Need Torque wreench help Dont want to buy twice thank you
JOE.G
Eastern ( Catskills ) NY
Need Torque wrench help Dont want to buy twice thank you
Guys I am looking for a Med duty torque wrench, I have a cheaper Teckon for the 1/4 and another cheaper 1/2 that goes to like 150. I never really bought a good wrench and I am not sure why as I am a pretty bigger believer in torque specs.
I am assuming most are going to say get the CDI so i my real question is do I go with the 3/8 in the 5 to 75 or the 3/8 th is a 10-100 ft lb.
Most of the things I work on are quads/snowmobiles/motorcycles/cars and light trucks.
This is a hobby tool not a full time job item.
I think either of these would cover a good majority of the range I use as I don't ever see myself using a 3/8 for anything below 10 or 15 LB and probably never up to a 100 LB.
I would say a lot of my wrenching is in the 20 to 60 rang and below 10 FT range.
Down the road I would like to add on other quality wrenches to fill in the gap.
Thank you
https://www.amazon.com/dp/B00HQGI3VY/?tag=atomicindus08-20
https://www.amazon.com/dp/B002LA19P2/?tag=atomicindus08-20
https://www.amazon.com/dp/B000KL2J7G/?tag=atomicindus08-20
plinker
Northern Wi
Precision instruments make very nice torque wrenches ( the split beams are very popular), as does CDI (Snap-on owns them, CDI uses a different ratchet head). Some deals can be had for Armstrong/Napa/ete.. torque wrenches on ebay too.
PI wrenches...
https://www.tooltopia.com/search.aspx?find=precision+instruments&log=false&manufacturer=183
I think 5-75 lb covers most needs in general, I also use a 3/8 drive that's 30 or 40 to 250 inch pounds about as much since it covers most of the lower scale of the 5-75 ft lb wrench.
My Snap-on tech wrench covers 5 to 100 lbs which can be nice for somethings.
Magnum440d100
Indiana
I’ve had good luck with my Craftsman. Built a few motors that haven’t come apart, and have torqued lug nuts and wheels haven’t come off, so it must be ok haha
txvwnut
Bedford, Texas
Precision Instruments best bang for buck. By once cry once although they are very affordable and a torque wrench is really not something to go cheap on.
6PTsocket
Re: Need Torque wrench help Dont want to buy twice thank you
Thank you
Generally, clicker type torque wrenches are speced to be 3 to 4 % accurate from 20% to 100 % of the full scale. A 5 to 75 would be good from 14 to 75. The reason is that below that the there is so little pressure on the spring that it cannot be accurately calibrated. In fact, some models set the lower end of the scale at 20% so there is no inacurrate part of the range.
kelpaso1
MEMBER EMERITUS
New Brunswick
I had the same dilemma. I bought a CDI 3/8 100-750 in/lbs or 16-62 ft/lbs and I hardy ever use it except for head bolts on atv's. I have since got a Tekton 1/4 20-200 in/lbs and use that way more often for small engine repair. Paid over $400 for the Cdi and about $100 on the Tekton.
pbon
I would get 1/4 for up to about 15 lbs, 3/8 for up to 100, and a 1/2 that goes to 250.
J
JOE.G
Flex head or not? CDI doesn't make the 3/8 in 5-75 flex but gear wrench does. Also I am probably going to get the 1/2 inch that goes to 250 FT do I want flex head on that?
WittHay
Surrey, BC Canada
I have the GearWrench 10-100 3/8 drive used mainly for torquing around 50 to 60 ft. lbs. The ratchet is smooth, the lock works good and its easy to adjust. Not rough or binding. Totally acceptable for my purpose.
I had a Snap-on 5-75 3/8 drive flex head a few years back. Shorter length than the GearWrench. Used mainly on diesel injection pump drives. The bolts were around 35 ft. lbs. Present day I would have a Techangle to do that type of work.
My reasoning is that the less bolts there is holding something and lower the ft.lbs. The better quality torque wrench you need. Aluminum heads on small motors probably a CDI or similar starting at 5 ft.lbs
Mr Ratchet
I'll second PI. They make many of Snap on's and are the same thing with their own name and different colors. Prices are reduced quite a bit.
I like the dial type with follow up pointers. My 30 + year old Torqometers are still in specs. They have a few different styles to choose from.
http://www.torqwrench.com/
ACR
Bought a PI split beam for the bigger jobs and a dial type for smaller, more precise jobs many years ago. One of the best tool investments I made!
6PTsocket
Bear in mind that if you are not square, the accuracy goes down. It is not considered a problem with angles under 15° but maximum accuracy is with the drive at a rt. angle to the handle
plinker
Northern Wi
I like a flex head for a 5-75 3/8 wrench, fixed head for 1/2 & inch pound wrenches.
TonyCH
Finland
Put your bid in on this one. You got 5 hours before it ends.
From the ad: "Save yourself a bundle on this torque wrench by buying here rather than off the Snap-on truck!". LOL... Its a vintage wrench, I don't think they have looked like that during this millenia. I have several SO tq wrenches made since early 2000's and they look much more modern than that one. EDIT: the SO-logo on the box and the tool seems to be pre 1982 type. The logo on the ratched head is newer which suggests it was rebuild at some stage.
It does look like its not seen much use though, chrome is in good condition and the box is almost spotless. But as its probably 30+ years old I think it would be a good idea to get it checked and calibrated before using it.
I do get mine calibrated every few years and they are super accurate time after time. I can recommend SO wrenches. Getting a good one second hand can be a real bargain - even with calibration costs.
TonyCH
Finland
You can have the modern ones. I much prefer the solidly built PI made Snap-on torque wrenches of that era. :)
Yeah I do and I have no complaints about them. Much more accurate than any other I've handled. And to me they don't feel like they are unsolidly built, if you are suggesting that?
But I was pointing out that the ad suggested you could buy one from the truck but truth is its a 30+ year old wrench which haven't been available for 20 some years now. So, either they don't know what they are selling or they like to ******** people in their ads. Doesn't make the wrench any worse though. Still, I prefer to pay $100 for SO torque wrench from this decade over same sum for 35 year old with a mystery rebuild and condition. To each his own.
Slinger646
Lots of older US made wrenches are waiting for their forever home in your local pawn shop.
orangeblood
Texas
Tony - glad i read your post. I was looking at a similar torque wrench from that seller (they seem to have many older models). i too am looking for 3/8 75 FTLBS wrench (used SO). any idea where a dating table for SO torque wrenches might be posted?
Steve_P
I would buy a new CDI, which come with accuracy certs, before a used SO that you'd want to get calibrated before using. I have several CDI and no complaints
