DIY Cheap Garage in SE Michigan
scrapmetal57
Waterford, MI
After two years I figured I should document all the work I have done to my garage.
Up to date album of all my pictures:
https://photos.app.goo.gl/sRNyyoR6GKSpxc8NA
View media item 88895
View media item 88896
Quick overview: I bought my house in 2016 mostly for the garage and wasn't planning to do that much to it. Unfortunately, the previous owner caused me all sorts of problems. He removed the metal work benches and didn't wire the garage correctly.
The first year I installed gas line and a furnace.
View media item 88901
The second year I had to completely redo the electrical. I decided to insulate, and I'm working on drywalling right now.
View media item 88902
View media item 88903
View media item 88904
I scored a 7k Bendpak lift for cheap that will be going in soon.
View media item 88905
I am trying to do it all correctly and to code. I plan to put all my findings and learning together, answer any questions, and hope to get some advice from the experts on GJ.
Bert_
NW Iowa
Agreed panel looks really nice. Might not like it so much if I had to pay by the hour for it :)
I'm going to call you out on that conduit going to the furnace. The cover on the box in the wall can't be removed. Should have used flex with that cover or an extension ring with the conduit.
scrapmetal57
Waterford, MI
That has since been changed. But it did pass inspection with the emt. It sucked to install that's for sure. c3d51fd64e3758852d2ba01e75479efa.jpg
scrapmetal57
Waterford, MI
More drywall done. I'm hoping to finish up this corner to I can put my workbenches back and start moving all my tools back into place.
I really need to finish so I don't run out of time on the permit.
Heater is also fixed and it is great working in a warm garage.
View media item 88987
scrapmetal57
Waterford, MI
Finished the ceiling, got the workbenches in place, and put some outlets in.
I read somewhere that it is good practice to flip the outlets upside down so that if you drop any metal on a plug you hit the ground before the hot. So I flipped all the outlets too.
View media item 89013
scrapmetal57
Waterford, MI
Got some more drywall up and outlets installed.
I forgot how many 240V outlets I wired. I think I have 6 total in the garage. Two are on this section. I'll probably just block them off until I figure out what receptacle I'll need.
View media item 89060
scrapmetal57
Waterford, MI
Update on progress. I had some friends come over this weekend to help finish up the big pieces of drywall. All the walls and ceiling are done. Just need to finish up the boxed section for the lift and above the garage door. That isn't needed for the final inspection so I'll get to it later. All the outlets are wired and working.
Tomorrow I'm going to finish up the drywall in the box and get my LED lights mounted on the ceiling. Then I need to hang the garage door track and I will be done for now.
I also figured out how I'm going to wire the lift. There was a surprisingly little amount I could find on the internet about how to go about it for my application. I'll take some pictures once its all done. The plan is rigid conduit to a junction box on the top, then an SJOOW cord with a plug to the receptacle in a box on the top of the ceiling. I'm going to use an L14-20 plug since the motor is rated at 15A and I have a 20A breaker. And 4 wire means I could add some outlets right onto the lift if I never need to.
More pictures!
View media item 89163View media item 89164View media item 89165View media item 89166View media item 89167
1953mercury
Steamboat Springs CO
A little late to the show here. First, your place is looking great, and you've come a long way. Secondly, a little late to help you, but for those not to this point yet and following along, a 6 mill vapor barrier between your stud wall and sheetrock is a definite should do, and it is pretty much SOP to stagger your sheet rock joints at half sheet intervals to prevent cracking along your joints. Same as you would for exterior sheathing for strength. Looking forward to seeing your continuing progress. Mike
scrapmetal57
Waterford, MI
Thanks for the suggestions. You aren't the first person the suggest staggering joints. I have not decided whether I will tape and mud the joints yet, and if I do, its a garage so I don't care about hiding the joints.
As far as vapor barrier goes, I used Kraft-faced insulation (got on sale). From what I researched, you can either do unfaced with a vapor barrier, or faced by itself. My priorities were lowest cost and time spent, so that was my solution.
scrapmetal57
Waterford, MI
Some more updates.
Passed inspection. Finished all the outlets and got the cover plates installed. Drywall is complete (except for above the garage door, but that is low priority).
