The First Bridgeport and Interchangeable Parts
A_Pmech
IL
These photos are from a few years ago, but I thought GJ'ers might like to see them...
So, your car finally let you down. No problem you say, a quick trip to the dealer and you'll have a new part that is exactly the same in dimension, material, and function. The replacement will bolt right up and requires no input from you beyond proper installation. What we take for granted today wasn't always possible.
In the early 1800's mechanisms with interacting components were hand fitted and "tuned" to work together. If one portion of the assembly failed a new part would have to be hand-fitted in order for the mechanism to work correctly. On the battlefield this posed an especially acute problem. 500 muskets with a simple broken part were no better than bayonet mounts as their components were all unique to the individual serial number. It wasn't possible to simply exchange a broken X for a new Y and be back in the fight.
Enter ASME landmark # 119, the American Precision Museum and the production of interchangeable parts. The museum is considered to be the largest collection of historically significant machine tools in the country and is located in the original buildings of the Robbins and Lawrence Armory in Windsor, VT. Many of the exhibits are on of a kind, or the last remaining example of their type. However, the site is also the location where the first US government contract specifying interchangeable parts was filled in 1847.
The idea of interchangeable parts predates the Robbins and Lawrence armory by almost fifty years. Eli Whitney is credited with the idea of interchangeable parts for musket production as early as January 1798 when he took a government contract for 10,000 muskets to be delivered in 1800. Although the contract did not specify interchangeable parts at the time, Whitney hit upon the idea and began to design the tools and manufacturing methods required to produce the order with interchangeable parts. He did not deliver the January 1798 order until 1801 and then only 500 of the original 10,000 were produced. In 1801 he traveled to Washington where he put on an impressive display for members of the government. He laid out a large array of gun parts and assembled a complete lock assembly from random components. After which, he invited his astonished onlookers to do the same. Part of the foundation for the industrial revolution, interchangeable parts, had been laid.
In 1846, Vermont gun-makers Robbins, Kendall and Lawrence won the first contract for 10,000 Springfield rifles requiring interchangeable parts, a bold move. The Robbins and Lawrence shops invented many machines, powered by their waterwheel driven lineshafting, to perform tasks once done entirely by hand. Gun stocks were automatically carved two at a time with revolving templates, lock mortises were routed via a 3 dimensional template, early screw machines invented at Robbins and Lawrence by Mr. Gridley, then a machinist for R&L, automatically made many of the turned parts required. These machines, along with a host of other machinery made some of the finest weapons of the time and earned the firm a solid reputation worldwide.
Despite the museum's focus on very early machine tools, I came specifically to see a machine built a little later. In 1929, a disasterous year to be in business, Swedish immigrants Magnus Wahlstrom and Rudolf Bannow set out to manufacture and market an electric hedge clipper. The idea failed, more than likely due to the business climate of the time. Not to be deterred, they re-grouped and set out to build a vertical milling attachment for horizontal milling machines that were common at the time. Little did they know that their design would be copied many times over and their company, Bridgeport Machine, would become synonymous with "machine tool".
Their first vertical milling head was delivered in 1932. It was so well received that by 1938 they decided to build an entire milling machine around their vertical head. This hand-built machine designated a model 9BRM serial# 1, or simply a "Bridgeport M-head", was delivered to the Precision Die Casting Company of Syracuse, NY. This machine, later bought back by the Bridgeport company and rebuilt to new condition was on display at the Hardinge company (who now owns the Bridgeport name) in Elmira, NY for a number of years. It now resides at the American Precision museum.
Any apprentice machinist who can "tram" a Bridgeport can tell you why the machine was a success. Not only was the machine light and compact, but the ability of the head to "nod" and "tilt" combined with a movable quill made the machine much more flexible than a fixed vertical head or the light horizontals it would soon replace. Combined with a correctly proportioned table and lightweight control feel the machine is a joy to operate. The Bridgeport, now known as the Series 1 12BRJ-2 is, in form, little changed from the original except in capacity and horsepower. It is still manufactured today by the Hardinge company of Elmira, NY and used by shops throughout the world, including my own. Early M-head machines, some rebuilt multiple times, are still used in daily production.
The American Precision Museum website
Bridgeport serial #1:
Note the serial number stamped in the knee just above the Y-axis dial:
Photo from the Hardinge Bridgeport website showing the current Series 1 12BRJ-2:
Lock mortising machine:
One of the first Gridley screw machines, built at Robbins and Lawrence by Gridley himself. At far left you can see the cam drum and the wedge cams that "program" the actions of the machine:
A slightly later Gridley screw machine. Although surpassed in versatility by CNC swiss turning machines, several modern versions of this machine will bury a machinist in chips and require only minimal attention. I know several one-man screw machine shops that run their 1940's six-spindle Gridleys 24 hours. At night the machines are left to run alone.
A
A_Pmech
IL
A few more photos:
Armory front:
Dam and Tailrace of the shop's waterwheel:
Everyone should recognize this. It's an original sketch of the "Brannock Device" by Mr. Brannock on the stationary of The Retail Shoe Dealers of New York State:
This lathe was built by 21-year-old Nathan F. English in 1849, largely with hand tools. The only portions hired-out were casting the bed (he supplied the patterns), cutting the rack and gears, and rough-planing the bed.
