Movin/on
A couple of one-off from friends Cut-O-Matic and Voltbox
Both were free and I don't really know if I'll ever use them. Had each for about 10 years
NCG Cut-O-Matic motorized AC torch from the WW2 ship building days in SD Ca. I also was given about 6 torch tips 00 thru 3 and a bunch of Misc. unknown fittings. The drive "cart" has 2 wheels that ride on a double V-track each about 3/8" wide and 6 inches apart. The rear wheel is on a caster and rides on the Torch side track. The left drive wheel can be unlocked so it will free-wheel. It will then follow a curved track.
Voltbox. Given this from a neighbor who is 90+ and started some sort of Vacumn welding and cutting of stainless for areo-space and medical instruments. Not sure if it qualifies as Vintage but it seems to be from the 1970's. AC in AC out 0 to 140V in and 10 amps max. out. The dial adjusts the output voltage in increments 0 to 100%. Plugged a small bench top grinder for a quick test and it did reduce the speed. Not more for more than 10 seconds so I wouldn't damage the disposable HF grinder. What type of 110V AC motors would run on this?
Movin/on
Movin/on