Whole garage:
View media item 89245
Ceiling outlets and lights:
View media item 89244
View media item 89243
Wall outlets complete:
View media item 89242
View media item 89241
View media item 89240
Twist Lock plug for the lift:
View media item 89236
Bendpak lift feet could use some love. I may sandblast and powdercoat them later. I got new rubber pads for them.
View media item 89237View media item 89238
View media item 89239
scrapmetal57
Waterford, MI
Made a lot of progress over the last few days.
Added two more 4' LED light fixtures over the workbench.
View media item 89276
Installed the garage door brackets. I was worried about the withdrawal loading of the lags going into the bottom of my trusses. I used the American Wood Council Calculator and consulting with a civil engineer friend. Each 3/8 lag is into the truss 2.5", and should hold at least 300 lbs. The whole 16'x10' garage door should weight less than 400 lbs. There are two lags on each bracket, holding at most a quarter of the weight of the door. I'm confident the brackets will hold fine.
View media item 89270
View media item 89271
View media item 89272
With a lot of help I moved most of the garage stuff into place and got it organized.
View media item 89274
Those yellow and black boxes are filled with my tools that used to be on pegboard behind the workbench. I need to figure out where I'm going to put them now.
View media item 89273
Enough room to pull in the FJ and do an oil change before our Christmas road trip!
View media item 89275
jacric2005
Lane County, Oregon
I sure like the idea about not taping and mudding. I'm doing fiberglass bats and OSB painted white on the walls. Based on what you're doing, I think I'll do fiberglass and sheet rock on the ceiling. Your's looks really good!
scrapmetal57
Waterford, MI
Thanks! I have so many projects that have been on hold while finishing the garage so taping and mudding is low on my priority list. I would have loved to do OSB or plywood on the bottom for a more durable wall and something to screw into, but it was too expensive.
scrapmetal57
Waterford, MI
Got the Bendpak 7,000 lb lift bolted to the concrete.
I still need to connect the hydraulics and equalizing cables, and install the wiring to the power unit. I should also move the trip stop tube down under the ceiling. Eventually I want to paint or powdercoat the lift arms but that is low priority. I can't wait to get a vehicle up on this.
View media item 89639
I know the orientation of the lift is weird. This seems to be a very early version of the asymmetrical lift. Here are some pictures of where they were installed in the Toyota Dealers Service Shop.
View media item 89640
View media item 89641
View media item 89642
scrapmetal57
Waterford, MI
Ran the electrical for the lift power unit.
I ended up leaving the routing of the overhead lift off switch wire into the power unit. I put 10 AWG THHN from the motor through flexible liquid tight conduit into the switch box. The switch is a 30A DPST switch just as a precaution. Then 1/2" EMT up to another box on the top of the post where the SJOOW cord goes into the twist lock receptacle on the ceiling. I tapped 1/4-20 holes for the boxes and conduit strap and cut the bolts down to be flush with the inside of the post. I offset the conduit to the left because the safety lock blocks are welded to the inside edge of the post (the right side of this post).
All that's left is to clean the bottom of the posts and put the arms on!
View media item 89738
scrapmetal57
Waterford, MI
Nice setup. I like the ceiling recess for the lift. A 120V outlet on the posts is useful and keeps extension cords out of the walk space.
I was going to do that. But to do it properly, I would have needed to run a separate 120V circuit above the lift to drop down. I have a bunch of outlets on the walls and will set up a cord reel overhead. Maybe on the next lift.
scrapmetal57
Waterford, MI
Lots of updates.
Tried out the lift on my WRX and my buddies Chevy HD. The truck doesnt quite fit in the garage which is too bad. I probably could have moved the lift more forward but was thrown off by how it is oriented. A 19' long truck would be tight in my 25' long garage anyways.
View media item 90014
View media item 90032
View media item 90016
I pulled out my old work benches and installed a set of kitchen cabinets that I got for free on CraigsList. They needed a lot of shims to fit but I'm excited to have some drawers and covered storage space. Where the sink and stovetop were had false drawer fronts so I am going to retrofit actual drawers in there. The plan is 3/4" plywood for the sides, 1/2" for the bottom, and ball bearing slides. Could use a fresh coat of paint but I don't plan to do much.
View media item 90018
View media item 90019
View media item 90020
View media item 90021
