Why does SK struggle w the concept of wrench length?
Ign
Butte Peak ND
I recently got SK set 86041 "long pattern" metrics.
I was quickly reminded of my other SuperKrome wrenches (which were never much to write home about) and how SK runs short.
In the pic are US Craftsman RP's against the "long" SK's
Note to self: long pattern SK = pretty much normal for everyone else.
bimmer630
[emoji23][emoji23]
This is true isn’t it
bimmer630
I got rid of my standard length sk wrenches years ago because the open ends would slip easily. I still have some sk in 21-24mm sizes but I’m not a fan of their smaller wrenches
I
Ign
Butte Peak ND
OTOH here's a long 13mm which is legit IMO. Remember, this is a 13mm so MUCH less torque generally required and the SK long here truly is plenty long - almost surely enough for a strong guy to break any fastener using a 13mm hex head.
I
Ign
Butte Peak ND
The wrenches are beautiful and proudly stamped USA but they need to produce some **** we can be proud of as Americans. Chrome don't get ya home.
bimmer630
[emoji23][emoji23]
I bought 21,22,24 mm sk wrenches years ago thinking they were “normal” lengths, but this 88521 comes up on their page as “long pattern”
Shown next to my “short pattern” 21mm, and a normal length snapon 19mm
Strange indeed
sweet victory
USA
I share the same experience as you. Really not a fan of SK's wrenches after owning the 6-22mm long patterns. They were brand new and rounded off a few smaller fasteners using the open end. Switched to flank drive plus wrenches and absolutely love them. I also have Wright sure grips at work which have been great!
Andres26tnt
They don't struggle, just their way.
They do struggle with bringing new products to market, however.
totally agree, lets see no LP90 1/2, 1/4, flex heads and bent handles. The x frame wrenches also only come in one flavor, and no flank drive/max drive whatever you want to call it. Not bashing SK they just don't have variety so you are forced to look elsewhere.
bob15
Northeasten, CT
No issue with their "long" wrenches. Why must it be the longest out there? Actually, super long wrenches can be a PIA as well. All depends on what you are working on......
WWheeler
Middleofnowhere USA
I've never had one of their 'long pattern' but their regular length does run shorter than any other I have. Just a little shorter than a Craftsman RP. The shorter length can come in handy sometimes, but I generally prefer to use the longest wrench i can get away with.
dan360
WA state
SK's wrench length is based off an ISO standard that was written sometime ago IIRC. There is also an ANSI standard regarding wrench lengths to 'provide configuration control for tool storage applications."
Spacey_G
I have the SK long pattern and Craftsman RP metric sets too. The difference in length is more significant through 19mm than with the larger sizes shown in the OP. The 13mm pictured later is more representative.
The only length-related issue I see in SK's wrench lineup is that, imo, the least desirable of the three is presented as the standard length.
Wamsutta
Amarillo, Texas
That's how they save money and make a profit ... by short changing you on length.
When you're ready to step up to real wrenches, let me know; I can provide the part numbers. :D
bimmer630
You’re Wright about that...
xin
ARKANSAS - NWA
Bought the LONG Pattern 7mm-19mm SK Metric Long time ago, along with their 1/4 and 3/8 chrome sockets/ratchets.
Them wrenches are nearly 25 years old and still in great shape and they have been used a LOT.
sk farmer
nd
i really don't get you guys. sk makes three lengths of wrench when many brands make only one. every spec is available online. for comparison before you buy.
fail to do your homework and then blame sk for it. makes no sense to me.
i find it very beneficial to have a variety of lengths and brands as every brand has a slightly different bend, angle or length to them and some time times of them may be just what is needed to fit in the space. any of you who actually use a tool will know this rather than just bitching about one feature that doesn't meet their narrow definition.
i have sk, sk made craftsman, bonney, matco, mac snap-on, wright and a half dozen other quality brands. i have no problem using any of them that fit the situation at hand. some are slightly better and some are slightly worse but none of them have any special, magic pixie dust that makes them vastly better. anyone who tells you otherwise is more than likely injecting opinion over fact.