Mr. English went on to develop the first automatic shoe-making machinery and holds several patents, including US# 5063
Very early Putnam planer. Notice the skill of the patternmakers and foundrymen. The standard test for an apprentice foundryman was to cast an iron teaspoon inside an iron teacup with nothing but green sand. The casting must be done in one pour and have no defects. The teaspoon must be a completely separate piece.
Adam McLaughlin
Santa Rosa, CA
I wonder how much time was consumed in the making of these machines; I would suppose that making something like this with what was available back then took the better part of a year.
Adam
A
A_Pmech
IL
Adam
Lots and lots and LOTS of time!
American Precision has the very first watchmaker's screw machine, built for an American watch company by hand. (Hamilton, I think.) The machine, which is about the size of an electric typewriter, cost the equivalent of $2.5 million of today's dollars.
Another interesting tidbit: It is said that a group of Swiss watchmakers came to America in the late 1800's specifically to visit the Hamilton watch company. To their astonishment, they saw a complete precision timekeeper assembled before their eyes from parts picked at random from various parts bins.
Upon arriving home, they started a tidal wave which resulted in the complete re-thinking of watch manufacturing in Switzerland. So, it can be said that Swiss precision is in a way the result of American manufacturing techniques.
A
A_Pmech
IL
G1K said:
Great post. I really like the old machinery. It had character back then.
Awesome machines, love that old stuff, its art:thumbup:
Most certainly! Unfortunately, it isn't appreciated as such by most people as we all know. Just another pile of industrial machinery far past it's prime.
Patternmaking at that period of time (late 1800's) was state-of-the-art stuff. Proud craftsmen showed off their skills by adorning the patterns with art. Prouder yet foundrymen figured out how to cast it, lest they allow themselves to be outdone by the patternmakers! I spent quite a bit of time just studying the castings. The attention to detail was very impressive.
It really wasn't until the 1970's that machine tool design started to drift away from careful industrial design in pursuit of the Allmighty Dollar. Today's CNC machines are just cheap sheet metal boxes disguising even uglier machinery. I think it's an unfortunate loss.
I was in a large compressor plant last year for an old lead mining operation. They had four 200HP Chicago Pneumatic reciprocating compressors there, with GE switchgear from the Edison days. The motors, compressors, switchgear, and even the hand-operated overhead crane were carefully designed to look good as well as function well.
bimmer1980
York, PA
facinating!!!!
Another great place to visit is the watch and clock museum in Columbia, PA. it is just across the river from York on the way to Lancaster.
They have some neat miniature machines that were used for making clocks and watches....
not to jack AP_Mech thread, but these photos go along with some of the comments about machines.....
I will have to keep the machine museum in mind if I ever get up that way...thanks for posting!
Steevo
43.49600, -112.04300
Please tell me you were on a ride when you stopped in to that museum, and you don't just dress that way for protection when wandering around machinery.
mike13u
S.Florida
Funny thing about those pants ... the museum Pmech is visiting is in Vt. It opens at 10am. He is from IL, and left at 8am.
trbomax
starvation lake,mi.
The mill in that pic looks identical to one of mine except for the motor. My dad told me that it (first his and now my older one) was from 37 or 38. I never questioned that and even told everyone that it was from 1937,I now know that cant be true,but its really a very early 1941! Below is # r 773 . Does that make it the 773rd built? Another question would be why mine does not have a moveable quill?
A
A_Pmech
IL
What is the serial number on the knee in front of the Y-axis dial? That is the machine serial number.
The serial number you gave is the head serial number and it is sequential. There were more milling heads than complete machines built as Bridgeport started out selling their heads as vertical milling attachments for horizontal mills. The Model "R", did not have a movable quill.
http://igor.chudov.com/manuals/Bridgeport/attachments-cat-30.pdf
trbomax
starvation lake,mi.
It does seem that the head is a 1/2 hp "R"./ When I called my son tonightand ask him to get the s/n thats what he read off. I told him where it would be,I guess he wasnt paying attention! Ill try again.
edit) just got off the phone with him and he confirmed that it is the head no. he gave me. Looking at the knee he says there is no number there. He is e-mailing a pic of it, so we will see.
IndyGarage
Indy
I love this old machinery. I'm refurbishing and old K&T mill right now - going to mount a Bridgeport head on the overarms, so I'll have both vertical and horizontal capability.
trbomax
starvation lake,mi.
I got the pic tonight and there is no trace of a serial number nor does it look like there ever was one. So whats up with that?
trbomax
starvation lake,mi.
Heres the pic. I'm not too happy about the rust,but I havent seen it in 4 yrs so it is what it is.
A
A_Pmech
IL
It's under the sliding knee cover. Crank the table farther towards the column and it should slide forward to reveal the serial number on the knee casting.
BWS
Mnts of Va
Bikes,travel,fashion...
They put sort of a crimp on what one drags home though.
Love the old iron.Always wanted an old planer........even got a nice place for it.BW
