28x42 after 2.5 years of remodeling...
imahemi
Omaha, NE
been lurking for a bit now... LOTS of awesome garages here... good thing i didnt find this place before :lol_hitti
well here is my latest pic... i will get some random pics of my progress it took to get to here... and what else is planned... in the coming few days...
-Ryan
and a cool open door shot took tonight :bounce:
I
imahemi
Omaha, NE
time to roll back time to the start of my project...
I have a few thousand pics total over the couple years of my project... but im going to try my best to summarize it... so if I missed something I should have it :)
starting 2.22.07...this is what I started with in my garage project... 24'x28' main with a 12'x28' lean-to style edition (west side)...
3.10.07 I officially started demo...
3.15.07 more progress getting ready to demo wall out...
3.17.07 time for the wall to come out and 2 glu-lams to go in...
3.26.07 wall out, beams in and flat ceiling in on west side...
4.01.07 ceiling insulated, walls and ceiling wired, air lines in the walls, speaker wires in walls...
4.07.07 walls ready for insulation...
Doorway added for future use :)
walls insulated...
4.11.07 west walls drywalled...
6.12.07 project kinda slowed for a bit here...
since the west side was kinda at a halt I decided to get busy on the rest of the main part...
7.06.07 existing walls being striped...
7.29.07 back to the west side... concrete time...
cant wait for the concrete to dry... moving stuff in... lol
8.06.07 main part walls wired, and air lines in...
8.08.07 insulation...
9.10.07 new panel in and ceiling hole getting ready for patch... (note the whole main ceiling stayed as-is because it was already well insulated, drywalled and textured)
I
imahemi
Omaha, NE
cont...
10.13.07 I finally found some help to finish my new drywall... this process went slow as I did it in sections...
10.17.07 painting 1st section...
10.19.07 getting some cabinets hung up...
10.21.07 starting to get cold.. time to get the furnace area finished next...
10.27.07 was able to move the cars around and get the rest of the west side finished and painted...
10.30.07 furnace hung...
10.31.07 cabinets hung, stuff moving in place and furnace exhaust plumbed... in west side...
11.06.07 finished up the rest of the west side drywall and painting...
11.10.07 car ready to be stored for the winter while I finish the rest of the interior...
12.02.07 ready for final area to be finished... and speakers hung up...
12.09.07 ceiling and wall paint time in main area...
12.16.07 rest of the ceiling painted and a shelf for tv with cabinet below...
12.23.07 final update for this year of 07... some signs hung on the walls...
This concludes the main interior remodel...
more to come shortly...
Falcon67
Merkel, TX
Very nice work! That was an effort. The 7-11 sign is a cool touch. I also like the "saw bench" idea - I'll have to remember that.
Doug I
3-17 ..... glue on the beam ....
ok who else writes their name somewhere in their project?
LOL
Nice work !!
I
imahemi
Omaha, NE
thanks all for the comments... I will be adding the rest this evening... check back :bounce:
Looks good.
I wouldn't want PVC as my compressed air line though.
I have noticed that almost know one as the PVC as air lines... but I DID use the thicker wall sche 40 and also I know my uncle also has had his in the walls with no problems for about 15 years
I
imahemi
Omaha, NE
on to 2008... waited until the weather got nice to start back up working...
4.28.08 materials delivered...
5.06.08 area for new posts to be set...
5.10.08 holes layed out, dug and posts set and ready for concrete...
5.11.08 concrete ready... concrete in...
5.23.08 some materials...
5.25.08 shed addition floor going in...
6.07.08 new roof rafters going in...
sheeting going on...
shed rafters going in...
shed part sheeted and finishing up the underside securing...
6.08.08 roof papered... lots of space up here... lol
6.11.08 started removing old overhang and adding clips for new fascia...
6.21.08 gables getting closed in, gables getting fascia, and SHINGLES!!!!
6.22.08 roof started...
7.08.08 shed wall studs up...
7.09.08 shed wall siding on...eventually it will be sided over with steel to match the house...
I
imahemi
Omaha, NE
7.11.08 shed ceiling studs, ceiling insulation up...
7.13.08 some primer... WOW...
7.20.08 shed floor insulated and plywood put down...
7.23.08 shed ceiling drywalled...
7.25.08 finally opened up the shed doorway...
got the roll-up door in, and a deck to step out onto...
9.07.08 posts in for my garage entry way...
9.13.08 rafters for entry put up...
9.21.08 rest of the roof stripped ready for shingles...
9.28.08 shed walls insulated, drywall, and a couple sections of pegboard up...
10.05.08 most of the soffits have the metal on them, one entry wall put up...
I still have some more completed but im lacking pics or finding them...
I will get some overall current pics of the inside of the garage and shed shorty...
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Wow....nice redo of space :thumbup: I'm still kicking it around about removing a wall between my two spaces. If I do, I now have the instructions on how to go about it. One question though and I think it was addressed about 50 pics ago :lol_hitti Aren't you worried about PVC for airlines? At least it's in the wall if something does happen, but in the event it does, what are your plans then? Run all new on the outside of the wall?
