Differences between HF 56" Series 2 boxes w/different part numbers
71goldss
Northern Calif
Differences between HF 56" Series 2 boxes w/different item numbers
I posted this today in another thread and felt that maybe it should have it's own thread.
As is common with many, if not all HF products, there are two different item numbers for the new 56" US General Series 2 top box, and two different numbers for the bottom box.
I bought two black 56” bottoms a few weeks ago. Each of my stores had only one in stock, so I bought them separately on the same day and didn’t notice their item number difference until I unloaded them. Currently, one is in my garage, and the other is being stored at my girlfriend's place until I make room for it at my place.
There are definitely manufacturing differences between the two. The top ledge on the front of the drawers are different. One measures approx 1 1/8”, front edge to rear edge, vs approx 3/4” on the other box. One box has rivets front and rear on the cabinet side of the slides. No rear rivets on the other box, which makes the drawers squeak like hell and cause excess side to side wobble when opening, but I’ll fix that. Also, different casters, different top mat (one is more like vinyl, and other is more like rubber), and one has thicker/beefier plastic drawer latches. I had also noticed when removing the drawers that the same drawers from each box seemed different in weight, so I weighed the upper right narrow drawers from both cabinets on a bathroom scale (not exactly scientific), and there was approximately a 1 to 2 pound difference in weight. And that's just one of the small drawers! Add that up over the whole box! I didn't use my caliper to measure the sheet metal thickness, as it would seem that powder coat can effect the true measurement, but the scale show's there's a good difference somewhere between the two. Even the product sheets that came with them are printed different. PDF's from HF's website confirms that also.
If I had it to do again I would definitely make sure to get both with item # 64457. I feel it is the better of the two. FAR BETTER! It just feels much more solid and heavy duty. The 64458 feels like a Craftsman box to me, and I have a lot of experience with Craftsman boxes. I’m assuming the red 56" boxes would also have the same differences between item numbers.
It seems obvious to me that my two were manufactured in two different factories. I’ve since been to one of my stores that displayed one factory’s top on the other factory’s bottom. If I weren’t looking for the differences, it would be hard to notice, but I definitely notice it now! *****, but it would be too much of a hassle for me to load the 64458 back up and return, but I will probably always regret that I didn't.
Nothing scientific here, but just my personal observation and opinion. Maybe this can help other members on what to look for if planning to purchase the new 56" box. They can then decide which box they prefer.
Edit: I forgot to mention one of the very first differences that I noticed when unloading the two boxes from my truck, and it may be a huge deal to some people. The 64457 not only has the larger plastic drawer latches that can be easily removed by removing two small screws from inside the drawer, but it also has detents to hold the drawers shut if you do choose to remove the latches. It takes a good tug to break the drawer loose when opening (like on the 44" boxes), even after sliding the latch to the open position. This would be great for those that hate the plastic latches and wish to remove them, and bad for those that like the latches and want to keep, but now have to slide the latch and give a good tug also. The 64458 has the smaller plastic latches, and are held on with one single rivet inside the drawer. If you wish to remove the latches, you'll have to drill out the rivet. And, the drawers don't have detents. With latches removed, there's nothing holding the drawers closed, requiring the magnet trick or some other fix to keep the drawer closed.
Mr_B
Reading
load it up, not a lot of effort for something got live with for years.
really got pay attention to what buying at HF, between different same item manufacture and totally changing manufacture or manufacturer changing material/component source what you get and the quality can never be taken for granted .
untchabl
I would take the little bit of time to load it up and take it back to exchange it for the nicer 64457. As mentioned, you'll be living with this for years and it will always bug you.
M6erfan
'Merica!
Agree, take it back if you're not happy. It'll nag you 20 years from now...
Edit: and thanks for posting (with part #'s!) to raise awareness.
Mr_B
Reading
Only good thing is you learnt something about the HF box number variations and posted it .
This reason some say drawers solid and others say flop about like a fishes tail .
If planning have them together as matching set that going bug even more .
Few hours to swap it over of few years sulking about it !
Swap it out and be 100% content, don't think about it too long, quicker dealt with the easier it be ...
Really wish HF wouldn't have similar products retailed as same from different suppliers ...
The hydraulic press good example or the CN or TW made pitts pro impact sockets .
