My Small But Growing 1/4" drive Socket Set Collection
A thread dedicated to the awesomeness of the vintage (and not so vintage) 1/4" drive socket set. Of course, your 9/32" drive set would be perfectly appropriate here as well.
We've got threads for double-end box wrenches and open-end wrenches. We've got threads for ratchets and screwdrivers. We've got threads for Bonney, Plomb, Proto, Craftsman, and S-K. I just noticed somebody recently even started a thread for Wizard!
After some serious in-depth consultations with other more knowledgeable members and careful thought, I feel it's only appropriate that there should be a thread dedicated to the small and oft-underrated 1/4" drive socket set.
This being the "Vintage" forum, I feel it only appropriate to try to start at the beginning:
Sedgley 8-pc 1/4" hex drive "Hexall" SAE socket set
Reginald F. Sedgley pretty much led the pack. His 1918 patent (patent 1289558) was used later by New Britain and others under license. Later Sedgley got out of the tool business and started doing custom work on firearms, for which he's much better known.
R.F. Sedgley 'Hexall' 1.4 hex drive SAE socket set - (patent 1289558 Dec 31 1918) 01.jpgR.F. Sedgley 'Hexall' 1.4 hex drive SAE socket set - (patent 1289558 Dec 31 1918) 02.jpgR.F. Sedgley 'Hexall' 1.4 hex drive SAE socket set - (patent 1289558 Dec 31 1918) 03.jpg
R.F. Sedgley 'Hexall' 1.4 hex drive SAE socket set - (patent 1289558 Dec 31 1918) 04.jpgR.F. Sedgley Hexall Socket Set - Hardware Age - November 25, 1916 pp 98.jpgR.F. Sedgley Hexall Socket Set - Patent 1289558 - Dec. 31 1918.jpg
F
New Britain "None Better" model 177 8-pc 1/4" hex drive SAE socket set with stamped steel holder.
The "ell" handle is stamped "Made in U.S.A." on one side. The other side is stamped "Pat. Dec 31, 1918" - the patent referred to on the "ell" handle is Reginald F. Sedgley's patent 1289558 (see post #1 above for an example of Sedgley's "Hexall" hex-drive set.)
The holder is stamped "Patented Dec. 12, 1922" - this refers to patent 1438900 issued to one H.H. Chase, and was used by New Britain Machine Company on a variety of different socket holders for a number of decades.
(* As I was not able to get clear images of all the details described above, I have posted a few of the photos from the Ebay listing from which this set was purchased as well. *)
New Britain - None Better 177 8-pc 1.4 hex dr SAE socket set (pat 1438900) 01.jpgNew Britain - None Better 177 8-pc 1.4 hex dr SAE socket set (pat 1438900) 02.jpgNew Britain - None Better 177 8-pc 1.4 hex dr SAE socket set (pat 1438900) 03.jpg
New Britain No. 177 8-pc 1.4 hex drive SAE socket set (Ebay 332574079385 03).jpgNew Britain None Better No. 177 8-pc 1.4 hex drive SAE socket set (Ebay 232677876043 04).jpgNew Britain - None Better No. 177 8-pc 1.4 hex drive SAE socket set - 1937 W. Bingham Co. catalo.jpg
New Britain None Better No. 177 8-pc 1.4 hex drive SAE socket set (Ebay 232677876043 03).jpg
(* There is a detailed description of this particular model at Alloy-Artifacts.org HERE: http://alloy-artifacts.org/newbritain-nonebetter.html *)
F
Indestro 350 "Vest Pocket" 8-pc 1/4" hex drive SAE socket set with holder (Patent 2065340)
The top one is the earliest version - the "ell" handle is stamped "Pat Pend"
The lower one is a later version - the "ell" handle has the patent number stamped on it.
Versions made later had both the part number and patent number, as well as Indestro's name, stamped on the bottom of the stamped steel holder. (see post #5 below)
(* Note that the earlier (upper) set does not contain the correct assortment of sockets *)
(* Note that the 1948 catalog snip shows a different patent number - 2065341 - which was essentially the same design but with the retaining tabs reversed. I have yet to be able to find a copy with that patent number. Oddly, the 1948 catalog illustration shows a holder identical to both those shown here. *)
Indestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set (pat 2065340)(early top)(late botto.jpg
F
Indestro 350 "Vest Pocket" 8-pc 1/4" hex drive SAE socket set with holder (patent 2065340)
(* for some reason all the photos would not upload to the same post *)
(* catalog snips from the 1937, 1948, and 1959 catalogs *)
Indestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set - 1937 Indestro catalog pp 34.jpg Indestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set - 1948 Indestro catalog pp 25.jpg Indestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set - 1959 Indestro catalog pp 38.jpg
F
This is the third (and last) iteration of the Indestro 350 "Vest Pocket" set, having no markings on the "ell" handle, but both the Indestro name and patent number stamped on the bottom of the holder.
Indestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set 01.jpgIndestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set 02.jpgIndestro 350 'Vest Pocket' 8-pc 1.4 hex drive SAE socket set 03.jpg
F
G.M. Manufacturing Company 1/4" square drive SAE socket set in plastic box
G.M Mfg. Co., 1308 43rd Ave., Long Island City, N.Y. / http://progress-is-fine.blogspot.com/2014/02/vanished-tool-makers-gm-co.html
This set (and the sets in the Ebay photos just below) should answer the question of who made the strange 1/4" drive "Frankenstein" ratchet. Note that there was also an Asian-made knock-off very similar to the U.S. made model by G.M. Mfg. Co., but every example I have seen is a two-piece design in which the shank unscrews just below the drive head.
