Needs recs for new workbench mitre saw
wahoowad
I need a new mitre saw for my workshop. My existing one is old, been abused, broken safety features and basically an accident waiting to happen.
I'm not a serious woodworker and suspect any modern models will exceed my expectations, so basically looking to get one that is a good deal for some of the desirable features. It will sit on my workbench so no need (or room) for a stand.
Suggestions? A holiday mega-deal would be great.
Thanks!
NUTTSGT
Northern Central Ohio
Since it's so close, I'd start looking through the Black Friday ads and see what's going to be on sale and where. That's where I would start looking.
W
wahoowad
Would like some recommendations. I see some of those black friday models, we have a Lowes nearby. While my needs are simple I don't know if the cheap Kobalt models are ****. They certainly are budget priced. Probably more than adequate for my needs.
NUTTSGT
I originally bought a CMan years ago with a brake, didn't last but a few years. I said heck with it and bought a 10" Dewalt and have no complaints about it. I'd have to look at it for the part number.
EDIT: Dewalt DW713 10" compound miter saw.
Jackfre
N CA
First decision is compound miter or a chop saw? CM are nice but pricier and need move depth on the bench. You can probably get a larger chop saw which will give you pretty good capacity for less dough than the CM. I can't make a brand or model suggestion as I haven't been in that market for quite a while.
IMStuner
I have a Ridgid 15 Amp 12 in. Dual Bevel Miter Saw with Laser which served me well but it's not sliding. It's also gear drive not belt. I purchased it for 249.99 and it has a lifetime service agreement.
W
wahoowad
I have never done a compound miter cut so don't think that is necessary
4xdog
Santa Fe, NM
I've been completely happy with the Bosch GCM12SD 15A 12" dual-bevel miter saw from Costco a few years ago. Not the cheapest, but, man, it makes a clean cut.
PS: And to my surprise, I did need to make some compound miter cuts as I replaced some trim on my garage!
Voi
Western South Dakota
I think Jackfre might have meant a sliding miter saw instead of compound miter saw.
What sort of capacity do you need? Is it more important to cut a 4x4 in one pass or a 1x8 in one pass?
Sliders are nice but are more expensive and most require some space away from the wall for the rails. There are sliders that hug the wall but they tend to be more expensive.
MoonRise
You have to think about some questions and decide what you want. :lol:
10" vs 12" ?
Just miter capability (do they even make them anymore :lol: ) or compound bevel?
Slide or just 'chop'?
How much cut 'capacity' do you want/need?
Some of these questions are inter-related too.
Two of the 'better' higher-end saw that I know of are the Bosch 12" with the linkage mentioned above GCM12SD and the Dewalt DWS780.
https://mozaw.com/best-12-inch-miter-saw/
And no matter what saw you end up with, you will need a GOOD blade. A 'decent' 12" blade will run you easily $70-$100.
Todd.Brock
Cincinnati
I have a 12” Hitachi compound / Non Slider that I am a huge fan of, Especially for the under 200 price tag. Has done everything I ve ever asked. I don’t need the slide function.
K'ledgeBldr
Johns Creek, GA
I think cutting 4x4 and 1x6 in one motion is max expected.
10" if it will do that.
I'd like bevel but rarely if ever need to do it.
Saw this basic Hitachi 10" at Lowes for only $99 https://www.lowes.com/pd/Hitachi-10-in-15-Amp-Single-Bevel-Compound-Miter-Saw/1000332211
That'll probably do everything you need.
The size of stock would be the first priority as to size, from there it's features. The more repetitive/complicated the cuts- probably more or better features.
With cordless dominating the market for portability- there's that option also. And if I remember correctly, there's a couple that are "duel fuel"- DC/battery and AC/corded. The cordless is really great for those outside projects and running a 100' extension cord does more damage than good to an electric motor.
Voi
eastbaysubaru
NorCal
While I really like the Bosch 4xdog noted above, this looks like a great deal for the type of work you're going to be doing.
https://www.homedepot.com/p/DEWALT-15-Amp-Corded-12-in-Sliding-Compound-Miter-Saw-with-Bonus-Rolling-Stand-DWS779WDWX726/307440108?irgwc=1&cm_mmc=afl-ir-10451-456723-&clickid=RfzRj43TdRPGxpvWYzxUeUHJUkg36eQPFUXgSc0
I've been on the fence for about six months on purchasing a dual compound sliding miter saw and this looks just about perfect. The thing I like about the Bosch though is the sliding mechanism. It doesn't require anywhere near the same space behind it to slide properly as it doesn't utilize the dual-tube setup that the DeWalt and many others do. Just food for thought.
-Brian
finn
The UP, God's country
The Bosch slider doesn’t have tha space hog deficiency issues all the conventional sliders have.
The 10” version is considerably lighter than the 12” version, which may or may not be important to you.
10” is adequate, at least for me.
tthornto
You might find a closeout type deal on a Hitachi because they are rebranding all Hitachi Powertools as "Metabo HPT" as of October 2018.
Augus7us
Central Ohio
The bosch, festool and hitachi all have the space saving sliders.
About ten years ago before I became a tool junkie, I bought a 10" ryobi that was a display model at Lowes for cheap. It has been a champ all this time. I just used it to frame my pole building. Wouldn't have thought it would have lasted this long but it has.
Pops bought the just bought the 12" sliding hitachi and is going to sell me his 10" sliding rigid. Works out because I have a growing collection of rigid tools.
tre873
NE TX
I'll probably be roasted for saying it, but my Ryobi compound miter saw works great. It has a blade brake and laser. I've had it for about 8 years and the batteries for the laser need to be changed. It's already been mentioned, but a decent blade makes a world of difference. Personally, I like the Diablo blades that you can buy at HD.
bobdole4u2
dothan, al
No roast man. I've had a Ryobi saw for 10 years that I bought at a pawn shop and I cut trim with it last weekend. It's been dropped (like 8 years ago) and the handle/trigger broke off and I just taped a push button switch to the back of the motor housing. Still works like a champ.
