chose against it because I was worried about leakage at the seams when used below grade. For an above grade application like this I can see a lot of benefit. I am eager to see how your project turns out.
T
tstealth32
South NJ
Well the work is starting again. My big issue was waiting for the ground to be dry and firm enough for the rock trucks to get into the back yard.
Excavation starts in 2 weeks. And the walls should be set by early September.
T
tstealth32
South NJ
2 more trucks showed at 5:50am! 2 loads to go.
T
tstealth32
South NJ
And the grand total: 94 Tons of 3/8 stone!
T
tstealth32
South NJ
The first layer of rock is down to level the ground. Digging the 30" x 36" trenches tomorrow.
T
tstealth32
South NJ
Too much rain today to start digging. So I picked up factory seconds XPS 2" foam. Drove 1.5 hours to Baltimore and back. Half price! No detects, it just came out the wrong color.
T
tstealth32
South NJ
Digging the trenches for the 3/8 stone.
T
tstealth32
South NJ
The trenches are dug and now are being filled and compacted with the 3/8 crushed stone.
Also have a confirmed wall set date for September 6th!
T
tstealth32
South NJ
Day 3. Excavation for the walls is complete. The 3' wide perimeter is level for the walls to be set.
Set day has been moved to Wednesday. I'll try and post a video lapse of it.
T
tstealth32
South NJ
Morning delivery of the walls.
