10mm Wide Nut with 1/4-20 Thread
sbosecker
Peachtree City, GA
I think the thread title says it all...
I have at least a dozen 1/4"-20 nuts in my fastener collection that need a 10 mm wrench to tighten them. The second picture is a brand new 1/2" long 1/4-20 bolt (7/16" head) with the said nut screwed onto it.
What's up with that?
Has anyone seen this sort of FrankenNut before?
I discovered these oddities today when I raided my fastener cabinet to put together a project. (Post 2703 on this PAGE.)
Scott
LXCam
Are you positive it's not 3/8"?
I've seen SAE one size reduced heads many times which is why I suspect...
GRB
SoCal
I keep 1/4-20 nuts on hand with 3/8" and 1/2" as well as the USS standard 7/16" across the flats.
10mm is less than 0.020" larger than 3/8".
Show7d3
Years ago I bought a cheap bolt assortment and the 1/4-20 x 1" bolts have a 10mm head on them :headscrat. Do you want some oddball bolts to go with your hybrid nuts? :)
sbosecker
Peachtree City, GA
sbosecker
Peachtree City, GA
Sounds like they aren't really 1/4x20 but actually M6x1.25
GRB
Forgive me if the following comes off as bellicose but I don't know how else to ask the question...
Are you speculating that it is a M6-1.25 nut or have you personally seen a M6-1.25 nut threaded onto a 1/4-20 bolt?
Best regards,
Scott
bigguns69
Iowa
Yes 1/4-20 will work with the metric equivalent. Fixed a lot of motorcycles when in a jam, this way. It is probably a metric fastener.
danielbuck
sometimes odd stuff happens and slips through the cracks.
I remember once at an ace hardware they had a box of grade 8 1/2-20 bolts that would not thread on to any 1/2-20 nut. I returned the bolts only to realize in the store that the entire box of bolts was that way. The next box was fine.
sbosecker
Peachtree City, GA
A couple of weeks ago I ordered a couple of M6-1.25 machine screws to test the "It's A Metric Nut Theory".
They finally arrived today. It is worth pointing out that these screws - or the updated part number CCBB-2PB - are advertised as having M6-1.25 threads in multiple locations on the internet.
I opened the package and tried threading one of the mystery nuts onto one of these machine screws. I really thought it was going to work but the nut threaded onto the screw and then stopped...
...right at the same position it had stopped threading onto the M6-1.0 screw.
At first I was thinking, "Well, that's that I guess. It's a 1/4-20 thread and not metric." Then I realized how weird it was that it stopped threading onto the screws at the same place as the M6-1.0 screw.
I got my metric thread gage out and...
...for Pete's sake. These screws aren't a 1.25 pitch; they're a 1.0 pitch. No wonder they stopped threading at the same place as the M6-1.0 screws I had already tested the nut with.
Back to looking for another M6-1.25 screw to test the "It's A Metric Nut" theory.
Scott
plinker
Northern Wi
I've run into some hardware that is 1/4 thread with a 10mm hex, mostly with some semi truck accessories (plastic fenders, IIRC) and cheap build it yourself type stuff.
DFB
Southern VT/Western Mass
Can't you like just go to a decent local hardware store or a tractor supply they usually have boxed inventory with assorted sizes. Makes life easy just as long as someone hasn't mixed up the parts in the little compartments. :lol:
Maybe I didn't read thru this well enough but if two nuts stopped at the same place on 2 different bolts my first thought would be is there a problem with nut's thread. Too bad you don't seem to have access to a thread chaser kit or tap and die set to easily assess the internal thread. :(
On a side note with "odd" fasteners I have one each the plastic boxes of assorted fasteners, nuts and bolts from the Harbor Frieght that I gleaned off my tool table and opened up to repair some pop up canopies, seems the fasteners often times fall out on people from transport or constant opening and closing. Anyhow I went to these boxes to see what I could discern with the different threads to relate to this post but was no 6 x1.25, just 8x1.25. But after looking thru them a bit then it turns out the heads on the #8 machine screws really didn't match anything. 11/32's was the closest fit but the tolerance was so loose still didn't seem right and probably would just barely work. :dunno:
At least the thin heads mostly match all the cheapo fasteners you usually get with those different China products like carts and stuff you have to assemble :spit:
Keep us all in the loop with what you figure out :beer:
vavet
Ashland, VA
It is possible to have a sae thread and metric threads, or vice versa. Anything is possible with enough money or sufficient quantities.
I think it’s a cruel and unusual truck to play on the person who will eventually work on a given device.
I’ve seen it on bowling equipment where the equipment design hasn’t changed much in many decades, but it’s now a globally marketed piece of equipment. Sae tools are not readily available in all countries, so they keep using the same threads, but use a metric head.