Also what made you decide to go with metal studding vs. wood? I know that in my area metal was starting to catch on for a very short while and a few houses were built using all metal, but then it seemed to die out. Maybe due to the economy and steel prices, IDK. Does the metal floor joist let the floor have any bounce to it, as strong as wood joist, or stronger?
I
imahemi
Omaha, NE
GO for it... it easily added more space (kinda) then you would think!!!
I am not too worried about it... the PVC is rated at well over my working wall pressure... I have a reglator that feeds the wall lines... then if I want full range I just connect straight to the compressor... and as noted before where I got the idea for pvc was my uncle which he has had them in his wall for 10-15 years with NO problems..
and also if i do have issues with it and can pin point where in the wall the problem is I will knock a hole in the wall and repair the pvc.
Side Note here: it was 109 pics ago Kevin :lol::D
wood vs steel... hummm
steel personally I would rather work with MUCH easier in most cases here to deal with. my reason for going with the steel was price ;)
now that you mention that the floor does have a little bit of bounce to it... but i really dot think the wood would change that... most ALL of the steel studs used were 18-14 gauge steel... not the flimsy **** from HD or lowes :lol_hitti
I
imahemi
Omaha, NE
That is one nice shop. You have done everything right the first time gotta love it.
Shouldn't be to long til you are useing it.
jhn9840
John
o yeah I have been using it for about 1.5 years now... I am still loving it... ready to add more space though :D
marty_p
SE LoUiSiAna
Your space is 'just right' in so many ways :thumbup:
And the 7-11 and exit signs just seal the deal!
Great addition, too, buddy!!! :beer:
I
imahemi
Omaha, NE
LOVE the toilet sign - I have the same "brand" of urinal!!
thanks guys!!!
as for the seven eleven sign i have had it for years my uncle got maybe 10 or so of the sign and a bunch of us each got one... to bad my clock part stopped working on it...
and the toilet sign I found before my garage edition was even a idea... I just KNEW I would have a urinal :D
I
imahemi
Omaha, NE
is the toilet for real???:lol_hitti
correct... it is for real,it drains into a 5 gallon bucket that has charcoal in it and holes drilled all around the bottom and sides... then i just have the crystal like toilet sanitizer thingys laying in the funnel to keep it from smelling back into the garage...
nzm.031
East Maitland, NSW, Australia
so its a no.1 only then i take it.... thats a ****** good idea... i hate trying to sneak in to the house at 2am to take a leak, only to have the dog wake up and go mental.. or i have to go outside and quietly try to relieve myself... youd be suprised how loud such actions are when its dead silent and dead still at 2am.
I
imahemi
Omaha, NE
a quick update of a couple things I have been up too...
first I closed in the garage entry... added a floor to the area because you already had to step up to get out or into the garage...
next I finally finished up the wall in the added part...
added a channel for my winter insulation to fit into for air gaps :)
more pics of this later when I put the insulation panel up for the winter...
then I painted the pocket door to blend into the wall :D
finally next years potential space :bounce: :lol_hitti
I
imahemi
Omaha, NE
middle of winter bump!!!
nothing going on garage mod wise... just some parked vehicles... lol :mrgreen:
kizer
Marysville, North of Seattle WA
Were those airlines PVC???
Yep he is.
I have 1/2 PVC lines in my garage as well. I think mine are rated to 300 PSI or something like that, which is Water PSI not air, but none the less. They get a bad rap because they explode. However I've never personally seen one explode. I however have seen them split and leak, which is typically because of a bad glue job, but never explode. Your running these lines at what 100 to 135 PSI max? Unless you have an output of 175PSI or something crazy. Mine is normally regulated at 100PSI.
Most building officials frown at them, but until you can buy black iron or that cheaper Aluminum stuff for .25cents a foot I don't personally see desire to spend the big bucks.
pacmktg
Foothills of CA
I know this has been beat to death but I do not see a problem with PVC inside a wall. The danger from PVC is not that is just spontaneously explodes. The danger is it being hit with something and then goin BAM and sending shrapnel everywhere. Can't do it encased in the wall.
DanD1
The Real NorCal
Wow! You have done a great job. :thumbup: Would you mind stopping by my garage and doing a little work? You should be done in about six months :bounce:
I
imahemi
Omaha, NE
Yep he is.
yup 1/2" sche 40 pvc in the wall... no problems...
That is a sweet place! You have done a great job! I really like all the signs and such!
thank you!!
thanks.. yeah this has been a bit of a continuous project, looking back i might have concidered extending that entry bump out the full length of the garage. but now that the roof and stuff is complete i will just have to add that shed for extra room... :) and i will be right over in a couple years... hahah
Malcolm
Holy ****, Ryan... I had no idea you had put so much work into your garage (or it was that big)!
Very nice!!
Malcolm... uh, errr Nick. :)
z28cp
Bellevue, NE
Hey Ryan, I live in Bellevue. Just curious what part of Omaha you are in. I don't expect you to post your address, just curious as to the general part of town. Most of the houses in your pics look older.
Thanks!
Dave in Bellevue.
I
imahemi
Omaha, NE
Thanks!
Dave in Bellevue.
welcome dave!!!
im in midtown area...