71goldss
Northern Calif
Thanks for the feedback guys! I actually posted to make others planning to purchase this box aware of the differences, but now I think I’ll take your advice and take it back. I won’t have my son to help until next weekend, but plan to go to the store where I got the 64458 and talk to them this weekend. They are also the store that have the mixed top and bottom set on display, so I’ll be able to point out the differences to them right there! My receipt states 90 day exchanges/refunds. I also haven’t been using the box yet (in storage) so it’s still in unused condition.
kngelv
Detroit, MI
I have the 56” Series 1 top and bottom. I hate the latches so today I went to take them off and found that I have the same issue. The top box latches are held on by screws and have a detent while the bottom has rivets and no detents. Just my luck.
James
71goldss
Northern Calif
James
I’m curious if the top front ledge on the drawers on yours are a different size also? Probably are since the latches are acually a different size.
Mr_B
Reading
latch and detents a big concern as plastic latches alone not great and typically the ones with no detent have the more flimsy latch .
HF need be more picky on manufacturers and stick with one manufacturer for these sort of items .
Good on OP for taking it back, be worth it get match pair with manufacture features you prefer .
Also good be publicised so others more aware of differences .
71goldss
Northern Calif
I just got back from the HF store where I purchased the 64458. Told them I was returning the box next Saturday and they were super cool about it. They don’t have a 64457 at their store, but checked stock and another local store does. Said they would give a refund and call ahead to the other store to honor my original sale $649 price. Hopefully that store still has it next Saturday, but if not I’ll just wait for another sale and more stock. No big deal since I’m just storing the box till I’m ready for it anyway.
Mr_B
Reading
cool
to be fair HF generally pretty good on returns .
Hope it works out and wrap it all up on the Saturday .
inane2
Central KY
I really appreciate this post and the OP taking the time to detail it.
I've had a similar experience I'd like to share, but with the 20 ton press I bought last winter. Had a coupon for it but it listed two item numbers. I asked the guy who went to retrieve it from the back about the difference and he didn't know. When he brought it out, he said they had a bunch in stock, but there were all the same item number. On the way to the register, I stopped and looked at the display, it had the other item number that was listed on the coupon. Got it home and put it together just fine. Few weeks later back at the store, I looked at the display (with the different item number) and there were several, significant differences. More metal, more welds, better supports, etc.
Fast forward to this summer, I was going to pick up the 2 ton cherry picker. Noticed there were again two item numbers. Not wanting a repeat of the 20 ton press situation, I called HF. Guy was cool, and explained that it was because the crane came from two different manufacturers. I assumed one item number was newer than the other and superseded the older number. He again explained that one is not newer than the other, but it comes from different manufacturers. He went one step further and compared the parts diagrams and explained that one showed a replacement caster and the other didn't. The one i bought is the same number as the display so I can't compare it for any differences.
Oddly enough, just two weeks ago, I saw the price tags for the orange, yellow and lime folding shelves for the 5 drawer tool cart. Each of those new colors already listed two different item numbers for the side tray.
redwrench60
East Tennessee
Anybody know if there’s also any differences between the different item numbers on the 44” series 2 boxes? Anyone have more than one series 2 to compare?
Mr_B
Reading
for sure be some differences
would assume factory not using rivets and bending drawer ledges different being doing it on all sizes .
Interesting to have closer look and see if pattern on odd/even number always links to same factory (expect it will)
Craftfab
Garage
Which model number do you have?
SRSemenza
Sorry if this is OT. But it is related. Even the different nitrile glove #s fit differently. I have written down the # for the ones I like the best and keep it in my truck so that I know which to buy when I stop at HF.
Seth
MostH8d
I'm not sure what the item numbers were, but my local store has 2 different ones on display. I didn't comb through them too much as I was there to look at the 56" model. However, one big difference that I did notice was that on one model the drawers had true full extension drawer slides that allowed the back of each drawer to come out past the cabinet almost an inch. This is a great feature in my opinion. The other model left about 3/4" of drawer left in the cabinet when in the full open position.
Sent from my SM-G935V using The Garage Journal mobile app
redwrench60
East Tennessee
That is definitely an important observation. That’s the kind of stuff I’m after. The series two 44” model I played with in store was a black version with full drawer extension like you describe and the item number was 64442. There’s two other item numbers in black 44” boxes but that’s the only one they had.
inane2
Central KY
On the 20 ton press, I have 32879. Go for the other model (60603), it has a few very nice improvements.
On the shop crane - 69514. Not sure about any differences in the other model.
6PTsocket
Re: Differences between HF 56" Series 2 boxes w/different item numbers
Back it goes. It would eat at you every time you use it. I hope that is not one of their items with a restocking fee. In my branch I found them to be oblivious to the different stock numbers. It is all the same to them even when it is definitely not. Thanks for letting us know the differences. When buying an expensive item from them, that is always a concern. The worst case I remember is they had an alternate compressor for the 5 hp, 2 stage. It was a three cylinder single stage that they listed as a 2 stage. Same price, same listing but different specs. It was not around for long.
