IQRaceworks
I've had my Quincey 325 compressor for around 5 years no (bought it used and rebuilt it). I've always ran straight ND 30wt oil in it. During the summer, it's great....fires up, builds on pressure in a few seconds, and runs great.
But in the winter when the temps in my shop are down around freezing or below, whenever I would go out and turn the compressor on, the oil was so thick it would really tax the motor trying to turn the pump, and it would run for a good 30 seconds or so before it would start to build oil pressure.......the oil is go thick it takes a while to get it through the system.
So I recently changed the oil over to Mobil1 0W-30 full synthetic. Wow, what a difference. When it's warn out it instantly builds pressure, and this morning when it was 13 degrees out, it fired right up and made oil pressure almost instantly. I'm very impressed.
Now I know people say that if you run multi grade viscosity oil with detergents in it (pretty much all automotive oils) it's bad for the compressors because the particles in the oil don't settle out in the sump, and if you don't have an oil filter (my 325 doesn't) it's bad for it.
Well, the way I look at it is like this.........what's worse, running with NO oil pressure when it's cold out, or getting instant oil pressure? For someone who doesn't use their compressor very much (probably less than 4 hours of run time a year)...I think it's a good choice.
So....anyone else run this in their air compressors?