Sloper0204
UT/WY
:thumbup:
That is my opinion as well. :beer:
cliftonbros89
Missouri
I’ve never had a problem with SK wrenches. But I also haven’t been that much in need of a “long pattern” wrench necessarily. There’s only a few times I’ve needed an actual long wrench and I bought a wrench just for those specific instances.
I get why someone might be aggravated if they’re advertised as “long” but for SK that is long. As it’s seen obviously in this thread and many others a “standard” length isn’t actually a specific length. I have several brands of wrenches and the lengths all vary. I’ve just always checked one sizes of things before I’ve bought them. That’s the good thing about tool catalogs. A lot of them with give you specs on the tools.
highland512
Somewhere near a cornfield
I thought the Snap-On truck sold magic pixie dust :bounce:
Why are some guys always so concerned about the length of things?
sweet victory
USA
Has anyone compared SK long patern wrenches to Snap-on regular wrenches?
Yes. I've owned both at the same time. The SK long patterns are roughly the same length as a normal Snap On wrench. I much prefer the Flank Drive Plus Open end. I also have an SAE Wight Sure Grip set at work. Those are also excellent wrenches. The Wrights are also far better and I would say are on par with the Snap On's. When I find myself needing something longer, I'll switch to a SO high performance zero offset wrench.
bimmer630
Strange indeed
I sort of did, earlier in the thread
Spacey_G
So is the takeaway here that SK makes combo wrenches whose lengths are on par with other quality brands, but they also make shorter lengths and sometimes people get burned by the naming convention?
BDT/NWMN
Erskine, Mn
Yep, that picture is worth a thousand words. Best to ask the S-hort K-id how tall He is if needing a tall one. Add Me to the group who own multiple tool brands in order to take advantage of the length variations. SK included. :beer:
sweet victory
USA
I didn't mind the naming convention for their lengths. Where they really fall short of every other modern tool manufacturer is the lack of some sort of "flank drive plus." Just about every other major tool mfger offers this feature.
Mgdoug3
KY
Send me any of your crappy SK tools. I'll dispose them properly.
Wamsutta
Amarillo, Texas
Is that SK 5/8 their standard length?
Gmonkee
Consumer expectations grew. The standards are just fine and have been for decades.
So a trend the last years is everyone vocal is clamoring for a longer flex head ratchet and ratchet wrenches.
When 21" quarter drive ratchets are made everyone will be bitching the drive lug breaks off when used in hard pulls.
duh...
That is exactly why they are mostly made short.
Open end wrenches the same issue. Balance the hardness of the steel for reduced stress flex stretch and brittleness then extend them the formula changes. Now the end needs to be lobster claw or it mushes up fasteners.
Change a material or process and the price goes up and still the vocal minority are unhappy.
Don't like the offerings buy something else you do like. Its not science.
hangfirew8
Central Maryland
Not this again. Does Adam.C have another account? He harped on this topic constantly. I see now he's banned. Don't miss him.
SK makes kinda short regular wrenches, just as short as all standard wrenches used to be made. And "long patterns" that are longer but not as big as Snappy. Don't like it, don't buy them.
My opinion is that people with full vehicle lifts like longer wrenches, and those of us on our backs don't/can't use them as often.
I have regular and long pattern SK's in Metric. I have not had a problem with the open ends spreading. They get the work done job after job. I'm just a DIY guy so what do I know? My radiator, my brakes, my exhaust, my spark plugs, my oil plug, none of them care what brand of wrench I used.
BTW Wright's have the box end point in-line with the wrench, making them useless for tight automotive work. I don't feel the need to point that out on every thread, or start a thread about it. My SK's don't have that problem.
bobcatdan
Kaukauna,WI
I have no complaints with SK wrench lengths. Granted I use them as topper kits to my snap on on and mac wrenches, their sizes are on par. My 1 /16" SK is longer than my 1" snap on.
