The New Shop!!!
bad_idea
Pasquotank, NC
Looking good. I broke ground on my 30x40x12 in July. I am STILL working on it. Hope to be done by the first week in January.
T
tricountytrail
Pendelton, NY
Utilities to Barn finally in, at least the ground work.
casmurbax
Wilton, NY
Looks great. Like the colors as well.
What will you being doing in it?
Dumb question why 3 man doors?
What did you trench besides power? How far did you trench?
T
tricountytrail
Pendelton, NY
Work area toy storage/ man cave!
Utilities
1" water 200'
1" gas 200'
1 1/2" and 1" for electric 160'
1 1/2" sewer back to house 225'
Getting final grade on inside stone and installing under slab conduits tomorrow before I do the 2" insulation on floor and sidewalls.
casmurbax
Wilton, NY
Looking good, best of luck to you with the new Man cave..
How is the sewer going back? Hard to tell from pictures of the grade. That far from the house are you going to put a driveway to it or is it accessible from the back side of your property?
:beer:
Jeeper89
Rockford MI
Looks great, very close colors to my shop. This may be a silly question, but is a 1" gas line large enough for a 200' run? I'm by no means an expert, but I am putting in a 1 1/4" line to my shop and its only a 35' run to the shop then another 20-30' inside the shop that I will be running in 1". It's natural gas and I am going to be feeding a 125,000 BTU unit heater. (I also like a little overkill but maybe I read the charts wrong.)
Nick in WI
I'm not sure about him but I am planning a 1" line out to my shop (300' from house 400' total from meter) I will be having the meter regulator replaced with a 2 psi regulator to make it work. With a 2 psi regulator 1" line is good for something like 700k btu's at that distance if I remember correctly. Then each appliance will have a regulator down to the standard 1/3 psi. It's the only way to do a run that long without a 2" line or something ridiculous.
On another note, the shop looks great, I like the darker colors. Are the headers on the side for a future porch/carport??
T
tricountytrail
Pendelton, NY
:beer:
The grade back to the house grinder pump is slightly uphill, I am putting in a grinder pump and pumping the 1 1/2" line back to my existing sewer system.
I have a driveway I put down with 8" of millings for access.
T
tricountytrail
Pendelton, NY
Maximum Capacity of PE Pipe in Cubic Feet per Hour
with a Gas Pressure of 8.0 in. WC and a Pressure Drop of 3.0 in. WC
Tubing
Size
Tubing Length (ft)
200 250 300 400 500 600 700 800 900 1000 1100 1200 1300 1400 1500
1/2" CTS 37 33 30 25 22 20 18 17 16 15 14 13 13 12 12
3/4" IPS 215 189 171 145 127 113 103 96 90 84 80 76 72 69 67
1" CTS 279 245 221 187 165 147 134 124 116 109 103 98 94 90 87
1" IPS 393 345 311 264 232 209 191 177 165 156 147 140 134 128 123
1-1/4" IPS 715 629 566 480 422 375 343 318 297 280 265 252 241 230 222
1-1/2" IPS 991 878 796 681 604 547 503 468 439 415 394 376 360 346 333
2" IPS 1954 1719 1548 1312 1154 1060 970 898 839 790 748 711 679 651 626
Yes I added double 2x12 ledger boards on both sides for future overhangs The town counts overhangs as square footage and I used all of my variance for the pole barn, thats another battle I will have.
casmurbax
Wilton, NY
tricountytrail,
Another silly question, do you think you would ever put a lift in there?
What are the 5 conduits for going across your floor for?
T
tricountytrail
Pendelton, NY
tricountytrail,
Electrical feeds from main box to pull boxes under concrete. 2 are for pex water lines to get water to the other side of the shop. Once I get them all in and the plumbing I will add 2" of more stone then 2" of Insulation, mesh then pex then 6" on concrete.
Probably looking at 4 post advantage lift.
T
tricountytrail
Pendelton, NY
T
tricountytrail
Pendelton, NY
Ready for Vapor Barrier Mesh and Finally Pex!
://www.garagejournal.com/forum/attachment.php?attachmentid=887225&stc=1&d=1556233376
casmurbax
Wilton, NY
That's great.
Do I see a pipe that just ends? It look likes its about even with the overhead door and the 4th pvc pipe sticking up?
Looks like it is coming along nicely, good for you.
T
tricountytrail
Pendelton, NY
That's great.
Good eye I put in a couple lengths like that to feed a thermo couple for temperature readings if I want. It will come up in the stub wall.
rixtrix1
Chandler, AZ (from west NE)
Great looking building. I like the high sidewalls and upper windows! Will it be high enough above the surrounding grade so the underfloor conduit isn't always in water. I realize your floor is probably 10" minimum higher than when you first posted pics, but it looked like the only standing water was inside the structure in the first pics, or are you planning on drain tubing around the outside?
T
tricountytrail
Pendelton, NY
Gutter Drains and area drains are next it has been TOO wet do do any site work. I have a 6" drain out to the ditch that everything will tie into. I dug a ditch to that temporary to get water out of the barn to get rid of that standing water.
Now that the floor is in I can start working on that except more rain is in the forecast.
TurboMustang370
Central, New Jersey
The contractor I used saw cut it this evening.
28 days is time concrete takes to cure. "Shouldn't" put heavy equipment or anchor anything into the slab until its cured.
6-7.5" thought-out the slab, 8-9" at the overhead door thresholds. Overkill but it'll work.
Interior floor is 40'x60', exterior lean-to's are 10'x15' and 10'x60'.
I'm very lucky, the concrete contractor is a family friend, he did it for cost of materials and labor for his crew.
derek_m
looks good, and looks familiar. are you in pendleton off meyer? i'm on campbell...
casmurbax
Wilton, NY
Its looking great.
thermo couple for temperature readings, that is interesting.
Is that a smooth finish?