G.M Mfg. Co. 10-piece 1.4 drive SAE socket set 02.jpg G.M Mfg. Co. 10-piece 1.4 drive SAE socket set 03.jpgG.M. Mfg. Co. 10-piece 1.4 drive SAE socket set 01.jpg
(* The two photos below are from other Ebay listings and are only to show examples of the "Frankenstein" ratchet *)
G.M Mfg. Co. 10-pc 1.4 drive SAE socket set (Ebay 132357996814 01).jpg G.M. Mfg. Co. 1160 12-pc 1.4 drive SAE socket set (Ebay 332505558902 01).jpg
F
RTEC - Randolph Tool Equipment Company 1/4" drive SAE socket set
Randolph Tool Equipment Co. 1.4 SAE socket set 01.jpg Randolph Tool Equipment Co. 1.4 SAE socket set 02.jpg
Randolph Tool Equipment Co. 1.4 SAE socket set 03.jpg Randolph Tool Equipment Co. 1.4 SAE socket set 04.jpg
(* Shown below are two photos of the RTEC sockets lined up next to their contemporary era New Britain counterparts. Although the knurling appears quite similar, the broaching is obviously quite different. *)
RTEC Randolph Tool Equipment (top) New Britain Machine (bottom) 01.jpg RTEC Randolph Tool Equipment (top) New Britain Machine (bottom) 02.jpg
F
Proamerica 1/4" drive SAE socket set in KAL box
(* This is the first Proamerica set I acquired. Proamerica is KAL's new name for consumer products. The KAL branded product that is still produced is strictly military/government contract stuff. This one has a couple KAL pieces in it (as well as having come in a KAL box.)
No idea why the plating oxidized so badly on the spinners in this set - none of the pieces look like they've ever been used. This was a contract-produced set for the military - the NSN number says it's a "small arms repair kit". *)
Proamerica 1.4 dr SAE socket set 01.jpgProamerica 1.4 dr SAE socket set 02.jpgProamerica 1.4 dr SAE socket set 03.jpg
F
Duro Chrome / Indestro "D I" 1/4" drive SAE socket set in New Britain / None Better box
(* This is, as near as I can tell, kind of a mish-mash of old Duro Chrome and Indestro - all "D I" period stuff - inexplicably in a "None Better" box that's in really great condition. *)
Duro Chrome Indestro 1.4 dr SAE socket set (New Britain box) 01.jpg Duro Chrome Indestro 1.4 dr SAE socket set (New Britain box) 02.jpgDuro Chrome Indestro 1.4 dr SAE socket set (New Britain box) 03.jpg
F
JS Technology 1/4" drive SAE socket set
(* JS Technology Inc., Alpharetta, Georgia - contract supplier for military/government. As with the KAL/Proamerica sets above, the NSN number calls this a "small arms repair kit". I do not believe that JS Technology actually manufactured any of these pieces, but I've never been able to figure out who the OE supplier was.
Some say S-K, but that Kilness-type clip ring on the drive side of the head certainly doesn't look like any S-K ratchets that I own.
Fit and finish on these is fabulous. I think I have three of these sets - all appear to be unused. Really nice action on the ratchet - similar feel to the 2426 Wright. *)
JS Technology 1.4 dr SAE socket set 01.jpgJS Technology 1.4 dr SAE socket set 02.jpgJS Technology 1.4 dr SAE socket set 03.jpg
F
Mustang 1/4" drive SAE socket set in slide-top steel box
(* Made by New Britain Machine as a "price point" line. Cadmium plated. Note the wonky slide-top box. I did find a Mustang ratchet in a 1/4" drive, but the box is too small for the ratchet to fit in there. I'm guessing this was the low-end 1/4" drive set in their product line-up. *)
F
Truecraft U.S. made 1/4" hex and square drive SAE socket and bit set with reversible ratcheting driver handle in blow-mold box
(* The sockets are all 1/4" square drive. The bits are all 1/4" hex drive. The reversible ratcheting driver handle (with a storage compartment in the handle) and all the sockets are marked "U.S.A.". The bits have no markings other than their sizes. *)
Truecraft 1.4 dr SAE socket set 01.jpgTruecraft 1.4 dr SAE socket set 02.jpgTruecraft 1.4 dr SAE socket set 03.jpg
F
An early New Britain Machine Co. 1/4" drive SAE socket set in the original box.
(* These are "C" series and stamped "Chrome Vanadium" with the "NB" logo inside a circle.
New Britain 1.4 dr SAE socket set 01.jpg New Britain 1.4 dr SAE socket set 02.jpg
F
A Penens Corp. 1/4" drive SAE socket set in the original box.
The larger sockets are stamped "Challenger" as well as "Penens". I think it would be reasonable to assume that the smaller sockets were not stamped with both names simply due to space limitations.
Penens Challenger 1.4 dr SAE socket set 01.jpgPenens Challenger 1.4 dr SAE socket set 02.jpgPenens Challenger 1.4 dr SAE socket set 03.jpg