71goldss
Northern Calif
I swapped out the 64458 for the 64457 today rather than waiting until Saturday. A seamless exchange, taking only a couple hours of my time overall. I’m now a happy camper! :)
71goldss
Northern Calif
Marketed as the same. Both numbers are listed on the paper slip that you take up to the cashier to purchase. Even when the cashier entered the 64457 number in her computer today to see what stores have stock, it automatically cross referenced to the 64458 number as well. The only way to know if a store has the actual item number you want, is to have an employee check the number on the carton in their stockroom. The cashier called 3 or 4 local stores for me and had them check their stockroom to find. Only one store had the 64457 after checking carton numbers. If ordering online, it may be a crapshoot as to what they will ship.
UncleB
VA
Assuming the red ones are the same way:
But my guess is the 64165 is the equal to the 64457
And that the 64164 is the 64458.
It could easily be the other way around, as the black ones the lower number is the one you prefer- I'm making this assumption because the item descriptions of the 64165 and 64457 both have the addition of California prop 65 info at the bottom.
Curious, because i'm considering buying one of these this weekend.
kngelv
Detroit, MI
Let us know. I just sold my 60” Milwaukee from Home Depot that I got last year with the website price glitch. Looking at another HF 56” in red but would like the detents.
James
71goldss
Northern Calif
I had mentioned in the opening post that even the user manuals that came with the two different boxes were different. Because of your question, I checked HF’s website and downloaded the manual pdf’s for both red 56” boxes. The manuals on the red 64164 and black 64457 are the same manual and probably built at the same factory. The manuals for the red 64165 and the black 64458 match each other and probably both from the other factory. I’d be betting on the 64164 to be the better box, but can’t guarantee without seeing the box in person.
kngelv
Detroit, MI
Good to know. Thank you.
James
jserr68594
I just purchased a 56 inch top and bottom box that is red in color. The correct SKU for the better bottom box with detents is 64164 and the top box is SKU number 64135. Hope this helps someone out!
UncleB
VA
Thanks!
My local store only has a black one on display.
Though now I'm considering the 72"...
UncleB
VA
^Yeah.
Just trying to weigh the pros/cons of the size difference now. Any suggestions?
Mr_B
Reading
only real difference in 72" and 56" is wider top drawer and the side bank of drawers, add a hangon cabinet and a 56" becomes virtually same ...
UncleB
VA
One more question- Are we on the assumption that the top box also has the same changes? Looking at the manuals now and see no difference in those, but would love to get a "matching" set.
EDIT:
somehow skipped over this. Thank you!
UncleB
VA
Went to the local store- had both the 64164 and 64135 as open box. Got them out the door for around $900. Thanks again for the correct numbers!
Magnum440d100
Indiana
Same thing happened to me with the 20 ton. The one I bought bolts together, whereas the other one is welded together. Just as well. The welded one wouldn’t have fit in my vehicle to bring it home.... would have been nice though.... but so far, no complaints. It has exceeded what I bought it for....
PAToyota
South Central Pennsylvania, USA
I've been looking at the 44" and 56" lower cabinets and came across this thread while doing some research.
I went and downloaded the manuals. Of the three 44" models, on the second page two are listed as 2640 lbs capacity and the other is 2600 lbs capacity. The 56" models are both listed as 4400 lbs capacity.
I've long known that the different numbers were different factories and recognized some minor differences here and there, but this seems to be a bigger deal than I had realized.
mikez8z
Charleston, SC
Hi All,
Longtime lurker, first time poster...
I went to my local HF today becuase I am going to be buying one of these 56" Series 2 toolboxes soon. They had a 57 on the floor and a 58 in the back. The manager assured me that the only differences are that the plant is different ("they are across the street from each other" was what I was told). She said the designs were 100% the same. Do you have any pictures that might show the differences? I played around with a couple of the 57 that was there and liked how solid the drawers felt. I also noticed the detente after the latch catches on the drawers.
Thanks all.
Mr_B
Reading
He got pics in other thread on the drawer top edge being different depth .
Factories certainly bit further away than other side of street lol .
one using completely different spec slides and plastic pull latch and if that top panel on the drawers bent different depth that measure going effect rest of drawer/box measures if check it out fully with a tape measure .
They certainly not 100% same and that manager just covering lack of real knowledge with usual bs ...
