Small Parts Rack Build For 28 HF Containers
jonlb
South Central Kentucky
I’ve seen several of these builds on GJ so I thought I would toss mine into the mix. I finished this cart up last week to hold 28 Harbor Freight containers. I used 22 of the 20 bin models and 6 of the 8 bins.
Sent from my iPad using Tapatalk Pro
SuperCat
Sacramento, CA
Wow! That's going to last FOREVER! Definitely professional quality, I'll bet you could sell a few of those on the side. I'm jealous. Well done. :thumbup:
Whiskeymike
Austin, TX
I’ve been wanting to build one of these forever. Nice work, good ideas. Do you think this style could be wall mounted? I don’t have any floor space, so I gotta put it up.
Krang
Hawaii
That looks awesome, damn, now I’m having ideas....
Now that I’m designing one in my head, was there a reason aside from maintaining clean lines that you decided to drill and weld the hole of each shelf? Why not just weld the back side of each “rail” so you couldn’t see it from the front?
It’s surely stronger, but a case full of bolts isn’t THAT heavy.
Damn nice looking piece of kit though.
J
jonlb
I don’t think I would be comfortable wall mounting one this large but a smaller configuration would certainly work well. I purchased right at 200 lbs of steel for the project and used somewhere between 3/4 to 7/8’s of it. That’s with 1” thin wall square tube and 1/8” angle. So that’s 150 to 175 lbs just for the frame. I’m not sure how heavy the hardware is but just the 5 or 6 containers I have of nails and screws are probably 75 lbs or more. It adds up quick but with enough lag screws I’m sure a wall will hold more than I imagine.
J
jonlb
I honestly just thought it would look cleaner in the beginning and maybe I’m a glutton for punishment too. I ended up putting a heavy tack on the backs anyway because I didn’t feel like the plug weld would be enough. If I had it to do over again I would weld the back or the top and bottom of the angle and not drill 112 holes. “Facepalm”
Keith_MN
Minneapolis Metro
I really like the density of storage you made. Looks great.
One question, why did you make the base frame stick out the front be a few inches? Just for added stability?
Krang
Hawaii
Okay, sometimes there’s one of those obvious reasons but thankfully I can avoid the 112 holes lol.
phule
Wow! Looks excellent! Now can you make me one..lol!
Sent from my SM-N960U using Tapatalk
NUTTSGT
Northern Central Ohio
Did you buy all those containers at one time or a few here and there. I suppose if you have a HF locally, you could buy one at a time, each with a 20% off coupon.
Edit:
If you bought them individually, you could get a serious stack of "free" parts trays, cleaning cloths, tarps or something.
J
jonlb
That’s correct. My worst fear would be this whole thing toppling over and tens of thousands of parts start flying around. These particular containers are about 13” deep. I think I used 5” casters so they could each potentially swing inward 2.5” so it would only be 8” wide without the extension during a worst case scenario and about 54” tall.
J
jonlb
Edit:
I purchased 9 of the 20 bins at a time for $5.99 with a coupon and I got 20-25% off on half of the larger 8 bins and paid full price for the other half. Three trips to the store total.
NUTTSGT
Ahhh, I forgot about buying several off of one coupon. I just checked and see there is still a coupon to get them for $5.99, limit 4.
Often times, when I need something like that, I take the wife, give her the coupons and send her through the other check out.
J
jonlb
Here is the coupon I used for the containers in case anyone would like to buy some. It reduces the price from $8.99 to $5.99. Limit of 9 per trip. They will also ship the order for a flat $6.99 if you don’t have a store near you.
J
jonlb
Here are a few pictures of the bins to give an idea of the storage density and bin sizes
Large Nails
2” - 4” Drywall Screws
3/4” - 1-3/4” Drywall Screws
Wood & Metal Screws
Concrete & Lag Screws
J
jonlb
84eee400d2ca38b37e9d535fc6a538f2.jpg39f45890516929723e9e42cba494a19a.jpg75c6da1e43719628f739e63d99b7c8e8.jpg2f89fd45e26b2f5c1a80cef07c460b4c.jpg1f720e9dc8a3cb1900a58a4786d18dbd.jpg
J
jonlb
e27b3b3e2e22b37afa38d7e20954f7bd.jpgb4a39dd0dfbb10d13e7be1d6b658049e.jpga1558c696b4ebe2a6b32d52efd2bc8be.jpgjbf24536239374b5daf7a87cb17c6d179.jpg6c7a0206cb3e72fb15830291ffa874f8.jpg2407fc2b4e625088243e127d0dcb13a1.jpg688ee3d1d3234f154f76e09a8bce7f52.jpg
TommyK
CT
Awesome build. I will be copying for sure. Perhaps I missed it but do you have any plans for labeling?
J
jonlb
I have a p-touch labeler that I purchased yellow labels for. I put them on the handles but the handles are curved both horizontally and vertically so time will tell if they will stay on but for now it works great.
n2jeepn
Meridian, Idaho
Excellent build! I work much better with metal than wood, so I had planned to build mine similar to yours (minus drilling all the holes and doing the plug welds!).
I've been collecting the parts bins, but seeing how you arranged some of yours really helped my think outside the parts-BOX :)
Having things like the glue guns and glue sticks together in one is ingenious.
I usually know where my glue gun is, but the glue sticks, they can be anywhere!
Thanks for posting, and again, excellent job.
StormcrowAz
Phoenix, AZ
I’ve seen several of these builds on GJ so I thought I would toss mine in to the mix. I finished this cart up last week to hold 28 Harbor Freight containers. I used 22 of the 20 bin models and 6 of the 8 bins. I still need to pick up two more but after using it for about a week I am really happy I took the time to build it.
Nice work! I am right in the middle of doing a similar build. Three rows across, 12 bins high on mine. Also going to use full-extension drawer slides riveted to the framework.
20190101_110810
20190101_141523
hemiallen
Sacramento, Ca
Nice setup
I just looked online and I'm thinking there is only one model, and you juts intermixed the small and larger yellow bins to get the ones with mostly small bins and a few with just large bins?
Do they sell the bins separately? It looks like they have 2 versions, this one at 2-1/4" and a deeper 4-1/2" tall one also
Thanks
J
jonlb
Great build! Did you take any pictures of how the castors mounted? And where did you buy the castors?
I get all my casters on eBay. It seems like the best bang for the buck. These claim to have a 500lb rating each. They were only $25 shipped for a set of 4. I have several sets and they have held up well. I added the corner brace at the bottom to help support the 4th corner on the casters and secured them with the largest self taping metal screws I had. Not sure what size but it was a lot bigger than a #10.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/263305230814
J
jonlb
Nice setup
Thanks
They don’t sell the bins separately but I ended up with a bunch left over because I like to take some bins out to put the tools in the container that goes with the parts.
J
jonlb
20190101_110810
20190101_141523
That’s awesome. After using the cart for a while I can see that the slides would be really convenient but I’m very happy with the static rails too.
ford33
Chicago, IL. USA
Good to see one made of metal and finished nicely.
I built a similar rack but wall mounted from wood which holds 12 plastic cases and find that I have out-grown it after 4 years. I could see making another wall rack like yours from metal.
FYI, P-touch label come in different marking tapes. Some have a strong adhesive and are UV tolerant. Cost more but they survive a long time.
